[petsc-users] unsorted local columns in 3.8?
Hong
hzhang at mcs.anl.gov
Wed Nov 8 10:09:20 CST 2017
Mark:
> Hong, is
> > 0-cells: 12 12 0 0
> > 1-cells: 20 20 0 0
> > 2-cells: 11 11 0 0
> > 3-cells: 2 2 0 0
> from the old version?
In O-build on my macPro, I get the above. In g-build, I get
> 0-cells: 8 8 8 8
> 1-cells: 12 12 12 12
> 2-cells: 6 6 6 6
> 3-cells: 1 1 1 1
I get this on linux machine.
Do you know why?
Hong
> On Tue, Nov 7, 2017 at 10:13 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> Mark:
>> I removed option '-ex56_dm_view'.
>> Hong
>> Humm, this looks a little odd, but it may be OK. Is this this diffing
>>> with the old non-repartition data? (more below)
>>> On Tue, Nov 7, 2017 at 11:45 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Mark,
>>>> The fix is merged to next branch for tests which show diff as
>>>> ******* Testing: testexamples_PARMETIS *******
>>>> 5c5
>>>> < 1 SNES Function norm 1.983e-10
>>>> > 1 SNES Function norm 1.990e-10
>>>> 10,13c10,13
>>>> < 0-cells: 8 8 8 8
>>>> < 1-cells: 12 12 12 12
>>>> < 2-cells: 6 6 6 6
>>>> < 3-cells: 1 1 1 1
>>> I assume this is the old.
>>>> > 0-cells: 12 12 0 0
>>>> > 1-cells: 20 20 0 0
>>>> > 2-cells: 11 11 0 0
>>>> > 3-cells: 2 2 0 0
>>>> 15,18c15,18
>>> and this is the new.
>>> This is funny because the processors are not fully populated. This can
>>> happen on coarse grids and indeed it should happen in a test with good
>>> coverage.
>>> I assume these diffs are views from coarse grids? That is, in the raw
>>> output files do you see fully populated fine grids, with no diffs, and then
>>> the diffs come on coarse grids.
>>> Repartitioning the coarse grids can change the coarsening, It is
>>> possible that repartitioning causes faster coarsening (it does a little)
>>> and this faster coarsening is tripping the aggregation switch, which gives
>>> us empty processors.
>>> Am I understanding this correctly ...
>>> Thanks,
>>> Mark
>>>> < boundary: 1 strata with value/size (1 (23))
>>>> < Face Sets: 4 strata with value/size (1 (1), 2 (1), 4 (1), 6 (1))
>>>> < marker: 1 strata with value/size (1 (15))
>>>> < depth: 4 strata with value/size (0 (8), 1 (12), 2 (6), 3 (1))
>>>> > boundary: 1 strata with value/size (1 (39))
>>>> > Face Sets: 5 strata with value/size (1 (2), 2 (2), 4 (2), 5 (1), 6 (1))
>>>> > marker: 1 strata with value/size (1 (27))
>>>> > depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
>>>> see http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/07/examples_full_next-tmp.log
>>>> I guess parmetis produces random partition on different machines (I made output file for ex56_1 on my imac). Please take a look at the differences. If the outputs are correct, I will remove option '-ex56_dm_view'
>>>> Hong
>>>> On Sun, Nov 5, 2017 at 9:03 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>> Mark:
>>>>> Bug is fixed in branch hzhang/fix-submat_samerowdist
>>>>> https://bitbucket.org/petsc/petsc/branch/hzhang/fix-submat_samerowdist
>>>>> I also add the test runex56. Please test it and let me know if there
>>>>> is a problem.
>>>>> Hong
>>>>> Also, I have been using -petscpartition_type but now I see
>>>>>> -pc_gamg_mat_partitioning_type. Is -petscpartition_type depreciated
>>>>>> for GAMG?
>>>>>> Is this some sort of auto generated portmanteau? I can not find
>>>>>> pc_gamg_mat_partitioning_type in the source.
>>>>>> On Thu, Nov 2, 2017 at 6:44 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> Great, thanks,
>>>>>>> And could you please add these parameters to a regression test? As I
>>>>>>> recall we have with-parmetis regression test.
>>>>>>> On Thu, Nov 2, 2017 at 6:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>> Mark:
>>>>>>>> I used petsc/src/ksp/ksp/examples/tutorials/ex56.c :-(
>>>>>>>> Now testing src/snes/examples/tutorials/ex56.c with your options,
>>>>>>>> I can reproduce the error.
>>>>>>>> I'll fix it.
