[petsc-users] DMPlex problem
Matthew Knepley
knepley at gmail.com
Mon Sep 26 07:19:07 CDT 2016
On Mon, Sep 26, 2016 at 7:00 AM, Morten Nobel-Jørgensen <mono at dtu.dk> wrote:
> Hi Matthew
> It seems like the problem is not fully fixed. I have changed the code to
> now run on with both 2,3 and 4 cells. When I run the code using NP = 1..3 I
> get different result both for NP=1 to NP=2/3 when cell count is larger than
> 2.
Do you mean the trace? I have no idea what you are actually putting in.
I have a lot of debugging when you use, MatSetValuesClosure(), but when you
directly use
MatSetValuesLocal(), you are handling things yourself.
Matt
> Kind regards,
> Morten
> ____
> mpiexec -np 1 ./ex18k
> cells 2
> Loc size: 36
> Trace of matrix: 132.000000
> cells 3
> Loc size: 48
> Trace of matrix: 192.000000
> cells 4
> Loc size: 60
> Trace of matrix: 258.000000
> mpiexec -np 2 ./ex18k
> cells 2
> Loc size: 24
> Loc size: 24
> cells 3
> Loc size: 36
> Loc size: 24
> Trace of matrix: 198.000000
> cells 4
> Loc size: 36
> Loc size: 36
> Trace of matrix: 264.000000
> mpiexec -np 3 ./ex18k
> cells 2
> Loc size: 24
> Loc size: 24
> Loc size: 0
> cells 3
> Loc size: 24
> Loc size: 24
> Loc size: 24
> cells 4
> Loc size: 36
> Loc size: 24
> Loc size: 24
> *From:* petsc-users-bounces at mcs.anl.gov [petsc-users-bounces at mcs.anl.gov]
> on behalf of Morten Nobel-Jørgensen [mono at dtu.dk]
> *Sent:* Sunday, September 25, 2016 11:15 AM
> *To:* Matthew Knepley
> *Cc:* PETSc [petsc-users at mcs.anl.gov]
> *Subject:* Re: [petsc-users] DMPlex problem
> Hi Matthew
> Thank you for the bug-fix :) I can confirm that it works :)
> And thanks for your hard work on PETSc - your work is very much
> appreciated!
> Kind regards,
> Morten
> *From:* Matthew Knepley [knepley at gmail.com]
> *Sent:* Friday, September 23, 2016 2:46 PM
> *To:* Morten Nobel-Jørgensen
> On Fri, Sep 23, 2016 at 7:45 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Fri, Sep 23, 2016 at 3:48 AM, Morten Nobel-Jørgensen <mono at dtu.dk>
>> wrote:
>>> Dear PETSc developers
>>> Any update on this issue regarding DMPlex? Or is there any obvious
>>> workaround that we are unaware of?
>> I have fixed this bug. It did not come up in nightly tests because we are
>> not using MatSetValuesLocal(). Instead we
>> use MatSetValuesClosure() which translates differently.
>> Here is the branch
>> https://bitbucket.org/petsc/petsc/branch/knepley/fix-dm-ltog-bs
>> and I have merged it to next. It will go to master in a day or two.
> Also, here is the cleaned up source with no memory leaks.
> Matt
>> Also should we additionally register the issue on Bitbucket or is
>>> reporting the issue on the mailing list enough?
>> Normally we are faster, but the start of the semester was hard this year.
>> Thanks,
>> Matt
>>> Kind regards,
>>> Morten
>>> *Sent:* Friday, September 09, 2016 12:21 PM
>>> On Fri, Sep 9, 2016 at 4:04 AM, Morten Nobel-Jørgensen <mono at dtu.dk>
>>> wrote:
>>>> Dear PETSc developers and users,
>>>> Last week we posted a question regarding an error with DMPlex and
>>>> multiple dofs and have not gotten any feedback yet. This is uncharted
>>>> waters for us, since we have gotten used to an extremely fast feedback from
>>>> the PETSc crew. So - with the chance of sounding impatient and ungrateful -
>>>> we would like to hear if anybody has any ideas that could point us in the
>>>> right direction?
>>> This is my fault. You have not gotten a response because everyone else
>>> was waiting for me, and I have been
>>> slow because I just moved houses at the same time as term started here.
>>> Sorry about that.
>>> The example ran for me and I saw your problem. The local-tp-global map
>>> is missing for some reason.
>>> I am tracking it down now. It should be made by DMCreateMatrix(), so
>>> this is mysterious. I hope to have
>>> this fixed by early next week.
>>> Thanks,
>>> Matt
>>>> We have created a small example problem that demonstrates the error in
>>>> the matrix assembly.
>>>> Thanks,
>>>> Morten
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160926/054ac934/attachment-0001.html>
