[petsc-users] SLEPC solvers not converging in latest version
Pandey, Siddhant spandey2 at wpi.edu
Wed Jul 12 16:15:36 CDT 2017
I have attached the matrices and the 'eps_view_pre' ouput in the zip file.
The versions of the older installation were: petsc-3.7.5, slecp-3.7.1;
and the current versions are: petsc-3.7.6, slecp-3.7.4.
Sidd (WPI)
Sent: Wednesday, July 12, 2017 4:29:57 PM
To: Pandey, Siddhant
Cc: Hong Zhang; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] SLEPC solvers not converging in latest version
> El 12 jul 2017, a las 22:05, Pandey, Siddhant <spandey2 at wpi.edu> escribió:
> I've attached the B matrix (binary) in a zip file. To give more context to the problem, the previous installation of petsc/slecp doesn't give this error. So the matrix being singular shouldn't be the issue since my matrix assembly routines are independent of the petsc/slepc installation I use. Also, diagonalization happens for smaller matrices.
> Unfortunately, since EPSsolve never got completed, -eps_viewer didn't return anything. Is there any other way I can show the settings used?
> Sidd
Use -eps_view_pre (it should view settings at the beginning of solve), or run a smaller case (settings should be the same).
I will also need the other matrix, otherwise I cannot run EPS.
Also, tell me which version are you using now, and which version worked before.
Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170712/73139c06/attachment-0001.html>
Type: application/zip
Desc: A,B,eps.zip
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170712/73139c06/attachment-0001.zip>
