[petsc-users] PETSC profiling on 1536 cores
Justin Chang jychang48 at gmail.com
Thu Jun 15 16:15:04 CDT 2017
Using no preconditioner is a bad bad idea and anyone with the gall to do
this deserves to be spanked.
For the Poisson equation, why not use PETSc's native algebraic multigrid
solver?
-pc_type gamg
On Thu, Jun 15, 2017 at 3:09 PM Pietro Incardona <asmprog32 at hotmail.com>
wrote:
> Dear All
> I tried PETSC version 3.6.5 to solve a linear system with 256 000 000
> unknown. The equation is Finite differences Poisson equation.
> I am using Conjugate gradient (the matrix is symmetric) with no
> preconditioner. Visualizing the solution is reasonable.
> Unfortunately the Conjugate-Gradient does not scale at all and I am
> extremely concerned about this problem in paticular about the profiling
> numbers.
> Looking at the profiler it seem that
> 1536 cores = 24 cores x 64
> VecScatterBegin      348 1.0 2.3975e-01 1.8 0.00e+00 0.0 7.7e+06 3.1e+04
> 0.0e+00  0  0 85 99  0   0  0 85 99  0     0
> VecScatterEnd        348 1.0 2.8680e+00 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> MatMult              348 1.0 4.1088e+00 1.4 8.18e+08 1.3 7.7e+06 3.1e+04
> 0.0e+00  2 52 85 99  0   2 52 85 99  0 281866
> I was expecting that this part was the most expensive and take around 4
> second in total that sound reasonable
> Unfortunately
> on 1536 cores = 24 cores x 64
> VecTDot              696 1.0 3.4442e+01 1.4 2.52e+08 1.3 0.0e+00 0.0e+00
> 7.0e+02 12 16  0  0 65  12 16  0  0 65 10346
> VecNorm              349 1.0 1.1101e+02 1.1 1.26e+08 1.3 0.0e+00 0.0e+00
> 3.5e+02 46  8  0  0 33  46  8  0  0 33  1610
> VecAXPY              696 1.0 8.3134e+01 1.1 2.52e+08 1.3 0.0e+00 0.0e+00
> 0.0e+00 34 16  0  0  0  34 16  0  0  0  4286
> Take over 228 seconds. Considering that doing some test on the cluster I
> do not see any problem with MPI_Reduce I do not understand how these
> numbers are possible
> ////////////////////////// I also attach to the profiling part the
> inversion on 48 cores /////////////////////////
> VecTDot              696 1.0 1.4684e+01 1.3 3.92e+09 1.1 0.0e+00 0.0e+00
> 7.0e+02  6 16  0  0 65   6 16  0  0 65 24269
> VecNorm              349 1.0 4.9612e+01 1.3 1.96e+09 1.1 0.0e+00 0.0e+00
> 3.5e+02 22  8  0  0 33  22  8  0  0 33  3602
> VecCopy              351 1.0 8.8359e+00 7.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
> VecSet                 2 1.0 1.6177e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecAXPY              696 1.0 8.8559e+01 1.1 3.92e+09 1.1 0.0e+00 0.0e+00
> 0.0e+00 42 16  0  0  0  42 16  0  0  0  4024
> VecAYPX              347 1.0 4.6790e+00 1.2 1.95e+09 1.1 0.0e+00 0.0e+00
> 0.0e+00  2  8  0  0  0   2  8  0  0  0 37970
> VecAssemblyBegin       2 1.0 5.0942e-02 2.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00  0  0  0  0  1   0  0  0  0  1     0
> VecAssemblyEnd         2 1.0 1.9073e-05 6.7 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin      348 1.0 1.2763e+00 1.5 0.00e+00 0.0 4.6e+05 2.0e+05
> 0.0e+00  0  0 97100  0   0  0 97100  0     0
> VecScatterEnd        348 1.0 4.6741e+00 5.6 0.00e+00 0.0 0.0e+00 0.0e+00
> MatMult              348 1.0 2.8440e+01 1.1 1.27e+10 1.1 4.6e+05 2.0e+05
> 0.0e+00 13 52 97100  0  13 52 97100  0 40722
> MatAssemblyBegin       1 1.0 7.4749e-0124.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
> MatAssemblyEnd         1 1.0 8.3194e-01 1.0 0.00e+00 0.0 2.7e+03 5.1e+04
> 8.0e+00  0  0  1  0  1   0  0  1  0  1     0
> KSPSetUp               1 1.0 8.2883e-02 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve               1 1.0 1.7964e+02 1.0 2.45e+10 1.1 4.6e+05 2.0e+05
> 1.0e+03 87100 97100 98  87100 97100 98 12398
> PCSetUp                1 1.0 1.1921e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCApply              349 1.0 8.8166e+00 7.8 0.00e+00 0.0 0.0e+00 0.0e+00
> If you need more information or test please let me know.
