[petsc-users] Petsc ILU PC Change between 3.6.4 and 3.7.x?
Thu Aug 24 02:34:56 CDT 2017
On Thu, Aug 24, 2017 at 2:29 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Matt,
> Thanks, I can understand the lower condition number of P A, but
> what about r? Doesn't that change to P r and if so why can we
> assume that ||r|| and ||P r|| have the same order?
r and Pr are the things we can control. We make them whatever we want.
   Matt
> Chris
> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
> MARIN | T +31 317 49 33 44 <+31%20317%20493%20344> | C.Klaij at marin.nl |
> www.marin.nl
> [image: LinkedIn] <https://www.linkedin.com/company/marin> [image:
> YouTube] <http://www.youtube.com/marinmultimedia> [image: Twitter]
> <https://twitter.com/MARIN_nieuws> [image: Facebook]
> <https://www.facebook.com/marin.wageningen>
> MARIN news: New C-DRONE - for undisturbed wave spectrum measurements
> <http://www.marin.nl/web/News/News-items/New-CDRONE-for-undisturbed-wave-spectrum-measurements-1.htm>
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Wednesday, August 23, 2017 8:37 AM
> *To:* Barry Smith
> *Cc:* Klaij, Christiaan; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Petsc ILU PC Change between 3.6.4 and 3.7.x?
> On Wed, Aug 23, 2017 at 2:30 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>    Some argue that the preconditioned residual is "closer to" the norm of
>> the error than the unpreconditioned norm. I don't have a solid mathematical
>> reason to prefer left preconditioning with the preconditioned norm.
> Because you have || x - x_exact || < k(A) || r ||
> where r is the residual and k is the condition number of A. If instead of
> A you use P A, which we assume has a lower condition number, then
> this bound is improved.
>   Thanks,
>      Matt
>>    Barry
>> > On Aug 22, 2017, at 11:27 PM, Klaij, Christiaan <C.Klaij at marin.nl>
>> wrote:
>> > Barry,
>> > Thanks for the explanation.
>> > We do have some rare cases that give false convergence, but
>> > decided to use
>> > CALL KSPSetNormType(ksp,KSP_NORM_UNPRECONDITIONED,ierr)
>> > so that convergence is always based on the true residual. Our
>> > results are much more consistent now. So that could have been
>> > your protection against the rare case as well, right? Why do you
>> > prefer left preconditioning?
>> > Chris
>> > MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl |
>> http://www.marin.nl
>> > MARIN news: http://www.marin.nl/web/News/N
>> ews-items/BlueWeek-October-911-Rostock.htm
>> > ________________________________________
>> > From: Barry Smith <bsmith at mcs.anl.gov>
>> > Sent: Tuesday, August 22, 2017 6:25 PM
>> > To: Klaij, Christiaan
>> > Cc: petsc-users at mcs.anl.gov
>> > Subject: Re: [petsc-users] Petsc ILU PC Change between 3.6.4 and 3.7.x?
>> >> On Aug 22, 2017, at 6:49 AM, Klaij, Christiaan <C.Klaij at marin.nl>
>> wrote:
>> >> We also faced this problem in our code. So I've added:
>> >> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sub_pc_factor_shift
>> _type","nonzero",ierr)
>> >> since there seems to be no setter function for this (correct me
>> >> if I'm wrong). Then everythings fine again.
>> >> Out of curiosity, what was the reason to change the default
>> >> behaviour?
>> >   The reason we changed this is that we would rather have a failure
>> that makes the user aware of a serious problem then to produce "garbage"
>> results. In some rare cases the shift can cause a huge jump in the
>> preconditioned residual which then decreases rapidly while the true
>> residual does not improve. This results in the KSP thinking it has
>> converged while in fact it has essentially garbage for an answer. Under the
>> previous model, where we shifted by default, users would in this rare case
>> think they had reasonable solutions when they did not.
>> >   For many users, such as yourself, the previous default behavior was
>> fine because you didn't have the "rare case" but we decided it was best to
>> protect against the rare case even though it would require other users such
>> as yourself to add the option.
>> >   Barry
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170824/2d49790a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170824/2d49790a/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170824/2d49790a/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170824/2d49790a/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170824/2d49790a/attachment-0007.png>