>>>>>>>> Hong
>>>>>>>> Hong,
>>>>>>>>> I've tested with master and I get the same error. Maybe the
>>>>>>>>> partitioning parameters are wrong. -pc_gamg_mat_partitioning_type is new to
>>>>>>>>> me.
>>>>>>>>> Can you run this (snes ex56) w/o the error?
>>>>>>>>> 17:33 *master* *= ~*/Codes/petsc/src/snes/examples/tutorials*$
>>>>>>>>> make runex
>>>>>>>>> /Users/markadams/Codes/petsc/arch-macosx-gnu-g/bin/mpiexec -n 4
>>>>>>>>> ./ex56 -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2
>>>>>>>>> -ksp_max_it 100 -ksp_type cg -ksp_rtol 1.e-11 -ksp_norm_type
>>>>>>>>> unpreconditioned -snes_rtol 1.e-10 -pc_type gamg -pc_gamg_type agg
>>>>>>>>> -pc_gamg_agg_nsmooths 1 -pc_gamg_coarse_eq_limit 10
>>>>>>>>> -pc_gamg_reuse_interpolation true -pc_gamg_square_graph 1
>>>>>>>>> -pc_gamg_threshold 0.05 -pc_gamg_threshold_scale .0 -ksp_converged_reason
>>>>>>>>> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
>>>>>>>>> -use_mat_nearnullspace true -mg_levels_ksp_max_it 1 -mg_levels_ksp_type
>>>>>>>>> chebyshev -mg_levels_esteig_ksp_type cg -mg_levels_esteig_ksp_max_it 10
>>>>>>>>> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05 -mg_levels_pc_type
>>>>>>>>> jacobi -pc_gamg_mat_partitioning_type parmetis -mat_block_size 3 -matrap 0
>>>>>>>>> -matptap_scalable -ex56_dm_view -run_type 1 -pc_gamg_repartition true
>>>>>>>>> [0] 27 global equations, 9 vertices
>>>>>>>>> [0] 27 equations in vector, 9 vertices
>>>>>>>>> 0 SNES Function norm 122.396
>>>>>>>>> 0 KSP Residual norm 122.396
>>>>>>>>> <snip>
>>>>>>>>> depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3 (8))
>>>>>>>>> [0] 4725 global equations, 1575 vertices
>>>>>>>>> [0] 4725 equations in vector, 1575 vertices
>>>>>>>>> 0 SNES Function norm 17.9091
>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object type
>>>>>>>>> [0]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>>>>> On Thu, Nov 2, 2017 at 1:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>>>>>>>>> Mark :
>>>>>>>>>> I realize that using maint or master branch, I cannot reproduce
>>>>>>>>>> the same error.
>>>>>>>>>> For this example, you must use a parallel partitioner,
>>>>>>>>>> e.g.,'current' gives me following error:
>>>>>>>>>> [0]PETSC ERROR: This is the DEFAULT NO-OP partitioner, it
>>>>>>>>>> currently only supports one domain per processor
>>>>>>>>>> use -pc_gamg_mat_partitioning_type parmetis or chaco or ptscotch
>>>>>>>>>> for more than one subdomain per processor
>>>>>>>>>> Please rebase your branch with maint or master, then see if you
>>>>>>>>>> still have problem.
>>>>>>>>>> Hong
>>>>>>>>>>> On Thu, Nov 2, 2017 at 11:07 AM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Mark,
>>>>>>>>>>>> I can reproduce this in an old branch, but not in current maint
>>>>>>>>>>>> and master.
>>>>>>>>>>>> Which branch are you using to produce this error?
>>>>>>>>>>> I am using a branch from Matt. Let me try to merge it with
>>>>>>>>>>> master.
>>>>>>>>>>>> Hong
>>>>>>>>>>>> On Thu, Nov 2, 2017 at 9:28 AM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> I am able to reproduce this with snes ex56 with 2 processors
>>>>>>>>>>>>> and adding -pc_gamg_repartition true
>>>>>>>>>>>>> I'm not sure how to fix it.
