[petsc-users] NULL section fortran
Justin Pogacnik
j.pogacnik at auckland.ac.nz
Wed Jul 12 14:52:07 CDT 2017
Hello,
I'm assembling a global finite element stiffness matrix and using the DMPlexMatSetClosure command in fortran. Long ago, in the past, I've used to set the section input parameters to PETSC_NULL_OBJECT. That now returns an error -- no implicit type -- during compilation. Looking at the defined null objects for fortran I don't see a section option. What should I use to invoke the default sections?
Hope this makes sense. Thanks!
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170712/f452080e/attachment.html>
