[petsc-users] Issue updating MUMPS ictnl after failed solve
Fande Kong fdkong.jd at gmail.com
Mon Sep 19 20:45:38 CDT 2016
Placing PCReset(PC pc) before the second kspsolve might works.
Fande Kong,
On Mon, Sep 19, 2016 at 7:38 PM, murat keçeli <keceli at gmail.com> wrote:
> Another guess: maybe you also need KSPSetUp(ksp); before the second
> KSPSolve(ksp,b,x);.
> Murat Keceli
> On Mon, Sep 19, 2016 at 8:33 PM, David Knezevic <
> david.knezevic at akselos.com> wrote:
>> On Mon, Sep 19, 2016 at 7:26 PM, Dave May <dave.mayhem23 at gmail.com>
>> wrote:
>>> On 19 September 2016 at 21:05, David Knezevic <
>>>> When I use MUMPS via PETSc, one issue is that it can sometimes fail
>>>> with MUMPS error -9, which means that MUMPS didn't allocate a big enough
>>>> workspace. This can typically be fixed by increasing MUMPS icntl 14, e.g.
>>>> via the command line option -mat_mumps_icntl_14.
>>>> However, instead of having to run several times with different command
>>>> line options, I'd like to be able to automatically increment icntl 14 value
>>>> in a loop until the solve succeeds.
>>>> I have a saved matrix which fails when I use it for a solve with MUMPS
>>>> with 4 MPI processes and the default ictnl values, so I'm using this to
>>>> check that I can achieve the automatic icntl 14 update, as described above.
>>>> (The matrix is 14MB so I haven't attached it here, but I'd be happy to send
>>>> it to anyone else who wants to try this test case out.)
>>>> I've pasted some test code below which provides a simple test of this
>>>> idea using two solves. The first solve uses the default value of icntl 14,
>>>> which fails, and then we update icntl 14 to 30 and solve again. The second
>>>> solve should succeed since icntl 14 of 30 is sufficient for MUMPS to
>>>> succeed in this case, but for some reason the second solve still fails.
>>>> Below I've also pasted the output from -ksp_view, and you can see that
>>>> ictnl 14 is being updated correctly (see the ICNTL(14) lines in the
>>>> output), so it's not clear to me why the second solve fails. It seems like
>>>> MUMPS is ignoring the update to the ictnl value?
>>> I believe this parameter is utilized during the numerical factorization
>>> phase.
>>> In your code, the operator hasn't changed, however you haven't signalled
>>> to the KSP that you want to re-perform the numerical factorization.
>>> You can do this by calling KSPSetOperators() before your second solve.
>>> I think if you do this (please try it), the factorization will be
>>> performed again and the new value of icntl will have an effect.
>>> Note this is a wild stab in the dark - I haven't dug through the
>>> petsc-mumps code in detail...
>> That sounds like a plausible guess to me, but unfortunately it didn't
>> work. I added KSPSetOperators(ksp,A,A); before the second solve and I
>> got the same behavior as before.
>> Thanks,
>> David
>>>> Test code:
>>>>   Mat A;
>>>>   MatCreate(PETSC_COMM_WORLD,&A);
>>>>   MatSetType(A,MATMPIAIJ);
>>>>   PetscViewer petsc_viewer;
>>>>   PetscViewerBinaryOpen( PETSC_COMM_WORLD,
>>>>                          "matrix.dat",
>>>>                          FILE_MODE_READ,
>>>>                          &petsc_viewer);
>>>>   MatLoad(A, petsc_viewer);
>>>>   PetscViewerDestroy(&petsc_viewer);
>>>>   PetscInt m, n;
>>>>   MatGetSize(A, &m, &n);
>>>>   Vec x;
>>>>   VecCreate(PETSC_COMM_WORLD,&x);
>>>>   VecSetSizes(x,PETSC_DECIDE,m);
>>>>   VecSetFromOptions(x);
>>>>   VecSet(x,1.0);
>>>>   Vec b;
>>>>   VecDuplicate(x,&b);
>>>>   KSP ksp;
>>>>   PC pc;
>>>>   KSPCreate(PETSC_COMM_WORLD,&ksp);
>>>>   KSPSetType(ksp,KSPPREONLY);
>>>>   KSPGetPC(ksp,&pc);
>>>>   PCSetType(pc,PCCHOLESKY);
>>>>   PCFactorSetMatSolverPackage(pc,MATSOLVERMUMPS);
>>>>   PCFactorSetUpMatSolverPackage(pc);
>>>>   KSPSetFromOptions(ksp);
>>>>   KSPSetUp(ksp);
>>>>   KSPSolve(ksp,b,x);
>>>>     KSPConvergedReason reason;
>>>>     KSPGetConvergedReason(ksp, &reason);
>>>>     std::cout << "converged reason: " << reason << std::endl;
>>>>   Mat F;
>>>>   PCFactorGetMatrix(pc,&F);
>>>>   MatMumpsSetIcntl(F,14,30);
>>>>   KSPSolve(ksp,b,x);
>>>> -ksp_view output (ICNTL(14) changes from 20 to 30, but we get
>>>> "converged reason: -11" for both solves)
>>>> KSP Object: 4 MPI processes
>>>>   type: preonly
>>>>   maximum iterations=10000, initial guess is zero
>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>>   left preconditioning
>>>>   using NONE norm type for convergence test
>>>> PC Object: 4 MPI processes
>>>>   type: cholesky
>>>>     Cholesky: out-of-place factorization
>>>>     tolerance for zero pivot 2.22045e-14
>>>>     matrix ordering: natural
>>>>     factor fill ratio given 0., needed 0.
