[petsc-users] help me to solve 6-dim PDE with PETSc with advice
Oleksandr Koshkarov
olk548 at mail.usask.ca
Sun Jul 30 12:44:22 CDT 2017
Thanks for the references, and warning.
I am trying to do exactly this
http://www.sciencedirect.com/science/article/pii/S0021999115004738
(I probably should have added the reference in the first place, sorry)
the evolution formula is (15) in the article.
So, I will do convolution only in 3D (while full system is 6D) because
velocity space is not discretized with Fourier
So As I understand, it will not be N^2 vs N logN. Moreover, I know that
algorithm with FFT has significantly larger "constant".
Please correct me if I am wrong here :)
I know for sure that FFT is a must at the end, but I thought I can start
with matrix product to get more familiar with PETSc as it will be
simpler to implement (At least I think so).
I hope it does make sense.
Another question about convolution via matrix product. Is there better
way to do it other then to construct NxN Toeplitz-like matrix each time
step on the "fly" from state vector and then multiply it to state vector?
p.s. Probably I should do FFT from the start, but I am a little bit
intimidated by the problem taking into account that I do not have PETSc
experience.
Best regards,
Oleksandr Koshkarov.
On 07/30/2017 09:01 AM, Matthew Knepley wrote:
> On Sat, Jul 29, 2017 at 7:01 PM, Oleksandr Koshkarov
> <olk548 at mail.usask.ca <mailto:olk548 at mail.usask.ca>> wrote:
> Thank you for the response,
> Now that you said about additional communication for fft, I want
> to ask another question:
> What if I disregard FFT and will compute convolution directly, I
> will rewrite it as vector-matrix-vector product
> I would caution you here. The algorithm is the most important thing
> to get right up front. In this case, the effect of
> dimension will be dominant, and anything that does not scale well with
> dimension will be thrown away, perhaps
> quite quickly, as you want to solve bigger problems.
> Small calculation: Take a 6-dim box which is 'n' on a side, so that N
> = n^6. FFT is N log N, whereas direct evaluation of
> a convolution is N^2. So if we could do n = 100 points on a side with
> FFT, you can do, assuming the constants are about
> equal,
> 100^6 (log 100^6) = x^12
> 1e12 (6 2) = x^12
> x ~ 10
> Past versions of PETSc had a higher dimensional DA construct (adda in
> prior versions), but no one used it so we removed it.
> I assume you are proposing something like
> https://arxiv.org/abs/1306.4625
> or maybe
> https://arxiv.org/abs/1610.00397
> The later is interesting since I think you could use a DMDA for the
> velocity and something like DMPlex for the space.
> Thanks,
> Matt
> x^T A x (where T - is transpose, x - is my state vector, and A is
> a matrix which represents convolution and probably it will be not
> very sparse).
> Yes - I will do more work (alghorithm will be slower), but will I
> win if we take the parallelization into account - less
> communication + probably more scalable algorithm?
> Best regards,
> Alex.
> On 07/29/2017 05:23 PM, Barry Smith wrote:
> DMDA provides a simple way to do domain decomposition of
> structured grid meshes in the x, y, and z direction, that is
> it makes it easy to efficiently chop up vectors in all 3
> dimensions, allowing very large problems easily. Unfortunately
> it only goes up to 3 dimensions and attempts to produce
> versions for higher dimensions have failed.
> If you would like to do domain decomposition across all six
> of your dimensions (which I think you really need to do to
> solve large problems) we don't have a tool that helps with
> doing the domain decomposition. To make matters more
> complicated, likely the 3d mpi-fftw that need to be applied
> require rejiggering the data across the nodes to get it into a
> form where the ffts can be applied efficiently.
> I don't think there is necessarily anything theoretically
> difficult about managing the six dimensional domain
> decomposition I just don't know of any open source software
> out there that helps to do this. Maybe some PETSc users are
> aware of such software and can chime in.
> Aside from these two issues :-) PETSc would be useful for
> you since you could use our time integrators and nonlinear
> solvers. Pulling out subvectors to process on can be done with
> with either VecScatter or VecStrideScatter, VecStrideGather
> etc depending on the layout of the unknowns, i.e. how the
> domain decomposition is done.
> I wish I had better answers for managing the 6d domain
> decomposition
> Barry
> On Jul 29, 2017, at 5:06 PM, Oleksandr Koshkarov
> Dear All,
> I am a new PETSc user and I am still in the middle of the
> manual (I have finally settled to choose PETSc as my main
> numerical library) so I am sorry beforehand if my
> questions would be naive.
> I am trying to solve 6+1 dimensional Vlasov equation with
> spectral methods. More precisely, I will try to solve
> half-discretized equations of the form (approximate form)
> with pseudospectral Fourier method:
> (Equations are in latex format, the nice website to see
> them is https://www.codecogs.com/latex/eqneditor.php
> <https://www.codecogs.com/latex/eqneditor.php>)
> \frac{dC_{m,m,p}}{dt} =\\
> \partial_x \left ( a_n C_{n+1,m,p} +b_n C_{n,m,p} +c_n
> C_{n-1,m,p} \right ) \\
> + \partial_y \left ( a_m C_{n,m+1,p} +b_m C_{n,m,p} +c_m
> C_{n,m-1,p} \right ) \\
> + \partial_z \left ( a_p C_{n,m,p+1} +b_p C_{n,m,p} +c_p
> C_{n,m,p-1} \right ) \\
> + d_n E_x C_{n-1,m,p} + d_m E_x C_{n,m-1,p} + d_p E_x
> C_{n,m,p-1} \\
> + B_x (e_{m,p} C_{n,m-1,p-1} + f_{m,p}C_{n,m-1,p+1} +
> \dots) + B_y (\dots) + B_z (\dots)
> where a,b,c,d,e,f are some constants which can depend on
> n,m,p,
> n,m,p = 0...N,
> C_{n,m,p} = C_{n,m,p}(x,y,z),
> E_x = E_x(x,y,z), (same for E_y,B_x,...)
> and fields are described with equation of the sort (linear
> pdes with source terms dependent on C):
> \frac{dE_x}{dt} = \partial_y B_z - \partial_z B_x +
> (AC_{1,0,0} + BC_{0,0,0}) \\
> \frac{dB_x}{dt} = -\partial_y E_z + \partial_z E_x
> with A,B being some constants.
> I will need fully implicit Crank–Nicolson method, so my
> plan is to use SNES or TS where
> I will use one MPI PETSc vector which describes the state
> of the system (all, C, E, B), then I can evolve linear
> part with just matrix multiplication.
> The first question is, should I use something like DMDA?
> if so, it is only 3dimensional but I need 6 dimensional
> vectots? Will it be faster then matrix multiplication?
> Then to do nonlinear part I will need 3d mpi-fftw to
> compute convolutions. The problem is, how do I extract
> subvectors from full big vector state? (what is the best
> approach?)
> If you have some other suggestions, please feel free to share
> Thanks and best regards,
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170730/93c8594b/attachment.html>
