[petsc-users] DMPlex problem
Morten Nobel-Jørgensen mono at dtu.dk
Mon Sep 26 07:00:10 CDT 2016
Hi Matthew
It seems like the problem is not fully fixed. I have changed the code to now run on with both 2,3 and 4 cells. When I run the code using NP = 1..3 I get different result both for NP=1 to NP=2/3 when cell count is larger than 2.
Kind regards,
Morten
____
mpiexec -np 1 ./ex18k
cells 2
Loc size: 36
Trace of matrix: 132.000000
cells 3
Loc size: 48
Trace of matrix: 192.000000
cells 4
Loc size: 60
Trace of matrix: 258.000000
mpiexec -np 2 ./ex18k
cells 2
Loc size: 24
Loc size: 24
cells 3
Loc size: 36
Loc size: 24
Trace of matrix: 198.000000
cells 4
Loc size: 36
Loc size: 36
Trace of matrix: 264.000000
mpiexec -np 3 ./ex18k
cells 2
Loc size: 24
Loc size: 24
Loc size: 0
cells 3
Loc size: 24
Loc size: 24
Loc size: 24
cells 4
Loc size: 36
Loc size: 24
Loc size: 24
From: petsc-users-bounces at mcs.anl.gov [petsc-users-bounces at mcs.anl.gov] on behalf of Morten Nobel-Jørgensen [mono at dtu.dk]
Sent: Sunday, September 25, 2016 11:15 AM
To: Matthew Knepley
Cc: PETSc ‎[petsc-users at mcs.anl.gov]‎
Subject: Re: [petsc-users] DMPlex problem
Hi Matthew
Thank you for the bug-fix :) I can confirm that it works :)
And thanks for your hard work on PETSc - your work is very much appreciated!
Kind regards,
Morten
Sent: Friday, September 23, 2016 2:46 PM
To: Morten Nobel-Jørgensen
On Fri, Sep 23, 2016 at 7:45 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Sep 23, 2016 at 3:48 AM, Morten Nobel-Jørgensen <mono at dtu.dk<mailto:mono at dtu.dk>> wrote:
Dear PETSc developers
Any update on this issue regarding DMPlex? Or is there any obvious workaround that we are unaware of?
I have fixed this bug. It did not come up in nightly tests because we are not using MatSetValuesLocal(). Instead we
use MatSetValuesClosure() which translates differently.
Here is the branch
  https://bitbucket.org/petsc/petsc/branch/knepley/fix-dm-ltog-bs
and I have merged it to next. It will go to master in a day or two.
Also, here is the cleaned up source with no memory leaks.
  Matt
Also should we additionally register the issue on Bitbucket or is reporting the issue on the mailing list enough?
Normally we are faster, but the start of the semester was hard this year.
     Matt
Kind regards,
Morten
From: Matthew Knepley [knepley at gmail.com<mailto:knepley at gmail.com>]
Sent: Friday, September 09, 2016 12:21 PM
Cc: PETSc ‎[petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>]‎
On Fri, Sep 9, 2016 at 4:04 AM, Morten Nobel-Jørgensen <mono at dtu.dk<mailto:mono at dtu.dk>> wrote:
Dear PETSc developers and users,
Last week we posted a question regarding an error with DMPlex and multiple dofs and have not gotten any feedback yet. This is uncharted waters for us, since we have gotten used to an extremely fast feedback from the PETSc crew. So - with the chance of sounding impatient and ungrateful - we would like to hear if anybody has any ideas that could point us in the right direction?
This is my fault. You have not gotten a response because everyone else was waiting for me, and I have been
slow because I just moved houses at the same time as term started here. Sorry about that.
The example ran for me and I saw your problem. The local-tp-global map is missing for some reason.
I am tracking it down now. It should be made by DMCreateMatrix(), so this is mysterious. I hope to have
this fixed by early next week.
    Matt
We have created a small example problem that demonstrates the error in the matrix assembly.
Morten
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160926/cbbeaf37/attachment.html>
Type: text/x-c++src
Desc: ex18k.cc
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160926/cbbeaf37/attachment.cc>
