[petsc-users] configure PETSc on Cray
Patrick Sanan
patrick.sanan at gmail.com
Fri Feb 10 11:55:41 CST 2017
You're missing the 'g' in 'configure.py'.
On Fri, Feb 10, 2017 at 6:51 PM, Sharp Stone <thronesf at gmail.com> wrote:
> Hi all,
> I noticed the instructions of Petsc with MPI. Now I'm using Cray. So the
> instruction:
> Vendor provided MPI might already be installed. IBM, SGI, Cray etc provide
> their own:
> ./config/confiure.py --with-cc=mpcc --with-fc=mpf77
> When I use the command "./config/confiure.py --with-cc=mpcc
> --with-fc=mpf77", it gives me the error "-bash: ./config/confiure.py: No
> such file or directory". But the file "confiure.py" is there in the "config"
> folder.
> What should I do?
> Thanks very much!
> Best regards,
> Feng
