[petsc-users] ASM with matrix-free method
    Matthew Knepley
    knepley at gmail.com
    Thu Feb  2 09:02:40 CST 2017
On Thu, Feb 2, 2017 at 8:55 AM, Sonia Pozzi <sonia.pozzi at usi.ch> wrote:
> Dear Barry,
> At the moment I’m dealing with the following problem.
> Suppose I want to solve Sx=b, where is a product of matrices. In
> particular inside it contains also an inverse of a matrix.
> To compute the action of S I have created a shell matrix, but know I would
> like to apply the ASM as preconditioner.
Are you using a Schur complement? Have you looked at
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/MatCreateSchurComplement.html
> Citing your words as answer to a previous similar question:
> *Thu Jan 13 13:14:47 CST 2011*
> *Is it possible use ASM and/or FieldSplit with a matrix-free method?*
> "Yes, BUT the algorithms are coded around MatGetSubMatrix() and or MatGetSubMatrices() so to do matrix free you need to have code that applies "part" of the operator at a time (that is you cannot just have a matrix vector product that applies the entire operator to the entire vector. Once you have the ability to apply "part" of the operator at a time you need to code up a MATSHELL that responds appropriately to MatGetSubMatrix() and or MatGetSubMatrices() and returns new matrix-free shell matrices that apply only "their" part of the operator. This is non-trivial for many people but possible."
> Could you be so kind to explain me better how, or do you have some code
> that is doing something similar?
> ASM says "I will take a block of your operator and invert it", but we do
not know how to take a block of your MATSHELL
because it only provides the action on a vector. You could
  a) Also provide MatGetSubmatrix() or MAtGetSubmatrices() for your
MATSHELL as Barry says
  b) Make a matrix M that is an approximation to your MATSHELL, perhaps
using the block diagonal portions of the inverse
      so that you can explicitly give the values. Then pass M in as the
preconditioner matrix for the solver.
  c) Use Chebyshev or some matrix-free preconditioner instead of ASM
    Matt
> Regards,
> Sonia
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170202/db34e08a/attachment-0001.html>
