[petsc-users] local to global mapping for DMPlex
    Matthew Knepley
    knepley at gmail.com
    Tue Dec 19 10:50:46 CST 2017
On Tue, Dec 19, 2017 at 11:40 AM, Yann JOBIC <yann.jobic at univ-amu.fr> wrote:
> Hello,
> We want to extract the cell connectivity from a DMPlex. We have no problem
> for a sequential run.
Do you want it on disk? If so, you can just DMView() for HDF5. That outputs
the connectivity in a global numbering.
I can show you the calls I use inside if you want. I usually put
  DMViewFromOptions(dm, NULL, "-dm_view")
Then
  -dm_view hdf5:mesh.h5
    Matt
> However for parallel ones, we need to get the node numbering in the global
> ordering, as when we distribute the mesh, we only have local nodes, and
> thus local numbering.
> It seems that we should use DMGetLocalToGlobalMapping (we are using
> Fortran with Petsc 3.8p3). However, we get the running error :
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: DM can not create LocalToGlobalMapping
> Is it the right way to do it ?
> Many thanks,
> Regards,
> Yann
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171219/ab47863c/attachment.html>
