[petsc-users] projection methods in TS
Matthew Knepley
knepley at gmail.com
Sat Feb 4 19:58:59 CST 2017
On Sat, Feb 4, 2017 at 7:56 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
> On Feb 4, 2017, at 7:47 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Feb 4, 2017 at 7:44 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>> > On Sat, Feb 4, 2017 at 7:24 PM, Zhang, Hong <hongzhang at anl.gov> wrote:
>> >> Can you elaborate a bit more on your problem?
>> >> If your problem is an index-1 DAE, there is no need to use a projection
>> >> method, and it is perfectly fine to set it up as a DAE in PETSc. For
>> >> high-index DAEs, you may have to use TSSetPostStep() to implement your
>> own
>> >> projection algorithm.
>> > Please define index.
>> Think of it as a measure of singularity of the "mass matrix". Higher
>> index DAE have more complicated constraints on compatibility of initial
>> conditions. It's covered in any book or paper on DAEs.
> Both your explanation and Hong's use of the term do not help Gideon (or
> me) know whether he has an index-1 DAE. There has
> to be some simple form you can write down so that we can tell.
> This is why we need to learn more about Gideon's problem. It is easy to
> determine the index if he can write down his problem in a simple form. But
> it is not that easy the other way round.
He says
y' = f(y)
0 = g(y)
which appears to me to be a Hessenberg index-2 DAE. Is that correct?
Matt
Hong
> Matt
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170204/1560087a/attachment.html>
