[petsc-users] EPS monitor
Kong, Fande
fande.kong at inl.gov
Wed Aug 16 15:19:23 CDT 2017
Solver details:
EPS Object: 1 MPI processes
type: jd
search subspace is orthogonalized
block size=1
type of the initial subspace: non-Krylov
size of the subspace after restarting: 6
number of vectors after restarting from the previous iteration: 1
problem type: generalized non-symmetric eigenvalue problem
extraction type: harmonic Ritz
selected portion of the spectrum: smallest eigenvalues in magnitude
number of eigenvalues (nev): 1
number of column vectors (ncv): 18
maximum dimension of projected problem (mpd): 18
maximum number of iterations: 10000
tolerance: 0.0001
convergence test: relative to the eigenvalue
BV Object: 1 MPI processes
type: svec
18 columns of global length 4225
vector orthogonalization method: classical Gram-Schmidt
orthogonalization refinement: if needed (eta: 0.7071)
block orthogonalization method: Gram-Schmidt
doing matmult as a single matrix-matrix product
DS Object: 1 MPI processes
type: gnhep
ST Object: 1 MPI processes
type: precond
shift: 0.
number of matrices: 2
all matrices have different nonzero pattern
KSP Object: (st_) 1 MPI processes
type: bcgsl
Ell = 2
Delta = 0
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: (st_) 1 MPI processes
type: jacobi
linear system matrix = precond matrix:
Mat Object: () 1 MPI processes
type: seqaij
rows=4225, cols=4225
total: nonzeros=37249, allocated nonzeros=37249
total number of mallocs used during MatSetValues calls =0
not using I-node routines
On Wed, Aug 16, 2017 at 2:12 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> > El 16 ago 2017, a las 21:36, Kong, Fande <fande.kong at inl.gov> escribió:
> > Hi All,
> > How to understand the following messages:
> > 1 EPS nconv=0 first unconverged value (error) 2.06312 (3.29164033e-01)
> > 2 EPS nconv=0 first unconverged value (error) 2.03951 (1.76223074e-01)
> > 3 EPS nconv=0 first unconverged value (error) 2.01177 (5.71109559e-02)
> > 4 EPS nconv=0 first unconverged value (error) 2.01042 (4.84609300e-02)
> > 5 EPS nconv=0 first unconverged value (error) 2.00708 (3.19917457e-02)
> > 6 EPS nconv=0 first unconverged value (error) 2.00595 (2.62792109e-02)
> > 7 EPS nconv=0 first unconverged value (error) 2.00504 (2.13766150e-02)
> > 8 EPS nconv=0 first unconverged value (error) 2.00441 (1.85066774e-02)
> > 9 EPS nconv=0 first unconverged value (error) 2.00397 (1.73188449e-02)
> > 10 EPS nconv=0 first unconverged value (error) 2.00366 (1.54528517e-02)
> > 11 EPS nconv=0 first unconverged value (error) 2.00339 (1.32215899e-02)
> > 12 EPS nconv=0 first unconverged value (error) 2.00316 (1.32215899e-02)
> > 13 EPS nconv=0 first unconverged value (error) 2.00316 (1.17928920e-02)
> > 14 EPS nconv=0 first unconverged value (error) 2.00297 (1.04964387e-02)
> > 15 EPS nconv=0 first unconverged value (error) 2.0028 (9.58244972e-03)
> > 16 EPS nconv=0 first unconverged value (error) 2.00268 (9.06634973e-03)
> > 17 EPS nconv=0 first unconverged value (error) 2.00198 (3.43444441e-04)
> > 18 EPS nconv=1 first unconverged value (error) 2.25718 (1.79769313e+308)
> > 18 EPS converged value (error) #0 2.00197 (5.69451918e-09)
> > When the solver converged, the wrong eigenvalue and the wrong residual
> are printed out. Do we design like this way?
> > Fande,
> Is this the POWER solver? Most solvers in EPS approximate several
> eigenvalues simultaneously, but this is not the case in POWER - when one
> eigenvalue converges there is no approximation available for the next one.
> I will think about a simple fix.
> Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170816/d381b08c/attachment.html>
