[petsc-users] help me to solve 6-dim PDE with PETSc with advice
Oleksandr Koshkarov
olk548 at mail.usask.ca
Sun Jul 30 14:04:55 CDT 2017
Yes, It seems I am wrong and you are right.
I think I can then make electric and magnetic fields local and do
parallel partitioning only in v space - it will defiantly restrict the
problem size, but maybe the code still be still useful and I get petsc
experience with it :) The question here if I will just parallize along
v-space, the 3d DMDA should be enough, right? I do not really understand
how would I do the partitioning here, can you please give me some hints?
Another approach is to abandon global Fourier, let say for education
purposes I will pick some finite difference along spacial dimensions,
how would you advice me to partition this problem with PETSc then?
I know something like spectral elements or discontinuous Galerkin will
be ideal, but I want to get petsc experience first with simpler problem
and then move to discontinuous Galerkin (this will be defiantly the next
step). (Unfortunately, I have never done any unstructured meshes like
spectral elements or discontinuous Galerkin myself before, but did some
finite difference and spectral methods)
On 07/30/2017 12:46 PM, Matthew Knepley wrote:
> On Sun, Jul 30, 2017 at 12:44 PM, Oleksandr Koshkarov
> <olk548 at mail.usask.ca <mailto:olk548 at mail.usask.ca>> wrote:
> Thanks for the references, and warning.
> I am trying to do exactly this
> http://www.sciencedirect.com/science/article/pii/S0021999115004738
> <http://www.sciencedirect.com/science/article/pii/S0021999115004738>
> (I probably should have added the reference in the first place, sorry)
> the evolution formula is (15) in the article.
> So, I will do convolution only in 3D (while full system is 6D)
> because velocity space is not discretized with Fourier
> So As I understand, it will not be N^2 vs N logN. Moreover, I know
> that algorithm with FFT has significantly larger "constant".
> Please correct me if I am wrong here :)
> I think you are wrong here. First, I do not understand why you think
> the asymptotics have changed. Second, the constant for
> FFT is about 6, which would be really hard to beat with a quadrature.
> Last, this discretization looks fully coupled to me. I cannot see how
> you would parallelize this right off the bat. This is a problem
> with spectral discretizations, and the main motivator for spectral
> elements.
> Thanks,
> Matt
> I know for sure that FFT is a must at the end, but I thought I can
> start with matrix product to get more familiar with PETSc as it
> will be simpler to implement (At least I think so).
> I hope it does make sense.
> Another question about convolution via matrix product. Is there
> better way to do it other then to construct NxN Toeplitz-like
> matrix each time step on the "fly" from state vector and then
> multiply it to state vector?
> p.s. Probably I should do FFT from the start, but I am a little
> bit intimidated by the problem taking into account that I do not
> have PETSc experience.
> Best regards,
> Oleksandr Koshkarov.
> On 07/30/2017 09:01 AM, Matthew Knepley wrote:
>> On Sat, Jul 29, 2017 at 7:01 PM, Oleksandr Koshkarov
>> Thank you for the response,
>> Now that you said about additional communication for fft, I
>> want to ask another question:
>> What if I disregard FFT and will compute convolution
>> directly, I will rewrite it as vector-matrix-vector product
>> I would caution you here. The algorithm is the most important
>> thing to get right up front. In this case, the effect of
>> dimension will be dominant, and anything that does not scale well
>> with dimension will be thrown away, perhaps
>> quite quickly, as you want to solve bigger problems.
>> Small calculation: Take a 6-dim box which is 'n' on a side, so
>> that N = n^6. FFT is N log N, whereas direct evaluation of
>> a convolution is N^2. So if we could do n = 100 points on a side
>> with FFT, you can do, assuming the constants are about
>> equal,
>> 100^6 (log 100^6) = x^12
>> 1e12 (6 2) = x^12
>> x ~ 10
>> Past versions of PETSc had a higher dimensional DA construct
>> (adda in prior versions), but no one used it so we removed it.
>> I assume you are proposing something like
>> https://arxiv.org/abs/1306.4625 <https://arxiv.org/abs/1306.4625>
>> or maybe
>> https://arxiv.org/abs/1610.00397 <https://arxiv.org/abs/1610.00397>
>> The later is interesting since I think you could use a DMDA for
>> the velocity and something like DMPlex for the space.
>> Thanks,
>> Matt
>> x^T A x (where T - is transpose, x - is my state vector, and
>> A is a matrix which represents convolution and probably it
>> will be not very sparse).