> Thanks in advance
> Here the log of 1536 cores
> 345 KSP Residual norm 1.007085286893e-02
> 346 KSP Residual norm 1.010054402040e-02
> 347 KSP Residual norm 1.002139574355e-02
> 348 KSP Residual norm 9.775851299055e-03
> Max div for vorticity 1.84572e-05   Integral: 6.62466e-09  130.764   -132
> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
> -fCourier9' to print this document            ***
> ---------------------------------------------- PETSc Performance Summary:
> ./vic_petsc on a arch-linux2-c-opt named taurusi6217 with 1536 processors,
> by incard Thu Jun 15 22:27:09 2017
> Using Petsc Release Version 3.6.4, Apr, 12, 2016
>                          Max       Max/Min        Avg      Total
> Time (sec):           2.312e+02      1.00027   2.312e+02
> Objects:              1.900e+01      1.00000   1.900e+01
> Flops:                1.573e+09      1.32212   1.450e+09  2.227e+12
> Flops/sec:            6.804e+06      1.32242   6.271e+06  9.633e+09
> MPI Messages:         8.202e+03      2.06821   5.871e+03  9.018e+06
> MPI Message Lengths:  2.013e+08      1.86665   2.640e+04  2.381e+11
> MPI Reductions:       1.066e+03      1.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of length N
> --> 2N flops
>                             and VecAXPY() for complex vectors of length N
> --> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total   counts
> %Total     Avg         %Total   counts   %Total
>  0:      Main Stage: 2.3120e+02 100.0%  2.2272e+12 100.0%  9.018e+06
> 100.0%  2.640e+04      100.0%  1.065e+03  99.9%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
>    Count: number of times phase was executed
>    Time and Flops: Max - maximum over all processors
>                    Ratio - ratio of maximum to minimum over all processors
>    Mess: number of messages sent
>    Avg. len: average message length (bytes)
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
>       %T - percent time in this phase         %F - percent flops in this
> phase
>       %M - percent messages in this phase     %L - percent message lengths
> in this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
> Event                Count      Time (sec)
> Flops                             --- Global ---  --- Stage ---   Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> VecCopy              351 1.0 2.7609e-01 5.8 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet                 2 1.0 3.8961e-0256.9 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAYPX              347 1.0 2.0852e-01 2.0 1.25e+08 1.3 0.0e+00 0.0e+00
> 0.0e+00  0  8  0  0  0   0  8  0  0  0 852044
> VecAssemblyBegin       2 1.0 8.3237e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd         2 1.0 5.1022e-0517.8 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyBegin       1 1.0 9.1920e-02 3.4 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd         1 1.0 3.9093e+00 1.0 0.00e+00 0.0 4.4e+04 7.7e+03
> 8.0e+00  2  0  0  0  1   2  0  0  0  1     0
> KSPSetUp               1 1.0 8.1890e-03 4.3 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve               1 1.0 2.1525e+02 1.0 1.57e+09 1.3 7.7e+06 3.1e+04
> 1.0e+03 93100 85 99 98  93100 85 99 98 10347
> PCSetUp                1 1.0 5.5075e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCApply              349 1.0 2.7485e-01 6.0 0.00e+00 0.0 0.0e+00 0.0e+00
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
>               Vector    10              7      7599552     0
>       Vector Scatter     1              1         1088     0
>               Matrix     3              3     20858912     0
>        Krylov Solver     1              1         1216     0
>            Index Set     2              2       242288     0
>       Preconditioner     1              1          816     0