>>>>       Factored matrix follows:
>>>>         Mat Object:         4 MPI processes
>>>>           type: mpiaij
>>>>           rows=22878, cols=22878
>>>>           package used to perform factorization: mumps
>>>>           total: nonzeros=3361617, allocated nonzeros=3361617
>>>>           total number of mallocs used during MatSetValues calls =0
>>>>             MUMPS run parameters:
>>>>               SYM (matrix type):                   2
>>>>               PAR (host participation):            1
>>>>               ICNTL(1) (output for error):         6
>>>>               ICNTL(2) (output of diagnostic msg): 0
>>>>               ICNTL(3) (output for global info):   0
>>>>               ICNTL(4) (level of printing):        0
>>>>               ICNTL(5) (input mat struct):         0
>>>>               ICNTL(6) (matrix prescaling):        7
>>>>               ICNTL(7) (sequentia matrix ordering):7
>>>>               ICNTL(8) (scalling strategy):        77
>>>>               ICNTL(10) (max num of refinements):  0
>>>>               ICNTL(11) (error analysis):          0
>>>>               ICNTL(12) (efficiency control):                         0
>>>>               ICNTL(13) (efficiency control):                         0
>>>>               ICNTL(14) (percentage of estimated workspace increase):
>>>> 20
>>>>               ICNTL(18) (input mat struct):                           3
>>>>               ICNTL(19) (Shur complement info):                       0
>>>>               ICNTL(20) (rhs sparse pattern):                         0
>>>>               ICNTL(21) (solution struct):                            1
>>>>               ICNTL(22) (in-core/out-of-core facility):               0
>>>>               ICNTL(23) (max size of memory can be allocated locally):0
>>>>               ICNTL(24) (detection of null pivot rows):               0
>>>>               ICNTL(25) (computation of a null space basis):          0
>>>>               ICNTL(26) (Schur options for rhs or solution):          0
>>>>               ICNTL(27) (experimental parameter):
>>>> -24
>>>>               ICNTL(28) (use parallel or sequential ordering):        1
>>>>               ICNTL(29) (parallel ordering):                          0
>>>>               ICNTL(30) (user-specified set of entries in inv(A)):    0
>>>>               ICNTL(31) (factors is discarded in the solve phase):    0
>>>>               ICNTL(33) (compute determinant):                        0
>>>>               CNTL(1) (relative pivoting threshold):      0.01
>>>>               CNTL(2) (stopping criterion of refinement): 1.49012e-08
>>>>               CNTL(3) (absolute pivoting threshold):      0.
>>>>               CNTL(4) (value of static pivoting):         -1.
>>>>               CNTL(5) (fixation for null pivots):         0.
>>>>               RINFO(1) (local estimated flops for the elimination after
>>>> analysis):
>>>>                 [0] 1.84947e+08
>>>>                 [1] 2.42065e+08
>>>>                 [2] 2.53044e+08
>>>>                 [3] 2.18441e+08
>>>>               RINFO(2) (local estimated flops for the assembly after
>>>> factorization):
>>>>                 [0]  945938.
>>>>                 [1]  906795.
>>>>                 [2]  897815.
>>>>                 [3]  998840.
