[petsc-users] Issue updating MUMPS ictnl after failed solve
murat keçeli
keceli at gmail.com
Mon Sep 19 20:38:30 CDT 2016
Another guess: maybe you also need KSPSetUp(ksp); before the second
KSPSolve(ksp,b,x);.
Murat Keceli
On Mon, Sep 19, 2016 at 8:33 PM, David Knezevic <david.knezevic at akselos.com>
wrote:
> On Mon, Sep 19, 2016 at 7:26 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
>> On 19 September 2016 at 21:05, David Knezevic <david.knezevic at akselos.com
>> > wrote:
>>> When I use MUMPS via PETSc, one issue is that it can sometimes fail with
>>> MUMPS error -9, which means that MUMPS didn't allocate a big enough
>>> workspace. This can typically be fixed by increasing MUMPS icntl 14, e.g.
>>> via the command line option -mat_mumps_icntl_14.
>>> However, instead of having to run several times with different command
>>> line options, I'd like to be able to automatically increment icntl 14 value
>>> in a loop until the solve succeeds.
>>> I have a saved matrix which fails when I use it for a solve with MUMPS
>>> with 4 MPI processes and the default ictnl values, so I'm using this to
>>> check that I can achieve the automatic icntl 14 update, as described above.
>>> (The matrix is 14MB so I haven't attached it here, but I'd be happy to send
>>> it to anyone else who wants to try this test case out.)
>>> I've pasted some test code below which provides a simple test of this
>>> idea using two solves. The first solve uses the default value of icntl 14,
>>> which fails, and then we update icntl 14 to 30 and solve again. The second
>>> solve should succeed since icntl 14 of 30 is sufficient for MUMPS to
>>> succeed in this case, but for some reason the second solve still fails.
>>> Below I've also pasted the output from -ksp_view, and you can see that
>>> ictnl 14 is being updated correctly (see the ICNTL(14) lines in the
>>> output), so it's not clear to me why the second solve fails. It seems like
>>> MUMPS is ignoring the update to the ictnl value?
>> I believe this parameter is utilized during the numerical factorization
>> phase.
>> In your code, the operator hasn't changed, however you haven't signalled
>> to the KSP that you want to re-perform the numerical factorization.
>> You can do this by calling KSPSetOperators() before your second solve.
>> I think if you do this (please try it), the factorization will be
>> performed again and the new value of icntl will have an effect.
>> Note this is a wild stab in the dark - I haven't dug through the
>> petsc-mumps code in detail...
> That sounds like a plausible guess to me, but unfortunately it didn't
> work. I added KSPSetOperators(ksp,A,A); before the second solve and I got
> the same behavior as before.
> Thanks,
> David
>>> Test code:
>>> Mat A;
>>> MatCreate(PETSC_COMM_WORLD,&A);
>>> MatSetType(A,MATMPIAIJ);
>>> PetscViewer petsc_viewer;
>>> PetscViewerBinaryOpen( PETSC_COMM_WORLD,
>>> "matrix.dat",
>>> FILE_MODE_READ,
>>> &petsc_viewer);
>>> MatLoad(A, petsc_viewer);
>>> PetscViewerDestroy(&petsc_viewer);
>>> PetscInt m, n;
>>> MatGetSize(A, &m, &n);
>>> Vec x;
>>> VecCreate(PETSC_COMM_WORLD,&x);
>>> VecSetSizes(x,PETSC_DECIDE,m);
>>> VecSetFromOptions(x);
>>> VecSet(x,1.0);
>>> Vec b;
>>> VecDuplicate(x,&b);
>>> KSP ksp;
>>> PC pc;
>>> KSPCreate(PETSC_COMM_WORLD,&ksp);
>>> KSPSetType(ksp,KSPPREONLY);
>>> KSPGetPC(ksp,&pc);
>>> PCSetType(pc,PCCHOLESKY);
>>> PCFactorSetMatSolverPackage(pc,MATSOLVERMUMPS);
>>> PCFactorSetUpMatSolverPackage(pc);
>>> KSPSetFromOptions(ksp);
>>> KSPSetUp(ksp);
>>> KSPSolve(ksp,b,x);
>>> KSPConvergedReason reason;
>>> KSPGetConvergedReason(ksp, &reason);
>>> std::cout << "converged reason: " << reason << std::endl;
>>> Mat F;
>>> PCFactorGetMatrix(pc,&F);
>>> MatMumpsSetIcntl(F,14,30);
>>> KSPSolve(ksp,b,x);
>>> -ksp_view output (ICNTL(14) changes from 20 to 30, but we get "converged
>>> reason: -11" for both solves)
>>> KSP Object: 4 MPI processes
>>> type: preonly
>>> maximum iterations=10000, initial guess is zero
>>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>>> left preconditioning
>>> using NONE norm type for convergence test
>>> PC Object: 4 MPI processes
>>> type: cholesky
>>> Cholesky: out-of-place factorization
>>> tolerance for zero pivot 2.22045e-14
>>> matrix ordering: natural
>>> factor fill ratio given 0., needed 0.
