[petsc-users] How to compute RARt with A and R as distributed (MPI) matrices ?
Jed Brown jed at jedbrown.org
Wed Jun 21 11:30:17 CDT 2017
It is only implemented for SeqAIJ, but it should arguably have a default
implementation that performs an explicit transpose and then calls
MatMatMatMult or MatPtAP.
Franck Houssen <franck.houssen at inria.fr> writes:
> I read the doc, and googled this before to write a dummy example. So, matRARt is only for sequential matrices, and, matPtAP for distributed ones : correct ? (means, I "just" used the "wrong" method)
> If so, this is a major difference which does not seem (to me) to be emphasized enough in the doc, in particular for a new user (the matRARt and matPtAP pages are the same with R replaced with Pt). Where was it possible to find this information ?
> Franck
> ----- Mail original -----
>> De: "Dave May" <dave.mayhem23 at gmail.com>
>> À: "Franck Houssen" <franck.houssen at inria.fr>, "PETSc users list"
>> <petsc-users at mcs.anl.gov>, "petsc-dev" <petsc-dev at mcs.anl.gov>
>> Envoyé: Mercredi 21 Juin 2017 15:11:27
>> Objet: Re: [petsc-users] How to compute RARt with A and R as distributed
>> (MPI) matrices ?
>> You can assemble R^t and then use MatPtAP which supports MPIAIJ
>> On Wed, 21 Jun 2017 at 15:00, Franck Houssen < franck.houssen at inria.fr >
>> > This works with sequential matrices.
>> > The doc say "currently only implemented for pairs of AIJ matrices and
>> > classes
>> > which inherit from AIJ": I supposed that MPIAIJ was someway inheriting from
>> > AIJ, seems that it doesn't.
>> > Is this kind of matrix product possible with distributed matrices in PETSc
>> > Or is this a known limitation ?
>> > Do I go the wrong way to do that (= should use another method) ? If yes,
>> > what
>> > is the correct one ?
>> > Franck
>> > PS: running debian/testing + gcc-6.3 + bitbucket petsc.
>> > >> mpirun -n 2 matRARt.exe seq
>> > Mat Object: 1 MPI processes
>> > type: seqaij
>> > row 0: (0, 1.) (1, 0.)
>> > row 1: (0, 0.) (1, 1.)
>> > >> mpirun -n 2 matRARt.exe mpi
>> > [0]PETSC ERROR: --------------------- Error Message
>> > [0]PETSC ERROR: No support for this operation for this object type
>> > [0]PETSC ERROR: Matrix of type <mpiaij> does not support RARt
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170621/8a292878/attachment.pgp>
