[petsc-users] PETSC profiling on 1536 cores
    Pietro Incardona
    asmprog32 at hotmail.com
    Fri Jun 16 03:03:39 CDT 2017
Thanks for the answer. I am aware that Multi-grid overall improve the speed of the solver, on the other hand I do not understand why a multigrid preconditioner should help in understanding what I am doing wrong
Da: Justin Chang <jychang48 at gmail.com>
Inviato: giovedì 15 giugno 2017 23:15:04
A: Pietro Incardona; petsc-users at mcs.anl.gov
Oggetto: Re: [petsc-users] PETSC profiling on 1536 cores
Using no preconditioner is a bad bad idea and anyone with the gall to do this deserves to be spanked.
For the Poisson equation, why not use PETSc's native algebraic multigrid solver?
-pc_type gamg
On Thu, Jun 15, 2017 at 3:09 PM Pietro Incardona <asmprog32 at hotmail.com<mailto:asmprog32 at hotmail.com>> wrote:
Dear All
I tried PETSC version 3.6.5 to solve a linear system with 256 000 000 unknown. The equation is Finite differences Poisson equation.
I am using Conjugate gradient (the matrix is symmetric) with no preconditioner. Visualizing the solution is reasonable.
Unfortunately the Conjugate-Gradient does not scale at all and I am extremely concerned about this problem in paticular about the profiling numbers.
Looking at the profiler it seem that
1536 cores = 24 cores x 64
VecScatterBegin      348 1.0 2.3975e-01 1.8 0.00e+00 0.0 7.7e+06 3.1e+04 0.0e+00  0  0 85 99  0   0  0 85 99  0     0
VecScatterEnd        348 1.0 2.8680e+00 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMult              348 1.0 4.1088e+00 1.4 8.18e+08 1.3 7.7e+06 3.1e+04 0.0e+00  2 52 85 99  0   2 52 85 99  0 281866
I was expecting that this part was the most expensive and take around 4 second in total that sound reasonable
Unfortunately
on 1536 cores = 24 cores x 64
VecTDot              696 1.0 3.4442e+01 1.4 2.52e+08 1.3 0.0e+00 0.0e+00 7.0e+02 12 16  0  0 65  12 16  0  0 65 10346
VecNorm              349 1.0 1.1101e+02 1.1 1.26e+08 1.3 0.0e+00 0.0e+00 3.5e+02 46  8  0  0 33  46  8  0  0 33  1610
VecAXPY              696 1.0 8.3134e+01 1.1 2.52e+08 1.3 0.0e+00 0.0e+00 0.0e+00 34 16  0  0  0  34 16  0  0  0  4286
Take over 228 seconds. Considering that doing some test on the cluster I do not see any problem with MPI_Reduce I do not understand how these numbers are possible
////////////////////////// I also attach to the profiling part the inversion on 48 cores /////////////////////////
VecTDot              696 1.0 1.4684e+01 1.3 3.92e+09 1.1 0.0e+00 0.0e+00 7.0e+02  6 16  0  0 65   6 16  0  0 65 24269
VecNorm              349 1.0 4.9612e+01 1.3 1.96e+09 1.1 0.0e+00 0.0e+00 3.5e+02 22  8  0  0 33  22  8  0  0 33  3602
VecCopy              351 1.0 8.8359e+00 7.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
VecSet                 2 1.0 1.6177e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              696 1.0 8.8559e+01 1.1 3.92e+09 1.1 0.0e+00 0.0e+00 0.0e+00 42 16  0  0  0  42 16  0  0  0  4024
VecAYPX              347 1.0 4.6790e+00 1.2 1.95e+09 1.1 0.0e+00 0.0e+00 0.0e+00  2  8  0  0  0   2  8  0  0  0 37970
VecAssemblyBegin       2 1.0 5.0942e-02 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd         2 1.0 1.9073e-05 6.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin      348 1.0 1.2763e+00 1.5 0.00e+00 0.0 4.6e+05 2.0e+05 0.0e+00  0  0 97100  0   0  0 97100  0     0
VecScatterEnd        348 1.0 4.6741e+00 5.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMult              348 1.0 2.8440e+01 1.1 1.27e+10 1.1 4.6e+05 2.0e+05 0.0e+00 13 52 97100  0  13 52 97100  0 40722
MatAssemblyBegin       1 1.0 7.4749e-0124.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         1 1.0 8.3194e-01 1.0 0.00e+00 0.0 2.7e+03 5.1e+04 8.0e+00  0  0  1  0  1   0  0  1  0  1     0
KSPSetUp               1 1.0 8.2883e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.7964e+02 1.0 2.45e+10 1.1 4.6e+05 2.0e+05 1.0e+03 87100 97100 98  87100 97100 98 12398
PCSetUp                1 1.0 1.1921e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply              349 1.0 8.8166e+00 7.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
If you need more information or test please let me know.
