[petsc-users]  configure fails with batch+scalapack
    Santiago Andres Triana
    repepo at gmail.com
    Sun Dec 17 14:29:17 CST 2017
Dear petsc-users,
I'm trying to install petsc in a cluster that uses a job manager.  This is
the configure command I use:
./configure --known-mpi-shared-libraries=1 --with-scalar-type=complex
--with-mumps=1 --download-mumps --download-parmetis
--with-blaslapack-dir=/sw/sdev/intel/psxe2015u3/composer_xe_2015.3.187/mkl
--download-metis --with-scalapack=1 --download-scalapack --with-batch
This fails when including the option --with-batch together with
--download-scalapack:
             Configuring PETSc to compile on your system
TESTING: check from
config.libraries(config/BuildSystem/config/libraries.py:158)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Unable to find scalapack in default locations!
Perhaps you can specify with --with-scalapack-dir=<directory>
If you do not want scalapack, then give --with-scalapack=0
You might also consider using --download-scalapack instead
However, if I omit the --with-batch option, the configure script manages to
succeed (it downloads and compiles scalapack; the install fails later at
the make debug because of the job manager). Any help or suggestion is
highly appreciated. Thanks in advance!
Andres
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171217/11f9004c/attachment.html>
