[petsc-users] projection methods in TS
Gideon Simpson
gideon.simpson at gmail.com
Sat Feb 4 09:47:58 CST 2017
Would setting it up as a DAE in petsc be algorithmically euivalent to a projected method (i.e., step of standard RK followed by nonlinear projection)?
-gideon
> On Feb 3, 2017, at 11:47 PM, Matthew Knepley <knepley at gmail.com> wrote:
> That is one answer. Another one is that this particular system is a DAE and we have methods for that.
> Matt
> On Fri, Feb 3, 2017 at 8:40 PM, Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
> TSSetPostStep(); in your function use TSGetSolution() to get the current solution.
> Please let us know how it works out
> Barry
> > On Feb 3, 2017, at 7:14 PM, Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> wrote:
> > I’m interested in implementing a projection method for an ODE of the form:
> > y’ = f(y),
> > such that g(y) = 0 for all time (i.e., g is conserved). Note that in a projection method, a standard time step is made to produce y* from y_{n}, and then this is corrected to obtain y_{n+1} satisfying g(y) = 0.
> > There were two ways I was thinking of doing this, and I was hoping to get some input:
> > Idea 1: Manually loop through using taking a time step and then implementing the projection routine. I see that there is a TSStep command, but this doesn’t seem to be much documentation on how to use it in this scenario. Does anyone have any guidance?
> > Idea 2: Is there some analog to TSMonitor that allows me to modify the solution after each time step, instead of just allowing for some computation of a statistic?
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170204/c60a8036/attachment.html>