Thanks in advance
Here the log of 1536 cores
345 KSP Residual norm 1.007085286893e-02
346 KSP Residual norm 1.010054402040e-02
347 KSP Residual norm 1.002139574355e-02
348 KSP Residual norm 9.775851299055e-03
Max div for vorticity 1.84572e-05   Integral: 6.62466e-09  130.764   -132
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./vic_petsc on a arch-linux2-c-opt named taurusi6217 with 1536 processors, by incard Thu Jun 15 22:27:09 2017
Using Petsc Release Version 3.6.4, Apr, 12, 2016
                         Max       Max/Min        Avg      Total
Time (sec):           2.312e+02      1.00027   2.312e+02
Objects:              1.900e+01      1.00000   1.900e+01
Flops:                1.573e+09      1.32212   1.450e+09  2.227e+12
Flops/sec:            6.804e+06      1.32242   6.271e+06  9.633e+09
MPI Messages:         8.202e+03      2.06821   5.871e+03  9.018e+06
MPI Message Lengths:  2.013e+08      1.86665   2.640e+04  2.381e+11
MPI Reductions:       1.066e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 2.3120e+02 100.0%  2.2272e+12 100.0%  9.018e+06 100.0%  2.640e+04      100.0%  1.065e+03  99.9%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecCopy              351 1.0 2.7609e-01 5.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                 2 1.0 3.8961e-0256.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAYPX              347 1.0 2.0852e-01 2.0 1.25e+08 1.3 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   0  8  0  0  0 852044
VecAssemblyBegin       2 1.0 8.3237e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
VecAssemblyEnd         2 1.0 5.1022e-0517.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       1 1.0 9.1920e-02 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         1 1.0 3.9093e+00 1.0 0.00e+00 0.0 4.4e+04 7.7e+03 8.0e+00  2  0  0  0  1   2  0  0  0  1     0
KSPSetUp               1 1.0 8.1890e-03 4.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 2.1525e+02 1.0 1.57e+09 1.3 7.7e+06 3.1e+04 1.0e+03 93100 85 99 98  93100 85 99 98 10347
PCSetUp                1 1.0 5.5075e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply              349 1.0 2.7485e-01 6.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    10              7      7599552     0
      Vector Scatter     1              1         1088     0
              Matrix     3              3     20858912     0
       Krylov Solver     1              1         1216     0
           Index Set     2              2       242288     0
      Preconditioner     1              1          816     0
              Viewer     1              0            0     0
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 3.68118e-05
Average time for zero size MPI_Send(): 3.24349e-06
#PETSc Option Table entries:
-ksp_atol 0.010000
-ksp_max_it 500
-ksp_monitor
-ksp_type cg
-log_summary
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-cxx-dialect=C++11 --with-mpi-dir=/sw/taurus/libraries/openmpi/1.10.2-gnu --with-parmetis=yes --with-parmetis-dir=/scratch/p_ppm//PARMETIS/ --with-metis=yes --with-metis-dir=/scratch/p_ppm//METIS --with-boost=yes --with-boost-dir=/scratch/p_ppm//BOOST --with-blas-lib=/scratch/p_ppm//OPENBLAS/lib/libopenblas.a --with-lapack-lib=/scratch/p_ppm//OPENBLAS/lib/libopenblas.a --with-suitesparse=yes --with-suitesparse-dir=/scratch/p_ppm//SUITESPARSE --with-trilinos=yes -with-trilinos-dir=/scratch/p_ppm//TRILINOS --with-scalapack=yes -with-scalapack-dir=/scratch/p_ppm//SCALAPACK --with-mumps=yes --with-mumps-include=/scratch/p_ppm//MUMPS/include --with-superlu_dist=yes --with-superlu_dist-lib=/scratch/p_ppm//SUPERLU_DIST/lib/libsuperlu_dist_4.3.a --with-superlu_dist-include=/scratch/p_ppm//SUPERLU_DIST/include/ --with-hypre=yes -with-hypre-dir=/scratch/p_ppm//HYPRE --with-mumps-lib=""/scratch/p_ppm//MUMPS/lib/libdmumps.a /scratch/p_ppm//MUMPS/lib/libmumps_common.a /scratch/p_ppm//MUMPS/lib/libpord.a"" --prefix=/scratch/p_ppm//PETSC --with-debugging=0
