[petsc-users] DMCreateGlobalVector in fortran.
Matthew Knepley
knepley at gmail.com
Sat Feb 4 19:34:22 CST 2017
On Sat, Feb 4, 2017 at 7:30 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> Thanks, that helped a lot,
> Now im a little confused with my next error, in my serial code i have
> several arrays with dimensions declared as:
> u0(-1:IMax+2,-1:JMax+1,-1:KMax+1)
> and i create my DMDA for this array as:
> call CDA3(daub,IMax+4,JMax+3,KMax+3)call DAs(daub,u0p,u0pl,u0)
> With the subroutines as:
> SUBROUTINE CDA3(da3d,dim3dx,dim3dy,dim3dz) DM, intent(inout) :: da3d PetscInt, intent(in) :: dim3dx,dim3dy,dim3dz DMBoundaryType :: bx,by,bz bx = DM_BOUNDARY_NONE by = DM_BOUNDARY_NONE bz = DM_BOUNDARY_NONE call DMDACreate3d(PETSC_COMM_WORLD,bx,by,bz,DMDA_STENCIL_BOX,dim3dx,dim3dy,dim3dz,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da3d,ierr) call DMSetFromOptions(da3d,ierr) call DMSetUp(da3d,ierr) END SUBROUTINE CDA3 SUBROUTINE DAs(da,globalv,localv,array) ! use PetscObjects, only :: ierr ! Umbrella program to update and communicate the arrays in a ! distributed fashion using the DMDA objects from PETSc. ! Manuel Valera 1/20/17 ! Arguments: ! da = DMDA array either 1d,2d or 3d, already created and setup ! globalv = global vector to be operated into ! localv = local chunk each processor works in. ! array = the array to be petscified. ONLY 3D ARRAYS rn. ! just in case. Vec,intent(inout) :: globalv,localv PetscScalar,dimension(:,:,:) :: array DM,intent(inout) :: da call DMCreateGlobalVector(da,globalv,ierr) call DMCreateLocalVector(da,localv,ierr) call DMGlobalToLocalBegin(da,globalv,INSERT_VALUES,localv,ierr) call DMGlobalToLocalEnd(da,globalv,INSERT_VALUES,localv,ierr) END SUBROUTINE DAs
> Which i later open into an array to operate into it, but when i try to access u0(:,j-2,:) it gives me the following error:
> Fortran runtime error: Index '-1' of dimension 2 of array 'u0' below lower bound of 0
> So i'm guessing the DMDA is creating the arrays with dimensions starting at 0 instead of -1 as it should, right? what can be done in this case?
1) The DMDA only takes sizes, not index bounds, in the constructor.
2) Its not the DMDA you must be talking about, but the array you get from
DMDAVecGetArrayF90() or VecGetArrayF90()
3) The VecGetArrayF90() always start from 0 since it is indexed in local
indices
4) The DMDVecGetArrayF90() arrays are indexed by global indices for the
patch your process owns (including ghosts if its a local vector)
Matt
> Thanks,
> Manuel
> On Sat, Feb 4, 2017 at 4:18 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> See: http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
>> search for DMDACreate and update your code.
>> Barry
>> > On Feb 4, 2017, at 6:02 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>> wrote:
>> > Hello devs,
>> > Ive been creating the framework to distribute the arrays from my model
>> using the global/local vectors and the DMDAs, for this i created a small
>> subroutine that is responsible for making the necessary calls:
>> > SUBROUTINE DAs(da,globalv,localv)
>> > ! Arguments:
>> > END SUBROUTINE DAs
>> > I call this from another program where i have declared a vector as:
>> > #include "petsc/finclude/petscdm.h"
>> > #include "petsc/finclude/petscdmda.h"
>> > use petsc
>> > use petscdm
>> > use petscdmda
>> > IMPLICIT NONE
>> > Vec :: xpdmda,yp,zp,xcp,ycp,zcp
>> > DM :: da,dac,dau,dav,daw
>> > CONTAINS
>> > SUBROUTINE InitGridP
>> > IMPLICIT NONE
>> > !PetscInt :: ierr
>> > ! CREATE DMDA:
>> > call CDA3(da,IMax-1,JMax-1,KMax-1)
>> > !xpdmda,yp,zp have the same dimensions than x,y,z
>> > !xpl,ypl,zpl are the local versions of xp,yp,zp
>> > !We create the global and local vectors and communicate their values:
>> > call DAs(da,xpdmda,xpl,x)
>> > And at this call it crashes with the following message:
>> > [0]PETSC ERROR: --------------------- Error Message
>> > [0]PETSC ERROR: Null argument, when expecting valid pointer
>> > [0]PETSC ERROR: Null Object: Parameter # 2
>> > [0]PETSC ERROR: See
>> > http://www.mcs.anl.gov/petsc/documentation/faq.html
>> > for trouble shooting.
>> > [0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-2949-gc3c607c
>> GIT Date: 2017-01-20 17:34:16 -0600
>> > [0]PETSC ERROR: ./ucmsLEP on a arch-linux2-c-debug named ocean by
>> valera Sat Feb 4 15:53:53 2017
>> > [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran --download-fblaslapack --download-mpich --download-hdf5
>> --download-netcdf --download-hypre --download-metis --download-parmetis
>> --download-trillinos --with-debugging=1
>> > [0]PETSC ERROR: #3 VecSetLocalToGlobalMapping() line 79 in
>> /usr/dataC/home/valera/petsc/src/vec/vec/interface/vector.c
>> > [0]PETSC ERROR: #4 DMCreateGlobalVector_DA() line 41 in
>> /usr/dataC/home/valera/petsc/src/dm/impls/da/dadist.c
>> > [0]PETSC ERROR: #5 DMCreateGlobalVector() line 840 in
>> /usr/dataC/home/valera/petsc/src/dm/interface/dm.c
>> > So my question is, do i have to setup the vectors in any additional
>> way? i followed the fortran DMDA examples closely and i didnt notice
>> anything extra,
>> > Thanks,
>> > Manuel
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170204/fef7c13e/attachment-0001.html>
