[petsc-users] DMPlex distribution with FVM adjacency
Lawrence Mitchell
lawrence.mitchell at imperial.ac.uk
Thu Jun 1 10:51:00 CDT 2017
On 25/05/17 21:00, Matthew Knepley wrote:
> On Thu, May 25, 2017 at 2:22 PM, Lawrence Mitchell
> <lawrence.mitchell at imperial.ac.uk
> <mailto:lawrence.mitchell at imperial.ac.uk>> wrote:
> > On 25 May 2017, at 20:03, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> > Hmm, I thought I made adjacency per field. I have to look. That way, no problem with the Stokes example. DG is still weird.
> You might, we don't right now. We just make the topological
> adjacency that is "large enough", and then make fields on that.
> > That seems baroque. So this is just another adjacency pattern. You should be able to easily define it, or if you are a patient person,
> > wait for me to do it. Its here
> > https://bitbucket.org/petsc/petsc/src/01c3230e040078628f5e559992965c1c4b6f473d/src/dm/impls/plex/plexdistribute.c?at=master&fileviewer=file-view-default#plexdistribute.c-239
> <https://bitbucket.org/petsc/petsc/src/01c3230e040078628f5e559992965c1c4b6f473d/src/dm/impls/plex/plexdistribute.c?at=master&fileviewer=file-view-default#plexdistribute.c-239>
> > I am more than willing to make this overridable by the user through function composition or another mechanism.
> Hmm, that naive thing of just modifying the XXX_Support_Internal
> to compute with DMPlexGetTransitiveClosure rather than
> DMPlexGetCone didn't do what I expected, but I don't understand
> the way this bootstrapping is done very well.
> It should do the right thing. Notice that you have to be careful about
> the arrays that you use since I reuse them for efficiency here.
> What is going wrong?
Coming back to this, I think I understand the problem a little better.
Consider this mesh:
|\ 3 |
|2 \ |
|\ 1 |
|0 \ |
Let's say I run on 3 processes and the initial (non-overlapped) cell
partition is:
rank 0: cell 0
rank 1: cell 1 & 2
rank 2: cell 3
Now I'd like to grow the overlap such that any cell I can see through
a facet (and its closure) lives in the overlap.
So great, I just need a new adjacency relation that gathers
closure(support(point))
But, that isn't right, because now on rank 0, I will get a mesh that
looks like:
|\ 1 |
|0 \ |
Because I grab all the mesh points in the adjacency of the initial cell:
|0 \
And on the top vertex that pulls in the facet (but not the cell).
So I can write a "DMPlexGetAdjacency" information that only returns
non-empty adjacencies for facets. But it's sort of lying about what
it does now.
Thoughts?
Lawrence
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170601/0d2627d3/attachment-0001.pgp>
