[petsc-users] projection methods in TS
Matthew Knepley
knepley at gmail.com
Fri Feb 3 22:47:09 CST 2017
That is one answer. Another one is that this particular system is a DAE and
we have methods for that.
Matt
On Fri, Feb 3, 2017 at 8:40 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> TSSetPostStep(); in your function use TSGetSolution() to get the current
> solution.
> Please let us know how it works out
> Barry
> > On Feb 3, 2017, at 7:14 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
> > I’m interested in implementing a projection method for an ODE of the
> form:
> > y’ = f(y),
> > such that g(y) = 0 for all time (i.e., g is conserved). Note that in a
> projection method, a standard time step is made to produce y* from y_{n},
> and then this is corrected to obtain y_{n+1} satisfying g(y) = 0.
> > There were two ways I was thinking of doing this, and I was hoping to
> get some input:
> > Idea 1: Manually loop through using taking a time step and then
> implementing the projection routine. I see that there is a TSStep command,
> but this doesn’t seem to be much documentation on how to use it in this
> scenario. Does anyone have any guidance?
> > Idea 2: Is there some analog to TSMonitor that allows me to modify the
> solution after each time step, instead of just allowing for some
> computation of a statistic?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170203/9846571e/attachment.html>