>> Yes - I will do more work (alghorithm will be slower), but
>> will I win if we take the parallelization into account - less
>> communication + probably more scalable algorithm?
>> Best regards,
>> Alex.
>> On 07/29/2017 05:23 PM, Barry Smith wrote:
>> DMDA provides a simple way to do domain decomposition of
>> structured grid meshes in the x, y, and z direction, that
>> is it makes it easy to efficiently chop up vectors in all
>> 3 dimensions, allowing very large problems easily.
>> Unfortunately it only goes up to 3 dimensions and
>> attempts to produce versions for higher dimensions have
>> failed.
>> If you would like to do domain decomposition across
>> all six of your dimensions (which I think you really need
>> to do to solve large problems) we don't have a tool that
>> helps with doing the domain decomposition. To make
>> matters more complicated, likely the 3d mpi-fftw that
>> need to be applied require rejiggering the data across
>> the nodes to get it into a form where the ffts can be
>> applied efficiently.
>> I don't think there is necessarily anything
>> theoretically difficult about managing the six
>> dimensional domain decomposition I just don't know of any
>> open source software out there that helps to do this.
>> Maybe some PETSc users are aware of such software and can
>> chime in.
>> Aside from these two issues :-) PETSc would be useful
>> for you since you could use our time integrators and
>> nonlinear solvers. Pulling out subvectors to process on
>> can be done with with either VecScatter or
>> VecStrideScatter, VecStrideGather etc depending on the
>> layout of the unknowns, i.e. how the domain decomposition
>> is done.
>> I wish I had better answers for managing the 6d
>> Barry
>> On Jul 29, 2017, at 5:06 PM, Oleksandr Koshkarov
>> wrote:
>> Dear All,
>> I am a new PETSc user and I am still in the middle of
>> the manual (I have finally settled to choose PETSc as
>> my main numerical library) so I am sorry beforehand
>> if my questions would be naive.
>> I am trying to solve 6+1 dimensional Vlasov equation
>> with spectral methods. More precisely, I will try to
>> solve half-discretized equations of the form
>> (approximate form) with pseudospectral Fourier method:
>> (Equations are in latex format, the nice website to
>> see them is
>> https://www.codecogs.com/latex/eqneditor.php
>> <https://www.codecogs.com/latex/eqneditor.php>)
>> \frac{dC_{m,m,p}}{dt} =\\
>> \partial_x \left ( a_n C_{n+1,m,p} +b_n C_{n,m,p}
>> +c_n C_{n-1,m,p} \right ) \\
>> + \partial_y \left ( a_m C_{n,m+1,p} +b_m C_{n,m,p}
>> +c_m C_{n,m-1,p} \right ) \\
>> + \partial_z \left ( a_p C_{n,m,p+1} +b_p C_{n,m,p}
>> +c_p C_{n,m,p-1} \right ) \\
>> + d_n E_x C_{n-1,m,p} + d_m E_x C_{n,m-1,p} + d_p E_x
>> C_{n,m,p-1} \\
>> + B_x (e_{m,p} C_{n,m-1,p-1} + f_{m,p}C_{n,m-1,p+1} +
>> \dots) + B_y (\dots) + B_z (\dots)
>> where a,b,c,d,e,f are some constants which can depend
>> on n,m,p,
>> n,m,p = 0...N,
>> C_{n,m,p} = C_{n,m,p}(x,y,z),
>> E_x = E_x(x,y,z), (same for E_y,B_x,...)
>> and fields are described with equation of the sort
>> (linear pdes with source terms dependent on C):
>> \frac{dE_x}{dt} = \partial_y B_z - \partial_z B_x +
>> (AC_{1,0,0} + BC_{0,0,0}) \\
>> \frac{dB_x}{dt} = -\partial_y E_z + \partial_z E_x
>> with A,B being some constants.
>> I will need fully implicit Crank–Nicolson method, so
>> my plan is to use SNES or TS where
>> I will use one MPI PETSc vector which describes the
>> state of the system (all, C, E, B), then I can
>> evolve linear part with just matrix multiplication.
>> The first question is, should I use something like
>> DMDA? if so, it is only 3dimensional but I need 6
>> dimensional vectots? Will it be faster then matrix
>> multiplication?
>> Then to do nonlinear part I will need 3d mpi-fftw to
>> compute convolutions. The problem is, how do I
>> extract subvectors from full big vector state? (what
>> is the best approach?)
>> If you have some other suggestions, please feel free
>> to share
>> Thanks and best regards,
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/%7Emk51/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170730/3cbea83c/attachment.html>
