[petsc-users] Parallel dense solve with submatrices
Toon Weyens
weyenst at gmail.com
Mon Aug 28 09:24:07 CDT 2017
Hey, as indicated here:
https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatSTRUMPACKSetHSSMinSize.html
there is an example in src/ksp/ksp/examples/tutorials/ex52.c.html
<https://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex52.c.html>
However, in my 3.7.6 distribution ex52.c does not have lines 29-31:
29: #if defined(PETSC_HAVE_STRUMPACK) 30: PetscBool
<https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscBool.html#PetscBool>
flg_strumpack=PETSC_FALSE
<https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PETSC_FALSE.html#PETSC_FALSE>;
31: #endif
On Mon, Aug 28, 2017 at 4:01 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 28, 2017 at 9:17 AM, Toon Weyens <weyenst at gmail.com> wrote:
>> Very interesting! I might try this afterwards, with H2lib.
>> Also, I must say that the strumpack interface looks promising. What did
>> you mean by "only for the sparse part", by the way? Also, any idea when it
>> is going to be released in an official petsc release, preferably with some
>> documentation?
> I thought STRUMPACK was in 3.7.6
> Matt
>> Thanks!
>> On Mon, Aug 28, 2017 at 12:15 PM Jose E. Roman <jroman at dsic.upv.es>
>> wrote:
>>> > El 28 ago 2017, a las 10:15, Toon Weyens <weyenst at gmail.com> escribió:
>>> > Thank you Barry, that explains why I couldn't find information about
>>> it. I am now going to implement this straight-forward implementation as a
>>> first step.
>>> > In the long term it would in any case be useful to have a solver that
>>> uses H-matrices, such as H2lib.
>>> > Is there any chance Petsc is thinking about moving to this kind of
>>> matrices as well in the future?
>>> You can use H2lib in a PETSc program by wrapping it in a shell matrix.
>>> We did this some time ago https://doi.org/10.1016/j.cam.2012.07.021
>>> Also, PETSc has an interface to STRUMPACK, but only to the sparse part
>>> and I guess what you need is the dense part.
>>> Jose
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170828/7088429c/attachment.html>
