[petsc-users] Using FAS with SNES
Karin&NiKo niko.karin at gmail.com
Fri Jun 2 10:13:57 CDT 2017
I emphasize that snes/examples/tutorials/ex1.c works perfectly with the
option -snes_type fas.
2017-06-02 17:07 GMT+02:00 Karin&NiKo <niko.karin at gmail.com>:
> Dear All,
> In order to ease the investigation, I reproduced this segfault by running
> snes/examples/tutorials/ex1f.F with the option -snes_type fas.
> I have the feeling that this is due to the nullity of the context object
> of FormJacobian (PETSC_NULL_OBJECT in Fortran).
> Best regards,
> Nicolas
> 2017-06-01 16:30 GMT+02:00 Karin&NiKo <niko.karin at gmail.com>:
>> Dear PETSc team,
>> I have interfaced our fortran legacy code with PETSC SNES. I mainly
>> followed the examples you provide. What I conceptually used is :
>>     call SNESCreate(PETSC_COMM_WORLD,snes,ierr)
>>     call SNESSetFromOptions(snes,ierr)
>>     call SNESSETFunction(snes, pf, nonlinFormFunction, PETSC_NULL_OBJECT,
>> ierr)
>>     call SNESSetJacobian(snes, mat, mat, nonlinFormJacobian,
>> PETSC_NULL_OBJECT, ierr)
>>     call SNESSetKSP(snes, myksp, ierr)
>> The code runs fine with -snes_type newtonls or newtontr. But when using
>> -snes_type fas, it complains with the message :
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Corrupt argument: http://www.mcs.anl.gov/petsc/d
>> ocumentation/faq.html#valgrind
>> [0]PETSC ERROR: Fortran callback not set on this object
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
>> [0]PETSC ERROR:
>> on a arch-linux2-c-debug named dsp0780450 by niko Thu Jun  1 16:18:43 2017
>> [0]PETSC ERROR: Configure options --prefix=/home/niko/dev/codeas
>> ter-prerequisites/petsc-3.7.2/Install --with-mpi=yes --with-x=yes
>> --download-ml=/home/niko/dev/codeaster-prerequisites/petsc-3.7.2/ml-6.2-p3.tar.gz
>> --with-mumps-lib="-L/home/niko/dev/codeaster-prerequisites/
>> v13/prerequisites/Mumps-502_consortium_aster1/MPI/lib -lzmumps -ldmumps
>> -lmumps_common -lpord -L/home/niko/dev/codeaster-pre
>> requisites/v13/prerequisites/Scotch_aster-604_aster6/MPI/lib -lesmumps
>> -lptscotch -lptscotcherr -lptscotcherrexit -lscotch -lscotcherr
>> -lscotcherrexit -L/home/niko/dev/codeaster-pre
>> requisites/v13/prerequisites/Parmetis_aster-403_aster/lib -lparmetis
>> -L/home/niko/dev/codeaster-prerequisites/v13/prerequisites/Metis_aster-510_aster1/lib
>> -lmetis -L/usr/lib -lscalapack-openmpi -L/usr/lib -lblacs-openmpi
>> -lblacsCinit-openmpi -lblacsF77init-openmpi -L/usr/lib/x86_64-linux-gnu
>> -lgomp " --with-mumps-include=/home/niko/dev/codeaster-prerequisites/
>> v13/prerequisites/Mumps-502_consortium_aster1/MPI/include
>> --with-scalapack-lib="-L/usr/lib -lscalapack-openmpi"
>> --with-blacs-lib="-L/usr/lib -lblacs-openmpi -lblacsCinit-openmpi
>> -lblacsF77init-openmpi" --with-blas-lib="-L/usr/lib -lopenblas -lcblas"
>> --with-lapack-lib="-L/usr/lib -llapack"
>> [0]PETSC ERROR: #1 PetscObjectGetFortranCallback() line 263 in
>> /home/niko/dev/codeaster-prerequisites/petsc-3.7.2/src/sys/
>> objects/inherit.c
>> [0]PETSC ERROR: #2 oursnesjacobian() line 105 in
>> /home/niko/dev/codeaster-prerequisites/petsc-3.7.2/src/snes/
>> interface/ftn-custom/zsnesf.c
>> [0]PETSC ERROR: #3 SNESComputeJacobian() line 2312 in
>> interface/snes.c
>> [0]PETSC ERROR: #4 SNESSolve_NEWTONLS() line 228 in
>> /home/niko/dev/codeaster-prerequisites/petsc-3.7.2/src/snes/impls/ls/ls.c
>> [0]PETSC ERROR: #5 SNESSolve() line 4008 in /home/niko/dev/codeaster-prere
>> quisites/petsc-3.7.2/src/snes/interface/snes.c
>> [0]PETSC ERROR: #6 SNESFASDownSmooth_Private() line 512 in
>> impls/fas/fas.c
>> [0]PETSC ERROR: #7 SNESFASCycle_Multiplicative() line 816 in
>> impls/fas/fas.c
>> [0]PETSC ERROR: #8 SNESSolve_FAS() line 987 in
>> impls/fas/fas.c
>> [0]PETSC ERROR: #9 SNESSolve() line 4008 in /home/niko/dev/codeaster-prere
>> When exploring a little bit with a debugger, it seems that the object
>> snes->vec_rhs which is used is fas.c is a null pointer.
>> What is this object vec_rhs and how to set it?
>> Thank you in advance,
>> Nicolas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170602/67dc9ce6/attachment.html>