>               Viewer     1              0            0     0
> Average time to get PetscTime(): 9.53674e-08
> Average time for MPI_Barrier(): 3.68118e-05
> Average time for zero size MPI_Send(): 3.24349e-06
> #PETSc Option Table entries:
> -ksp_atol 0.010000
> -ksp_max_it 500
> -ksp_monitor
> -ksp_type cg
> -log_summary
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: --with-cxx-dialect=C++11
> --with-mpi-dir=/sw/taurus/libraries/openmpi/1.10.2-gnu --with-parmetis=yes
> --with-parmetis-dir=/scratch/p_ppm//PARMETIS/ --with-metis=yes
> --with-metis-dir=/scratch/p_ppm//METIS --with-boost=yes
> --with-boost-dir=/scratch/p_ppm//BOOST
> --with-blas-lib=/scratch/p_ppm//OPENBLAS/lib/libopenblas.a
> --with-lapack-lib=/scratch/p_ppm//OPENBLAS/lib/libopenblas.a
> --with-suitesparse=yes --with-suitesparse-dir=/scratch/p_ppm//SUITESPARSE
> --with-trilinos=yes -with-trilinos-dir=/scratch/p_ppm//TRILINOS
> --with-scalapack=yes -with-scalapack-dir=/scratch/p_ppm//SCALAPACK
> --with-mumps=yes --with-mumps-include=/scratch/p_ppm//MUMPS/include
> --with-superlu_dist=yes
> --with-superlu_dist-lib=/scratch/p_ppm//SUPERLU_DIST/lib/libsuperlu_dist_4.3.a
> --with-superlu_dist-include=/scratch/p_ppm//SUPERLU_DIST/include/
> --with-hypre=yes -with-hypre-dir=/scratch/p_ppm//HYPRE
> --with-mumps-lib=""/scratch/p_ppm//MUMPS/lib/libdmumps.a
> /scratch/p_ppm//MUMPS/lib/libmumps_common.a
> /scratch/p_ppm//MUMPS/lib/libpord.a"" --prefix=/scratch/p_ppm//PETSC
> --with-debugging=0
> Libraries compiled on Wed Feb 22 17:30:49 2017 on tauruslogin4
> Machine characteristics:
> Linux-2.6.32-642.11.1.el6.Bull.106.x86_64-x86_64-with-redhat-6.8-Santiago
> Using PETSc directory:
> /lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4
> Using PETSc arch: arch-linux2-c-opt
> Using C compiler: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpicc  -fPIC
> -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O
> ${COPTFLAGS} ${CFLAGS}
> Using Fortran compiler:
> /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpif90  -fPIC -Wall
> -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O
> ${FOPTFLAGS} ${FFLAGS}
> Using include paths:
> -I/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/include
> -I/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/include
> -I/scratch/p_ppm/TRILINOS/include -I/scratch/p_ppm/HYPRE/include
> -I/scratch/p_ppm/SUPERLU_DIST/include -I/scratch/p_ppm/SUITESPARSE/include
> -I/scratch/p_ppm/MUMPS/include -I/scratch/p_ppm/PARMETIS/include
> -I/scratch/p_ppm/METIS/include -I/scratch/p_ppm/BOOST/include
> -I/sw/taurus/libraries/openmpi/1.10.2-gnu/include
> Using C linker: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpicc
> Using Fortran linker: /sw/taurus/libraries/openmpi/1.10.2-gnu/bin/mpif90
> Using libraries:
> -Wl,-rpath,/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/lib
> -L/lustre/scratch2/p_ppm/jenkins2/workspace/OpenFPM_high_scal_tests/petsc-3.6.4/arch-linux2-c-opt/lib
> -lpetsc -Wl,-rpath,/scratch/p_ppm/TRILINOS/lib
> -L/scratch/p_ppm/TRILINOS/lib -lpike-blackbox -ltrilinoscouplings -lmsqutil
> -lmesquite -lctrilinos -lsundancePdeopt -lsundanceStdFwk -lsundanceStdMesh
> -lsundanceCore -lsundanceInterop -lsundanceUtils -lsundancePlaya -lpiro
> -lrol -lstokhos_muelu -lstokhos_ifpack2 -lstokhos_amesos2 -lstokhos_tpetra
> -lstokhos_sacado -lstokhos -lmoochothyra -lmoocho -lrythmos
> -lmuelu-adapters -lmuelu-interface -lmuelu -lmoertel -llocathyra
> -llocaepetra -llocalapack -lloca -lnoxepetra -lnoxlapack -lnox -lphalanx
> -lstk_mesh_fixtures -lstk_search_util_base -lstk_search
> -lstk_unit_test_utils -lstk_io_util -lstk_io -lstk_mesh_base -lstk_topology
> -lstk_util_use_cases -lstk_util_registry -lstk_util_diag -lstk_util_env
> -lstk_util_util -lstkclassic_search_util -lstkclassic_search
