[petsc-users] Petsc with OpenMP
Khai Pham
khaipham at mit.edu
Thu Aug 24 04:12:03 CDT 2017
Hi Danyang,
Thank you for the information.
Khai
Sent: Wednesday, August 23, 2017 12:52 PM
To: Khai Pham; PETSc
Subject: Re: [petsc-users] Petsc with OpenMP
Hi Khai,
I finally implemented LIS solver (linear algebra library, http://www.ssisc.org/lis/index.en.html) to support the OpenMP and hybrid MPI-OpenMP since the old PETSc version with OpenMP is not officially supported any more. LIS is pretty easy to be implemented if you have already implemented PETSc. You can still use PETSc DMDA to do domain decomposition but just replace the linear solver for the hybrid version.
Danyang
On 17-08-23 03:42 AM, Khai Pham wrote:
Hi All,
I searched for the information about Petsc with OpenMP support. I came cross Danyang Su question a couple of month ago at https://lists.mcs.anl.gov/pipermail/petsc-users/2017-June/032975.htmlhttps://lists.mcs.anl.gov/pipermail/petsc-users/2017-June/032975.html . I tried to configure Petsc version 3.5.4 but it said that "Please use petsc master (git branch) for OpenMP functionality". As Barry mentioned, one has to use an older version of petsc for OpenMp support. Could you please tell me what the the last version of petsc which supports OpenMP? Thanks!
Best,
Khai
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170824/0e93d554/attachment.html>
