[petsc-users] DMCreateGlobalVector in fortran.
Manuel Valera
mvalera at mail.sdsu.edu
Sat Feb 4 19:30:21 CST 2017
Thanks, that helped a lot,
Now im a little confused with my next error, in my serial code i have
several arrays with dimensions declared as:
u0(-1:IMax+2,-1:JMax+1,-1:KMax+1)
and i create my DMDA for this array as:
call CDA3(daub,IMax+4,JMax+3,KMax+3)call DAs(daub,u0p,u0pl,u0)
With the subroutines as:
SUBROUTINE CDA3(da3d,dim3dx,dim3dy,dim3dz) DM, intent(inout)
:: da3d PetscInt, intent(in) :: dim3dx,dim3dy,dim3dz
DMBoundaryType :: bx,by,bz bx = DM_BOUNDARY_NONE
by = DM_BOUNDARY_NONE bz = DM_BOUNDARY_NONE call
DMDACreate3d(PETSC_COMM_WORLD,bx,by,bz,DMDA_STENCIL_BOX,dim3dx,dim3dy,dim3dz,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,da3d,ierr)
call DMSetFromOptions(da3d,ierr) call DMSetUp(da3d,ierr)
END SUBROUTINE CDA3 SUBROUTINE DAs(da,globalv,localv,array) !
use PetscObjects, only :: ierr ! Umbrella program to update and
communicate the arrays in a ! distributed fashion using the DMDA
objects from PETSc. ! Manuel Valera 1/20/17 ! Arguments:
! da = DMDA array either 1d,2d or 3d, already created and setup
! globalv = global vector to be operated into ! localv =
local chunk each processor works in. ! array = the array to be
petscified. ONLY 3D ARRAYS rn. ! just in case.
Vec,intent(inout) :: globalv,localv
PetscScalar,dimension(:,:,:) :: array
DM,intent(inout) :: da call
DMCreateGlobalVector(da,globalv,ierr) call
DMCreateLocalVector(da,localv,ierr) call
DMGlobalToLocalBegin(da,globalv,INSERT_VALUES,localv,ierr) call
DMGlobalToLocalEnd(da,globalv,INSERT_VALUES,localv,ierr) END
SUBROUTINE DAs
Which i later open into an array to operate into it, but when i try to
access u0(:,j-2,:) it gives me the following error:
Fortran runtime error: Index '-1' of dimension 2 of array 'u0' below
lower bound of 0
So i'm guessing the DMDA is creating the arrays with dimensions
starting at 0 instead of -1 as it should, right? what can be done in
this case?
Manuel
On Sat, Feb 4, 2017 at 4:18 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> See: http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
> search for DMDACreate and update your code.
> Barry
> > On Feb 4, 2017, at 6:02 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> > Hello devs,
> > Ive been creating the framework to distribute the arrays from my model
> using the global/local vectors and the DMDAs, for this i created a small
> subroutine that is responsible for making the necessary calls:
> > SUBROUTINE DAs(da,globalv,localv)
> > ! use PetscObjects, only :: ierr
> > ! Umbrella program to update and communicate the arrays in a
> > ! distributed fashion using the DMDA objects from PETSc.
> > ! Arguments:
> > ! localv = local chunk each processor works in.
> > call DMCreateGlobalVector(da,globalv,ierr)
> > call DMCreateLocalVector(da,localv,ierr)
> > call DMGlobalToLocalBegin(da,globalv,INSERT_VALUES,localv,ierr)
> > call DMGlobalToLocalEnd(da,globalv,INSERT_VALUES,localv,ierr)
> > END SUBROUTINE DAs
> > I call this from another program where i have declared a vector as:
> > #include "petsc/finclude/petscdm.h"
> > #include "petsc/finclude/petscdmda.h"
> > use petsc
> > use petscdm
> > use petscdmda
> > IMPLICIT NONE
> > Vec :: xpdmda,yp,zp,xcp,ycp,zcp
> > DM :: da,dac,dau,dav,daw
> > CONTAINS
> > SUBROUTINE InitGridP
> > IMPLICIT NONE
> > !PetscInt :: ierr
> > ! CREATE DMDA:
> > call CDA3(da,IMax-1,JMax-1,KMax-1)
> > !xpdmda,yp,zp have the same dimensions than x,y,z
> > !xpl,ypl,zpl are the local versions of xp,yp,zp
> > !We create the global and local vectors and communicate their values:
> > call DAs(da,xpdmda,xpl,x)
> > And at this call it crashes with the following message:
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Null argument, when expecting valid pointer
> > [0]PETSC ERROR: Null Object: Parameter # 2
> > [0]PETSC ERROR: See
> > http://www.mcs.anl.gov/petsc/documentation/faq.html
> > for trouble shooting.
> > [0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-2949-gc3c607c
> GIT Date: 2017-01-20 17:34:16 -0600
> > [0]PETSC ERROR: ./ucmsLEP on a arch-linux2-c-debug named ocean by valera
> Sat Feb 4 15:53:53 2017
> > [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack --download-mpich --download-hdf5
> --download-netcdf --download-hypre --download-metis --download-parmetis
> --download-trillinos --with-debugging=1
> > [0]PETSC ERROR: #3 VecSetLocalToGlobalMapping() line 79 in
> /usr/dataC/home/valera/petsc/src/vec/vec/interface/vector.c
> > [0]PETSC ERROR: #4 DMCreateGlobalVector_DA() line 41 in
> /usr/dataC/home/valera/petsc/src/dm/impls/da/dadist.c
> > [0]PETSC ERROR: #5 DMCreateGlobalVector() line 840 in
> /usr/dataC/home/valera/petsc/src/dm/interface/dm.c
> > So my question is, do i have to setup the vectors in any additional way?
> i followed the fortran DMDA examples closely and i didnt notice anything
> extra,
> > Thanks,
> > Manuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170204/b9be3df7/attachment.html>