> -lstkclassic_rebalance_utils -lstkclassic_rebalance -lstkclassic_linsys
> -lstkclassic_io_util -lstkclassic_io -lstkclassic_expreval
> -lstkclassic_algsup -lstkclassic_mesh_fem -lstkclassic_mesh_base
> -lstkclassic_util_use_cases -lstkclassic_util_unit_test_support
> -lstkclassic_util_parallel -lstkclassic_util_diag -lstkclassic_util_env
> -lstkclassic_util_util -lstk_mesh_fixtures -lstk_search_util_base
> -lstk_search -lstk_unit_test_utils -lstk_io_util -lstk_io -lstk_mesh_base
> -lstk_topology -lstk_util_use_cases -lstk_util_registry -lstk_util_diag
> -lstk_util_env -lstk_util_util -lstkclassic_search_util -lstkclassic_search
> -lstkclassic_util_util -lintrepid -lteko -lfei_trilinos -lfei_base
> -lstratimikos -lstratimikosbelos -lstratimikosaztecoo -lstratimikosamesos
> -lstratimikosml -lstratimikosifpack -lifpack2-adapters -lifpack2
> -lanasazitpetra -lModeLaplace -lanasaziepetra -lanasazi -lkomplex -lsupes
> -laprepro_lib -lchaco -lIonit -lIotr -lIohb -lIogn -lIopg -lIoss -lsupes
> -laprepro_lib -lchaco -lIonit -lIotr -lIohb -lIogn -lIopg -lIoss -lamesos2
> -lshylu -lbelostpetra -lbelosepetra -lbelos -lml -lifpack -lzoltan2
> -lpamgen_extras -lpamgen -lamesos -lgaleri-xpetra -lgaleri-epetra -laztecoo
> -ldpliris -lisorropia -loptipack -lxpetra-sup -lxpetra -lthyratpetra
> -lthyraepetraext -lthyraepetra -lthyracore -lthyratpetra -lthyraepetraext
> -lthyraepetra -lthyracore -lepetraext -ltpetraext -ltpetrainout -ltpetra
> -lkokkostsqr -ltpetrakernels -ltpetraclassiclinalg -ltpetraclassicnodeapi
> -ltpetraclassic -ltpetraext -ltpetrainout -ltpetra -lkokkostsqr
> -ltpetraclassic -ltriutils -lglobipack -lshards -lzoltan -lepetra -lsacado
> -lrtop -lteuchoskokkoscomm -lteuchoskokkoscompat -lteuchosremainder
> -lteuchosnumerics -lteuchoscomm -lteuchosparameterlist -lteuchoscore
> -lkokkosalgorithms -lkokkoscontainers -lkokkoscore -lkokkosalgorithms
> -lkokkoscontainers -lkokkoscore -ltpi -lgtest -lpthread
> -Wl,-rpath,/scratch/p_ppm/HYPRE/lib -L/scratch/p_ppm/HYPRE/lib -lHYPRE
> -Wl,-rpath,/sw/taurus/libraries/openmpi/1.10.2-gnu/lib
> -L/sw/taurus/libraries/openmpi/1.10.2-gnu/lib
> -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib64
> -L/sw/global/compilers/gcc/5.3.0/lib64
> -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0
> -L/sw/global/compilers/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0
> -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0
> -L/sw/global/compilers/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0
> -Wl,-rpath,/sw/global/compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib
> -L/sw/global/compilers/gcc/5.3.0/x86_64-unknown-linux-gnu/lib
> -L/sw/global/compilers/gcc/5.3.0/lib -lmpi_cxx -lstdc++
> -Wl,-rpath,/scratch/p_ppm//SUPERLU_DIST/lib
> -L/scratch/p_ppm//SUPERLU_DIST/lib -lsuperlu_dist_4.3
> -Wl,-rpath,/scratch/p_ppm/SUITESPARSE/lib -L/scratch/p_ppm/SUITESPARSE/lib
> -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd
> -lsuitesparseconfig -lrt -ldmumps -Wl,-rpath,/scratch/p_ppm//MUMPS/lib
> -L/scratch/p_ppm//MUMPS/lib -lmumps_common -lpord
> -Wl,-rpath,/scratch/p_ppm/SCALAPACK/lib -L/scratch/p_ppm/SCALAPACK/lib
> -lscalapack -Wl,-rpath,/scratch/p_ppm//OPENBLAS/lib
> -L/scratch/p_ppm//OPENBLAS/lib -lopenblas
> -Wl,-rpath,/scratch/p_ppm/PARMETIS/lib -L/scratch/p_ppm/PARMETIS/lib
> -lparmetis -Wl,-rpath,/scratch/p_ppm/METIS/lib -L/scratch/p_ppm/METIS/lib
> -lmetis -lX11 -lhwloc -lssl -lcrypto -lm -lmpi_usempi -lmpi_mpifh
> -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++
> -L/sw/global/compilers/gcc/5.3.0/lib -ldl
> -Wl,-rpath,/sw/taurus/libraries/openmpi/1.10.2-gnu/lib -lmpi -lgcc_s
> -lpthread -ldl
> Regards
> Pietro Incardona
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170615/bd775bec/attachment-0001.html>