>>>>>>>>>>>>> 10:26 1 knepley/feature-plex-boxmesh-create *=
>>>>>>>>>>>>> ~/Codes/petsc/src/snes/examples/tutorials$ make
>>>>>>>>>>>>> PETSC_DIR=/Users/markadams/Codes/petsc
>>>>>>>>>>>>> PETSC_ARCH=arch-macosx-gnu-g runex
>>>>>>>>>>>>> 2 ./ex56 -cells 2,2,1 -max_conv_its 3 -petscspace_order 2 -snes_max_it 2
>>>>>>>>>>>>> -mg_levels_pc_type jacobi -petscpartitioner_type simple -mat_block_size 3
>>>>>>>>>>>>> -matrap 0 -matptap_scalable -ex56_dm_view -run_type 1 -pc_gamg_repartition
>>>>>>>>>>>>> true
>>>>>>>>>>>>> 1 KSP Residual norm 20.4696
>>>>>>>>>>>>> 2 KSP Residual norm 3.95009
>>>>>>>>>>>>> 3 KSP Residual norm 0.176181
>>>>>>>>>>>>> 4 KSP Residual norm 0.0208781
>>>>>>>>>>>>> 5 KSP Residual norm 0.00278873
>>>>>>>>>>>>> 6 KSP Residual norm 0.000482741
>>>>>>>>>>>>> 7 KSP Residual norm 4.68085e-05
>>>>>>>>>>>>> 8 KSP Residual norm 5.42381e-06
>>>>>>>>>>>>> 9 KSP Residual norm 5.12785e-07
>>>>>>>>>>>>> 10 KSP Residual norm 2.60389e-08
>>>>>>>>>>>>> 11 KSP Residual norm 4.96201e-09
>>>>>>>>>>>>> 12 KSP Residual norm 1.989e-10
>>>>>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 12
>>>>>>>>>>>>> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
>>>>>>>>>>>>> iterations 1
>>>>>>>>>>>>> DM Object: Mesh (ex56_) 2 MPI processes
>>>>>>>>>>>>> type: plex
>>>>>>>>>>>>> Mesh in 3 dimensions:
>>>>>>>>>>>>> 0-cells: 12 12
>>>>>>>>>>>>> 1-cells: 20 20
>>>>>>>>>>>>> 2-cells: 11 11
>>>>>>>>>>>>> 3-cells: 2 2
>>>>>>>>>>>>> Labels:
>>>>>>>>>>>>> Face Sets: 5 strata with value/size (1 (2), 2 (2), 3 (2), 5
>>>>>>>>>>>>> (1), 6 (1))
>>>>>>>>>>>>> (2))
>>>>>>>>>>>>> [0] 441 global equations, 147 vertices
>>>>>>>>>>>>> [0] 441 equations in vector, 147 vertices
>>>>>>>>>>>>> 0 SNES Function norm 49.7106
>>>>>>>>>>>>> 0 KSP Residual norm 49.7106
>>>>>>>>>>>>> 1 KSP Residual norm 12.9252
>>>>>>>>>>>>> 2 KSP Residual norm 2.38019
>>>>>>>>>>>>> 3 KSP Residual norm 0.426307
>>>>>>>>>>>>> 4 KSP Residual norm 0.0692155
>>>>>>>>>>>>> 5 KSP Residual norm 0.0123092
>>>>>>>>>>>>> 6 KSP Residual norm 0.00184874
>>>>>>>>>>>>> 7 KSP Residual norm 0.000320761
>>>>>>>>>>>>> 8 KSP Residual norm 5.48957e-05
>>>>>>>>>>>>> 9 KSP Residual norm 9.90089e-06
>>>>>>>>>>>>> 10 KSP Residual norm 1.5127e-06
>>>>>>>>>>>>> 11 KSP Residual norm 2.82192e-07
>>>>>>>>>>>>> 12 KSP Residual norm 4.62364e-08
>>>>>>>>>>>>> 13 KSP Residual norm 7.99573e-09
>>>>>>>>>>>>> 14 KSP Residual norm 1.3028e-09
>>>>>>>>>>>>> 15 KSP Residual norm 2.174e-10
>>>>>>>>>>>>> Linear solve converged due to CONVERGED_RTOL iterations 15
>>>>>>>>>>>>> 1 SNES Function norm 2.174e-10
>>>>>>>>>>>>> iterations 1
>>>>>>>>>>>>> type: plex
>>>>>>>>>>>>> 0-cells: 45 45
>>>>>>>>>>>>> 1-cells: 96 96
>>>>>>>>>>>>> 2-cells: 68 68
>>>>>>>>>>>>> 3-cells: 16 16
>>>>>>>>>>>>> Labels:
>>>>>>>>>>>>> marker: 1 strata with value/size (1 (129))
>>>>>>>>>>>>> Face Sets: 5 strata with value/size (1 (18), 2 (18), 3 (18),
>>>>>>>>>>>>> 5 (9), 6 (9))
>>>>>>>>>>>>> boundary: 1 strata with value/size (1 (141))
>>>>>>>>>>>>> depth: 4 strata with value/size (0 (45), 1 (96), 2 (68), 3
>>>>>>>>>>>>> (16))
>>>>>>>>>>>>> type
>>>>>>>>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>> [1]PETSC ERROR: No support for this operation for this object
>>>>>>>>>>>>> type
>>>>>>>>>>>>> [1]PETSC ERROR: unsorted iscol_local is not implemented yet
>>>>>>>>>>>>> On Thu, Nov 2, 2017 at 9:51 AM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> On Wed, Nov 1, 2017 at 9:36 PM, Randy Michael Churchill <
>>>>>>>>>>>>>> rchurchi at pppl.gov> wrote:
>>>>>>>>>>>>>>> Doing some additional testing, the issue goes away when
>>>>>>>>>>>>>>> removing the gamg preconditioner line from the petsc.rc:
>>>>>>>>>>>>>>> -pc_type gamg
>>>>>>>>>>>>>> Yea, this is GAMG setup.
