[petsc-users] How to compute RARt with A and R as distributed (MPI) matrices ?
Franck Houssen franck.houssen at inria.fr
Wed Jun 21 10:45:06 CDT 2017
I read the doc, and googled this before to write a dummy example. So, matRARt is only for sequential matrices, and, matPtAP for distributed ones : correct ? (means, I "just" used the "wrong" method)
If so, this is a major difference which does not seem (to me) to be emphasized enough in the doc, in particular for a new user (the matRARt and matPtAP pages are the same with R replaced with Pt). Where was it possible to find this information ?
Franck
----- Mail original -----
> De: "Dave May" <dave.mayhem23 at gmail.com>
> À: "Franck Houssen" <franck.houssen at inria.fr>, "PETSc users list"
> <petsc-users at mcs.anl.gov>, "petsc-dev" <petsc-dev at mcs.anl.gov>
> Envoyé: Mercredi 21 Juin 2017 15:11:27
> Objet: Re: [petsc-users] How to compute RARt with A and R as distributed
> (MPI) matrices ?
> You can assemble R^t and then use MatPtAP which supports MPIAIJ
> On Wed, 21 Jun 2017 at 15:00, Franck Houssen < franck.houssen at inria.fr >
> > This works with sequential matrices.
> > The doc say "currently only implemented for pairs of AIJ matrices and
> > classes
> > which inherit from AIJ": I supposed that MPIAIJ was someway inheriting from
> > AIJ, seems that it doesn't.
> > Is this kind of matrix product possible with distributed matrices in PETSc
> > Or is this a known limitation ?
> > Do I go the wrong way to do that (= should use another method) ? If yes,
> > what
> > is the correct one ?
> > Franck
> > PS: running debian/testing + gcc-6.3 + bitbucket petsc.
> > >> mpirun -n 2 matRARt.exe seq
> > Mat Object: 1 MPI processes
> > type: seqaij
> > row 0: (0, 1.) (1, 0.)
> > row 1: (0, 0.) (1, 1.)
> > >> mpirun -n 2 matRARt.exe mpi
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: No support for this operation for this object type
> > [0]PETSC ERROR: Matrix of type <mpiaij> does not support RARt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170621/754f313d/attachment-0001.html>
