[petsc-users] MatMult performance on baij vs aij
Karl Rupp rupp at iue.tuwien.ac.at
Thu Aug 24 12:38:33 CDT 2017
> For the same sparse matrix, will the storage format (baij or aij) have a
> noticeable performance effect on MatMult give the baij may have a
>   better locality?
The gains are mostly due to the reduced number of indices loaded from
memory. For normal aij, each floating point number (typically 8 bytes)
requires an index (typically 4 bytes, unless you use 64 bit indices).
With baij you only need one index per block. For example, if your block
size is 3x3, only one index for 9 floating point numbers is needed.
Thus, your performance gains are not going to be dramatic, but still... :-)
Best regards,
Karli