>>>>>>>>>>>>>> This is the code. findices is create with ISCreateStride, so
>>>>>>>>>>>>>> it is sorted ...
>>>>>>>>>>>>>> Michael is repartitioning the coarse grids. Maybe we don't
>>>>>>>>>>>>>> have a regression test with this...
>>>>>>>>>>>>>> I will try to reproduce this.
>>>>>>>>>>>>>> Michael: you can use hypre for now, or turn repartitioning
>>>>>>>>>>>>>> off (eg, -fsa_fieldsplit_lambda_upper_pc_gamg_repartition
>>>>>>>>>>>>>> false), but I'm not sure this will fix this.
>>>>>>>>>>>>>> You don't have hypre parameters for all of your all of your
>>>>>>>>>>>>>> solvers. I think 'boomeramg' is the default pc_hypre_type. That should be
>>>>>>>>>>>>>> good enough for you.
>>>>>>>>>>>>>> IS findices;
>>>>>>>>>>>>>> PetscInt Istart,Iend;
>>>>>>>>>>>>>> Mat Pnew;
>>>>>>>>>>>>>> ierr = MatGetOwnershipRange(Pold, &Istart,
>>>>>>>>>>>>>> &Iend);CHKERRQ(ierr);
>>>>>>>>>>>>>> #if defined PETSC_GAMG_USE_LOG
>>>>>>>>>>>>>> ierr = PetscLogEventBegin(petsc_gamg_
>>>>>>>>>>>>>> setup_events[SET15],0,0,0,0);CHKERRQ(ierr);
>>>>>>>>>>>>>> #endif
>>>>>>>>>>>>>> ierr = ISCreateStride(comm,Iend-Istar
>>>>>>>>>>>>>> t,Istart,1,&findices);CHKERRQ(ierr);
>>>>>>>>>>>>>> ierr = ISSetBlockSize(findices,f_bs);CHKERRQ(ierr);
>>>>>>>>>>>>>> ierr = MatCreateSubMatrix(Pold, findices,
>>>>>>>>>>>>>> new_eq_indices, MAT_INITIAL_MATRIX, &Pnew);CHKERRQ(ierr);
>>>>>>>>>>>>>> ierr = ISDestroy(&findices);CHKERRQ(ierr);
>>>>>>>>>>>>>> ierr = PetscLogEventEnd(petsc_gamg_se
>>>>>>>>>>>>>> #endif
>>>>>>>>>>>>>> ierr = MatDestroy(a_P_inout);CHKERRQ(ierr);
>>>>>>>>>>>>>> /* output - repartitioned */
>>>>>>>>>>>>>> *a_P_inout = Pnew;
>>>>>>>>>>>>>>> On Wed, Nov 1, 2017 at 8:23 PM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>> Randy:
>>>>>>>>>>>>>>>> Thanks, I'll check it tomorrow.
>>>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>>>> OK, this might not be completely satisfactory, because it
>>>>>>>>>>>>>>>>> doesn't show the partitioning or how the matrix is created, but this
>>>>>>>>>>>>>>>>> reproduces the problem. I wrote out my matrix, Amat, from the larger
>>>>>>>>>>>>>>>>> simulation, and load it in this script. This must be run with MPI rank
>>>>>>>>>>>>>>>>> greater than 1. This may be some combination of my petsc.rc, because when I
>>>>>>>>>>>>>>>>> use the PetscInitialize with it, it throws the error, but when using
>>>>>>>>>>>>>>>>> default (PETSC_NULL_CHARACTER) it runs fine.
