[petsc-users] configure PETSc on Cray
Sharp Stone thronesf at gmail.com
Fri Feb 10 11:51:15 CST 2017
Hi all,
I noticed the instructions of Petsc with MPI. Now I'm using Cray. So the
instruction:
Vendor provided MPI might already be installed. IBM, SGI, Cray etc provide
their own:
./config/confiure.py --with-cc=mpcc --with-fc=mpf77
When I use the command "./config/confiure.py --with-cc=mpcc --with-fc=mpf77",
it gives me the error "-bash: ./config/confiure.py: No such file or
directory". But the file "confiure.py" is there in the "config" folder.
What should I do?
Thanks very much!
Best regards,
Feng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170210/fb004667/attachment.html>
