[petsc-users] SLEPC solvers not converging in latest version
Jose E. Roman jroman at dsic.upv.es
Wed Jul 12 15:29:57 CDT 2017
> El 12 jul 2017, a las 22:05, Pandey, Siddhant <spandey2 at wpi.edu> escribió:
> I've attached the B matrix (binary) in a zip file. To give more context to the problem, the previous installation of petsc/slecp doesn't give this error. So the matrix being singular shouldn't be the issue since my matrix assembly routines are independent of the petsc/slepc installation I use. Also, diagonalization happens for smaller matrices.
> Unfortunately, since EPSsolve never got completed, -eps_viewer didn't return anything. Is there any other way I can show the settings used?
> Sidd
Use -eps_view_pre (it should view settings at the beginning of solve), or run a smaller case (settings should be the same).
I will also need the other matrix, otherwise I cannot run EPS.
Also, tell me which version are you using now, and which version worked before.
Jose
