[petsc-users] slepc trap for large matrix
Kannan, Ramakrishnan
kannanr at ornl.gov
Wed Jun 7 09:37:18 CDT 2017
Barry,
Thanks for the kind response. I am building slepc 3.7.3 and when I configure –with-64-bit-indices=1, I am getting the following error.
./configure --with-64-bit-indices=1 --prefix=/lustre/atlas/proj-shared/csc209/ramki/slepc
ERROR: Invalid arguments --with-64-bit-indices=1
Use -h for help
When I run ./configure –h, I am getting the following options. Let me know if I am missing something.
SLEPc Configure Help
SLEPc:
--with-clean=<bool> : Delete prior build files including externalpackages
--with-cmake=<bool> : Enable builds with CMake (disabled by default)
--prefix=<dir> : Specify location to install SLEPc (e.g., /usr/local)
--DATAFILESPATH=<dir> : Specify location of datafiles (for SLEPc developers)
ARPACK:
--download-arpack[=<fname>] : Download and install ARPACK in SLEPc directory
--with-arpack=<bool> : Indicate if you wish to test for ARPACK
--with-arpack-dir=<dir> : Indicate the directory for ARPACK libraries
--with-arpack-flags=<flags> : Indicate comma-separated flags for linking ARPACK
BLOPEX:
--download-blopex[=<fname>] : Download and install BLOPEX in SLEPc directory
BLZPACK:
--with-blzpack=<bool> : Indicate if you wish to test for BLZPACK
--with-blzpack-dir=<dir> : Indicate the directory for BLZPACK libraries
--with-blzpack-flags=<flags> : Indicate comma-separated flags for linking BLZPACK
FEAST:
--with-feast=<bool> : Indicate if you wish to test for FEAST
--with-feast-dir=<dir> : Indicate the directory for FEAST libraries
--with-feast-flags=<flags> : Indicate comma-separated flags for linking FEAST
PRIMME:
--download-primme[=<fname>] : Download and install PRIMME in SLEPc directory
--with-primme=<bool> : Indicate if you wish to test for PRIMME
--with-primme-dir=<dir> : Indicate the directory for PRIMME libraries
--with-primme-flags=<flags> : Indicate comma-separated flags for linking PRIMME
TRLAN:
--download-trlan[=<fname>] : Download and install TRLAN in SLEPc directory
--with-trlan=<bool> : Indicate if you wish to test for TRLAN
--with-trlan-dir=<dir> : Indicate the directory for TRLAN libraries
--with-trlan-flags=<flags> : Indicate comma-separated flags for linking TRLAN
SOWING:
--download-sowing[=<fname>] : Download and install SOWING in SLEPc directory
Ramki
On 6/6/17, 9:06 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
The resulting matrix has something like
>>> 119999808*119999808*1.e-6
14,399,953,920.036863
nonzero entries. It is possible that some integer operations are overflowing since C int can only go up to about 4 billion before overflowing.
You can building with a different PETSC_ARCH value using the additional ./configure option for PETSc of --with-64-bit-indices and see if the problem is resolved.
Barry
> On Jun 5, 2017, at 12:37 PM, Kannan, Ramakrishnan <kannanr at ornl.gov> wrote:
> I am running EPS for NHEP on a matrix of size 119999808x119999808 and I am experiencing the attached trapped. This is a 1D row distributed sparse uniform random matrix with 1e-6 sparsity over 36 processors. It works fine for smaller matrices of sizes with 1.2 million x 1.2 million. Let me know if you are looking for more information.
> Regards,
> Ramki
> <slepc.e609742.zip>