>>>>>>>>>>>>>>>>> On Tue, Oct 31, 2017 at 9:58 AM, Hong <hzhang at mcs.anl.gov>
>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>> Randy:
>>>>>>>>>>>>>>>>>> It could be a bug or a missing feature in our new
>>>>>>>>>>>>>>>>>> MatCreateSubMatrix_MPIAIJ_SameRowDist().
>>>>>>>>>>>>>>>>>> It would be helpful if you can provide us a simple
>>>>>>>>>>>>>>>>>> example that produces this example.
>>>>>>>>>>>>>>>>>> Hong
>>>>>>>>>>>>>>>>>> I'm running a Fortran code that was just changed over to
>>>>>>>>>>>>>>>>>>> using petsc 3.8 (previously petsc 3.7.6). An error was thrown during a
>>>>>>>>>>>>>>>>>>> KSPSetUp() call. The error is "unsorted iscol_local is not implemented yet"
>>>>>>>>>>>>>>>>>>> (see full error below). I tried to trace down the difference in the source
>>>>>>>>>>>>>>>>>>> files, but where the error occurs (MatCreateSubMatrix_MPIAIJ_SameRowDist())
>>>>>>>>>>>>>>>>>>> doesn't seem to have existed in v3.7.6, so I'm unsure how to compare. It
>>>>>>>>>>>>>>>>>>> seems the error is that the order of the columns locally are unsorted,
>>>>>>>>>>>>>>>>>>> though I don't think I specify a column order in the creation of the matrix:
>>>>>>>>>>>>>>>>>>> call MatCreate(this%comm,AA,ierr)
>>>>>>>>>>>>>>>>>>> call MatSetSizes(AA,npetscloc,npets
>>>>>>>>>>>>>>>>>>> cloc,nreal,nreal,ierr)
>>>>>>>>>>>>>>>>>>> call MatSetType(AA,MATAIJ,ierr)
>>>>>>>>>>>>>>>>>>> call MatSetup(AA,ierr)
>>>>>>>>>>>>>>>>>>> call MatGetOwnershipRange(AA,low,high,ierr)
>>>>>>>>>>>>>>>>>>> allocate(d_nnz(npetscloc),o_nnz(npetscloc))
>>>>>>>>>>>>>>>>>>> call getNNZ(grid,npetscloc,low,high
>>>>>>>>>>>>>>>>>>> ,d_nnz,o_nnz,this%xgc_petsc,nreal,ierr)
>>>>>>>>>>>>>>>>>>> call MatSeqAIJSetPreallocation(AA,P
>>>>>>>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,ierr)
>>>>>>>>>>>>>>>>>>> call MatMPIAIJSetPreallocation(AA,P
>>>>>>>>>>>>>>>>>>> ETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr)
>>>>>>>>>>>>>>>>>>> deallocate(d_nnz,o_nnz)
>>>>>>>>>>>>>>>>>>> call MatSetOption(AA,MAT_IGNORE_OFF
>>>>>>>>>>>>>>>>>>> _PROC_ENTRIES,PETSC_TRUE,ierr)
>>>>>>>>>>>>>>>>>>> call MatSetOption(AA,MAT_KEEP_NONZE
>>>>>>>>>>>>>>>>>>> RO_PATTERN,PETSC_TRUE,ierr)
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: No support for this operation for this
>>>>>>>>>>>>>>>>>>> object type
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: unsorted iscol_local is not implemented
>>>>>>>>>>>>>>>>>>> yet
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: Petsc Release Version 3.8.0,
>>>>>>>>>>>>>>>>>>> unknown[62]PETSC ERROR: #1 MatCreateSubMatrix_MPIAIJ_SameRowDist()
>>>>>>>>>>>>>>>>>>> line 3418 in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>>>>>>>> 8.0/src/mat/impls/aij/mpi/mpiaij.c
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #2 MatCreateSubMatrix_MPIAIJ() line
>>>>>>>>>>>>>>>>>>> 3247 in /global/u1/r/rchurchi/petsc/3.
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #3 MatCreateSubMatrix() line 7872 in
>>>>>>>>>>>>>>>>>>> /global/u1/r/rchurchi/petsc/3.8.0/src/mat/interface/matrix.c
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #4 PCGAMGCreateLevel_GAMG() line 383 in
>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #5 PCSetUp_GAMG() line 561 in
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #6 PCSetUp() line 924 in
>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>>>>>>>> [62]PETSC ERROR: #7 KSPSetUp() line 378 in
>>>>>>>>>>>>>>>>>>> 8.0/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>>>>>>>> R. Michael Churchill
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171108/232148b2/attachment-0001.html>
