[petsc-users] Parallel dense solve with submatrices
Matthew Knepley
knepley at gmail.com
Mon Aug 28 16:10:03 CDT 2017
Hi Sherry,
Did you guys have a standard PETSc example that you run to test the
interface? Should I be asking someone else?
Matt
On Mon, Aug 28, 2017 at 10:24 AM, Toon Weyens <weyenst at gmail.com> wrote:
> Hey, as indicated here: https://www.mcs.anl.gov/petsc/petsc-dev/docs/
> manualpages/Mat/MatSTRUMPACKSetHSSMinSize.html
> there is an example in src/ksp/ksp/examples/tutorials/ex52.c.html
> <https://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex52.c.html>
> However, in my 3.7.6 distribution ex52.c does not have lines 29-31:
> 29: #if defined(PETSC_HAVE_STRUMPACK) 30: PetscBool <https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscBool.html#PetscBool> flg_strumpack=PETSC_FALSE <https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PETSC_FALSE.html#PETSC_FALSE>; 31: #endif
> On Mon, Aug 28, 2017 at 4:01 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Aug 28, 2017 at 9:17 AM, Toon Weyens <weyenst at gmail.com> wrote:
>>> Very interesting! I might try this afterwards, with H2lib.
>>> Also, I must say that the strumpack interface looks promising. What did
>>> you mean by "only for the sparse part", by the way? Also, any idea when it
>>> is going to be released in an official petsc release, preferably with some
>>> documentation?
>> I thought STRUMPACK was in 3.7.6
>> Matt
>>> Thanks!
>>> On Mon, Aug 28, 2017 at 12:15 PM Jose E. Roman <jroman at dsic.upv.es>
>>> wrote:
>>>> > El 28 ago 2017, a las 10:15, Toon Weyens <weyenst at gmail.com>
>>>> escribió:
>>>> > Thank you Barry, that explains why I couldn't find information about
>>>> it. I am now going to implement this straight-forward implementation as a
>>>> first step.
>>>> > In the long term it would in any case be useful to have a solver that
>>>> uses H-matrices, such as H2lib.
>>>> > Is there any chance Petsc is thinking about moving to this kind of
>>>> matrices as well in the future?
>>>> You can use H2lib in a PETSc program by wrapping it in a shell matrix.
>>>> We did this some time ago https://doi.org/10.1016/j.cam.2012.07.021
>>>> Also, PETSc has an interface to STRUMPACK, but only to the sparse part
>>>> and I guess what you need is the dense part.
>>>> Jose
>> experiments lead.
>> -- Norbert Wiener
>> http://www.caam.rice.edu/~mk51/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170828/6c74dcd4/attachment-0001.html>
