[petsc-users] Parallel vector with shared memory in Fortran
Stefano Zampini stefano.zampini at gmail.com
Mon Jun 5 09:44:26 CDT 2017
Sorry, bad copy and paste
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreateToAll.html
Il 05 Giu 2017 4:43 PM, "Stefano Zampini" <stefano.zampini at gmail.com> ha
scritto:
> Il 05 Giu 2017 4:12 PM, "Francesco Migliorini" <
> francescomigliorini93 at gmail.com> ha scritto:
>> Hello there!
>> I am working with an MPI code in which I should create a petsc vector
>> such that all the processes can access to all its entries. So, I tried with
>> VecCreateShared but it does not work with my machine. Then I tried
>> VecCreateMPI but it seems to me that it does not change anything from the
>> usual VecCreate. Finally I found the scatter commands but the examples are
>> a bit tricky. So, are there any other way? If no, could someone please show
>> me how to use scatter in this simple code?
>> Vec  feP    !The vector to be shared with all the processes
>> mpi_np = 2    !The number of processes
>> ind(1) = 10   !The global dimension of the vector
>> call VecCreate(PETSC_COMM_WORLD,feP,perr)
>> call VecSetSizes(feP,PETSC_DECIDE,ind,perr)
>> call VecSetFromOptions(feP,perr)
>> (...)    !Here feP is filled in
>> call VecAssemblyBegin(feP,perr)
>> call VecAssemblyEnd(feP,perr)
>> Many thanks,
>> Francesco
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170605/fbc96526/attachment.html>