Libraries compiled on Wed Feb 22 17:30:49 2017 on tauruslogin4
Machine characteristics: Linux-2.6.32-642.11.1.el6.Bull.106.x86_64-x86_64-with-redhat-6.8-Santiago
Using PETSc directory: /lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4
Using PETSc arch: arch-linux2-c-opt
Using C compiler: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpicc  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/include -I/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/include -I/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/include -I/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/include -I/scratch/p_ppm/TRILINOS/include -I/scratch/p_ppm/HYPRE/include -I/scratch/p_ppm/SUPERLU_DIST/include -I/scratch/p_ppm/SUITESPARSE/include -I/scratch/p_ppm/MUMPS/include -I/scratch/p_ppm/PARMETIS/include -I/scratch/p_ppm/METIS/include -I/scratch/p_ppm/BOOST/include -I/sw/taurus/libraries/openmpi/1.10.2-gnu/include
Using C linker: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpicc
Using Fortran linker: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpif90
Using libraries: -Wl,-rpath,/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/lib -L/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/scratch/p_ppm/TRILINOS/lib -L/scratch/p_ppm/TRILINOS/lib -lpike-blackbox -ltrilinoscouplings -lmsqutil -lmesquite -lctrilinos -lsundancePdeopt -lsundanceStdFwk -lsundanceStdMesh -lsundanceCore -lsundanceInterop -lsundanceUtils -lsundancePlaya -lpiro -lrol -lstokhos_muelu -lstokhos_ifpack2 -lstokhos_amesos2 -lstokhos_tpetra -lstokhos_sacado -lstokhos -lmoochothyra -lmoocho -lrythmos -lmuelu-adapters -lmuelu-interface -lmuelu -lmoertel -llocathyra -llocaepetra -llocalapack -lloca -lnoxepetra -lnoxlapack -lnox -lphalanx -lstk_mesh_fixtures -lstk_search_util_base -lstk_search -lstk_unit_test_utils -lstk_io_util -lstk_io -lstk_mesh_base -lstk_topology -lstk_util_use_cases -lstk_util_registry -lstk_util_diag -lstk_util_env -lstk_util_util -lstkclassic_search_util -lstkclassic_search -lstkclassic_rebalance_utils -lstkclassic_rebalance -lstkclassic_linsys -lstkclassic_io_util -lstkclassic_io -lstkclassic_expreval -lstkclassic_algsup -lstkclassic_mesh_fem -lstkclassic_mesh_base -lstkclassic_util_use_cases -lstkclassic_util_unit_test_support -lstkclassic_util_parallel -lstkclassic_util_diag -lstkclassic_util_env -lstkclassic_util_util -lstk_mesh_fixtures -lstk_search_util_base -lstk_search -lstk_unit_test_utils -lstk_io_util -lstk_io -lstk_mesh_base -lstk_topology -lstk_util_use_cases -lstk_util_registry -lstk_util_diag -lstk_util_env -lstk_util_util -lstkclassic_search_util -lstkclassic_search -lstkclassic_rebalance_utils -lstkclassic_rebalance -lstkclassic_linsys -lstkclassic_io_util -lstkclassic_io -lstkclassic_expreval -lstkclassic_algsup -lstkclassic_mesh_fem -lstkclassic_mesh_base -lstkclassic_util_use_cases -lstkclassic_util_unit_test_support -lstkclassic_util_parallel -lstkclassic_util_diag -lstkclassic_util_env -lstkclassic_util_util -lintrepid -lteko -lfei_trilinos -lfei_base -lstratimikos -lstratimikosbelos -lstratimikosaztecoo -lstratimikosamesos -lstratimikosml -lstratimikosifpack -lifpack2-adapters -lifpack2 -lanasazitpetra -lModeLaplace -lanasaziepetra -lanasazi -lkomplex -lsupes -laprepro_lib -lchaco -lIonit -lIotr -lIohb -lIogn -lIopg -lIoss -lsupes -laprepro_lib -lchaco -lIonit -lIotr -lIohb -lIogn -lIopg -lIoss -lamesos2 -lshylu -lbelostpetra -lbelosepetra -lbelos -lml -lifpack -lzoltan2 -lpamgen_extras -lpamgen -lamesos -lgaleri-xpetra -lgaleri-epetra -laztecoo -ldpliris -lisorropia -loptipack -lxpetra-sup -lxpetra -lthyratpetra -lthyraepetraext -lthyraepetra -lthyracore -lthyratpetra -lthyraepetraext -lthyraepetra -lthyracore -lepetraext -ltpetraext -ltpetrainout -ltpetra -lkokkostsqr -ltpetrakernels -ltpetraclassiclinalg -ltpetraclassicnodeapi -ltpetraclassic -ltpetraext -ltpetrainout -ltpetra -lkokkostsqr -ltpetrakernels -ltpetraclassiclinalg -ltpetraclassicnodeapi -ltpetraclassic -ltriutils -lglobipack -lshards -lzoltan -lepetra -lsacado -lrtop -lteuchoskokkoscomm -lteuchoskokkoscompat -lteuchosremainder -lteuchosnumerics -lteuchoscomm -lteuchosparameterlist -lteuchoscore -lteuchoskokkoscomm -lteuchoskokkoscompat -lteuchosremainder -lteuchosnumerics -lteuchoscomm -lteuchosparameterlist -lteuchoscore -lkokkosalgorithms -lkokkoscontainers -lkokkoscore -lkokkosalgorithms -lkokkoscontainers -lkokkoscore -ltpi -lgtest -lpthread -Wl,-rpath,/scratch/p_ppm/HYPRE/lib -L/scratch/p_ppm/HYPRE/lib -lHYPRE -Wl,-rpath,/sw/taurus/libraries/openmpi/1.10.2-gnu/lib -L/sw/taurus/libraries/openmpi/1.10.2-gnu/lib -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib64 -L/sw/global/compilers/gcc/5.3.0/lib64 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0 -L/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0 -L/sw/global/compilers/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib -L/sw/global/compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib -L/sw/global/compilers/gcc/5.3.0/lib -lmpi_cxx -lstdc++ -Wl,-rpath,/scratch/p_ppm//SUPERLU_DIST/lib -L/scratch/p_ppm//SUPERLU_DIST/lib -lsuperlu_dist_4.3 -Wl,-rpath,/scratch/p_ppm/SUITESPARSE/lib -L/scratch/p_ppm/SUITESPARSE/lib -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lrt -ldmumps -Wl,-rpath,/scratch/p_ppm//MUMPS/lib -L/scratch/p_ppm//MUMPS/lib -lmumps_common -lpord -Wl,-rpath,/scratch/p_ppm/SCALAPACK/lib -L/scratch/p_ppm/SCALAPACK/lib -lscalapack -Wl,-rpath,/scratch/p_ppm//OPENBLAS/lib -L/scratch/p_ppm//OPENBLAS/lib -lopenblas -Wl,-rpath,/scratch/p_ppm/PARMETIS/lib -L/scratch/p_ppm/PARMETIS/lib -lparmetis -Wl,-rpath,/scratch/p_ppm/METIS/lib -L/scratch/p_ppm/METIS/lib -lmetis -lX11 -lhwloc -lssl -lcrypto -lm -lmpi_usempi -lmpi_mpifh -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -Wl,-rpath,/sw/taurus/libraries/openmpi/1.10.2-gnu/lib -L/sw/taurus/libraries/openmpi/1.10.2-gnu/lib -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib64 -L/sw/global/compilers/gcc/5.3.0/lib64 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0 -L/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib64 -L/sw/global/compilers/gcc/5.3.0/lib64 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib64 -L/sw/global/compilers/gcc/5.3.0/lib64 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0 -L/sw/global/compilers/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0 -L/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0 -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib -L/sw/global/compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib -L/sw/global/compilers/gcc/5.3.0/lib -ldl -Wl,-rpath,/sw/taurus/libraries/openmpi/1.10.2-gnu/lib -lmpi -lgcc_s -lpthread -ldl
Regards
Pietro Incardona
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170616/2694b2cb/attachment-0001.html>