>>>>               RINFO(3) (local estimated flops for the elimination after
>>>> factorization):
>>>>                 [0]  1.59835e+08
>>>>                 [1]  1.50867e+08
>>>>                 [2]  2.27932e+08
>>>>                 [3]  1.52037e+08
>>>>               INFO(15) (estimated size of (in MB) MUMPS internal data
>>>> for running numerical factorization):
>>>>               [0] 36
>>>>               [1] 37
>>>>               [2] 38
>>>>               [3] 39
>>>>               INFO(16) (size of (in MB) MUMPS internal data used during
>>>>                 [0] 36
>>>>                 [1] 37
>>>>                 [2] 38
>>>>                 [3] 39
>>>>               INFO(23) (num of pivots eliminated on this processor
>>>> after factorization):
>>>>                 [0] 6450
>>>>                 [1] 5442
>>>>                 [2] 4386
>>>>                 [3] 5526
>>>>               RINFOG(1) (global estimated flops for the elimination
>>>> after analysis): 8.98497e+08
>>>>               RINFOG(2) (global estimated flops for the assembly after
>>>> factorization): 3.74939e+06
>>>>               RINFOG(3) (global estimated flops for the elimination
>>>> after factorization): 6.9067e+08
>>>>               (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
>>>> (0.,0.)*(2^0)
>>>>               INFOG(3) (estimated real workspace for factors on all
>>>> processors after analysis): 4082184
>>>>               INFOG(4) (estimated integer workspace for factors on all
>>>> processors after analysis): 231846
>>>>               INFOG(5) (estimated maximum front size in the complete
>>>> tree): 678
>>>>               INFOG(6) (number of nodes in the complete tree): 1380
>>>>               INFOG(7) (ordering option effectively use after
>>>> analysis): 5
>>>>               INFOG(8) (structural symmetry in percent of the permuted
>>>> matrix after analysis): 100
>>>>               INFOG(9) (total real/complex workspace to store the
>>>> matrix factors after factorization): 3521904
>>>>               INFOG(10) (total integer space store the matrix factors
>>>> after factorization): 229416
>>>>               INFOG(11) (order of largest frontal matrix after
>>>> factorization): 678
>>>>               INFOG(12) (number of off-diagonal pivots): 0
>>>>               INFOG(13) (number of delayed pivots after factorization):
>>>> 0
>>>>               INFOG(14) (number of memory compress after
>>>> factorization): 0
>>>>               INFOG(15) (number of steps of iterative refinement after
>>>> solution): 0
>>>>               INFOG(16) (estimated size (in MB) of all MUMPS internal
>>>> data for factorization after analysis: value on the most memory consuming
>>>> processor): 39
>>>>               INFOG(17) (estimated size of all MUMPS internal data for
>>>> factorization after analysis: sum over all processors): 150
>>>>               INFOG(18) (size of all MUMPS internal data allocated
>>>> during factorization: value on the most memory consuming processor): 39
>>>>               INFOG(19) (size of all MUMPS internal data allocated
>>>> during factorization: sum over all processors): 150
>>>>               INFOG(20) (estimated number of entries in the factors):
>>>> 3361617
>>>>               INFOG(21) (size in MB of memory effectively used during
>>>> factorization - value on the most memory consuming processor): 35
>>>>               INFOG(22) (size in MB of memory effectively used during
>>>> factorization - sum over all processors): 136
>>>>               INFOG(23) (after analysis: value of ICNTL(6) effectively
>>>> used): 0
>>>>               INFOG(24) (after analysis: value of ICNTL(12) effectively
>>>> used): 1
>>>>               INFOG(25) (after factorization: number of pivots modified
>>>> by static pivoting): 0
>>>>               INFOG(28) (after factorization: number of null pivots
>>>> encountered): 0
>>>>               INFOG(29) (after factorization: effective number of
>>>> entries in the factors (sum over all processors)): 2931438
>>>>               INFOG(30, 31) (after solution: size in Mbytes of memory
>>>> used during solution phase): 0, 0
>>>>               INFOG(32) (after analysis: type of analysis done): 1
>>>>               INFOG(33) (value used for ICNTL(8)): 7
>>>>               INFOG(34) (exponent of the determinant if determinant is
>>>> requested): 0
>>>>   linear system matrix = precond matrix:
>>>>     type: mpiaij
>>>>     total: nonzeros=1219140, allocated nonzeros=1219140
>>>>       using I-node (on process 0) routines: found 1889 nodes, limit
>>>> used is 5
>>>>   type: preonly
>>>>   type: cholesky
>>>>           type: mpiaij
>>>> 30
>>>> -24
>>>> analysis):
>>>>                 [0] 1.84947e+08
>>>>                 [1] 2.42065e+08
>>>>                 [2] 2.53044e+08
>>>>                 [3] 2.18441e+08
>>>> factorization):
>>>>                 [0]  945938.
>>>>                 [1]  906795.
>>>>                 [2]  897815.
>>>>                 [3]  998840.
>>>> factorization):
>>>>                 [0]  1.59835e+08
>>>>                 [1]  1.50867e+08
>>>>                 [2]  2.27932e+08
>>>>                 [3]  1.52037e+08
>>>>               [0] 36
>>>>               [1] 37
>>>>               [2] 38
>>>>               [3] 39
>>>>                 [0] 36
>>>>                 [1] 37
>>>>                 [2] 38
>>>>                 [3] 39
>>>>                 [0] 6450
>>>>                 [1] 5442
>>>>                 [2] 4386
>>>>                 [3] 5526
>>>> (0.,0.)*(2^0)
>>>> tree): 678
>>>> analysis): 5
>>>> factorization): 678
>>>> 0
>>>> factorization): 0
>>>> solution): 0
>>>> processor): 39
>>>> 3361617
>>>> used): 0
>>>> used): 1
>>>> encountered): 0
>>>> requested): 0
>>>>     type: mpiaij
>>>> used is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160919/a3951855/attachment-0001.html>
