[petsc-users] Parallel vector with shared memory in Fortran
Stefano Zampini
stefano.zampini at gmail.com
Mon Jun 5 09:43:31 CDT 2017
petsc-current/docs/manualpages/Vec/VecScatterCreateToAll.html
Il 05 Giu 2017 4:12 PM, "Francesco Migliorini" <
francescomigliorini93 at gmail.com> ha scritto:
> Hello there!
> I am working with an MPI code in which I should create a petsc vector such
> that all the processes can access to all its entries. So, I tried with
> VecCreateShared but it does not work with my machine. Then I tried
> VecCreateMPI but it seems to me that it does not change anything from the
> usual VecCreate. Finally I found the scatter commands but the examples are
> a bit tricky. So, are there any other way? If no, could someone please show
> me how to use scatter in this simple code?
> Vec feP !The vector to be shared with all the processes
> mpi_np = 2 !The number of processes
> ind(1) = 10 !The global dimension of the vector
> call VecCreate(PETSC_COMM_WORLD,feP,perr)
> call VecSetSizes(feP,PETSC_DECIDE,ind,perr)
> call VecSetFromOptions(feP,perr)
> (...) !Here feP is filled in
> call VecAssemblyBegin(feP,perr)
> call VecAssemblyEnd(feP,perr)
> Many thanks,
> Francesco
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170605/54a3e4d0/attachment.html>
