[petsc-users] Petsc with OpenMP
Danyang Su danyang.su at gmail.com
Wed Aug 23 11:52:53 CDT 2017
Hi Khai,
I finally implemented LIS solver (linear algebra library,
http://www.ssisc.org/lis/index.en.html) to support the OpenMP and hybrid
MPI-OpenMP since the old PETSc version with OpenMP is not officially
supported any more. LIS is pretty easy to be implemented if you have
already implemented PETSc. You can still use PETSc DMDA to do domain
decomposition but just replace the linear solver for the hybrid version.
Danyang
On 17-08-23 03:42 AM, Khai Pham wrote:
> Hi All,
> I searched for the information about Petsc with OpenMP support. I came
> cross Danyang Su question a couple of month ago
> at https://lists.mcs.anl.gov/pipermail/petsc-users/2017-June/032975.htmlhttps://lists.mcs.anl.gov/pipermail/petsc-users/2017-June/032975.html .
> I tried to configure Petsc version 3.5.4 but it said that "Please use
> petsc master (git branch) for OpenMP functionality". As Barry
> mentioned, one has to use an older version of petsc for OpenMp
> support. Could you please tell me what the the last version of petsc
> which supports OpenMP? Thanks!
> Best,
> Khai
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170823/dff762c7/attachment-0001.html>
