[petsc-users] Multi-domain meshes with DMPLEX
Santos Teixeira Frederico
fsantost at student.ethz.ch
Sun Feb 26 10:51:00 CST 2017
Hi folks,
Attached you find small.msh, a mesh with two prisms (physical domains 43 and 45) and the interface between them (physical domain 40).
test_dmplex.cpp loads the mesh and tries to filter each sub-mesh and the interface. I use PETSc master.
When I load small.msh, all physical domains are correctly assigned to "Cell Sets" or "Face Sets".
1) Both sub-meshes (prisms with domains 43 and 45) are filtered with DMPlexFilter and saved correctly, but the interface isn't. What am I missing?
2) I can retrieve any specific strata of "Cell Sets" with DMPlexFilter, but this operation does not include any related strata of "Face Sets", as pointed by DMView. How can I do it?
3) Physical domains 43 and 45 could be interpreted as fluid and solid domains in a F.S.I. simulation, for example, and I would like to define fluid and solid sub-problems only on the respective sub-mesh. Do I really need to have fully operational sub-DMPLEX's in order to achieve it? Is there an easier way?
My apologies if the explanations are confusing!
Best regards,
Frederico.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170226/1735b05b/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170226/1735b05b/attachment-0001.txt>
Desc: small.msh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170226/1735b05b/attachment-0002.obj>
Desc: test_dmplex.cpp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170226/1735b05b/attachment-0003.obj>