>>> Factored matrix follows:
>>> Mat Object: 4 MPI processes
>>> type: mpiaij
>>> rows=22878, cols=22878
>>> package used to perform factorization: mumps
>>> total: nonzeros=3361617, allocated nonzeros=3361617
>>> total number of mallocs used during MatSetValues calls =0
>>> MUMPS run parameters:
>>> SYM (matrix type): 2
>>> PAR (host participation): 1
>>> ICNTL(1) (output for error): 6
>>> ICNTL(2) (output of diagnostic msg): 0
>>> ICNTL(3) (output for global info): 0
>>> ICNTL(4) (level of printing): 0
>>> ICNTL(5) (input mat struct): 0
>>> ICNTL(6) (matrix prescaling): 7
>>> ICNTL(7) (sequentia matrix ordering):7
>>> ICNTL(8) (scalling strategy): 77
>>> ICNTL(10) (max num of refinements): 0
>>> ICNTL(11) (error analysis): 0
>>> ICNTL(12) (efficiency control): 0
>>> ICNTL(13) (efficiency control): 0
>>> ICNTL(14) (percentage of estimated workspace increase): 20
>>> ICNTL(18) (input mat struct): 3
>>> ICNTL(19) (Shur complement info): 0
>>> ICNTL(20) (rhs sparse pattern): 0
>>> ICNTL(21) (solution struct): 1
>>> ICNTL(22) (in-core/out-of-core facility): 0
>>> ICNTL(23) (max size of memory can be allocated locally):0
>>> ICNTL(24) (detection of null pivot rows): 0
>>> ICNTL(25) (computation of a null space basis): 0
>>> ICNTL(26) (Schur options for rhs or solution): 0
>>> ICNTL(27) (experimental parameter):
>>> -24
>>> ICNTL(28) (use parallel or sequential ordering): 1
>>> ICNTL(29) (parallel ordering): 0
>>> ICNTL(30) (user-specified set of entries in inv(A)): 0
>>> ICNTL(31) (factors is discarded in the solve phase): 0
>>> ICNTL(33) (compute determinant): 0
>>> CNTL(1) (relative pivoting threshold): 0.01
>>> CNTL(2) (stopping criterion of refinement): 1.49012e-08
>>> CNTL(3) (absolute pivoting threshold): 0.
>>> CNTL(4) (value of static pivoting): -1.
>>> CNTL(5) (fixation for null pivots): 0.
>>> RINFO(1) (local estimated flops for the elimination after
>>> analysis):
>>> [0] 1.84947e+08
>>> [1] 2.42065e+08
>>> [2] 2.53044e+08
>>> [3] 2.18441e+08
>>> RINFO(2) (local estimated flops for the assembly after
>>> factorization):
>>> [0] 945938.
>>> [1] 906795.
>>> [2] 897815.
>>> [3] 998840.
>>> RINFO(3) (local estimated flops for the elimination after
>>> factorization):
>>> [0] 1.59835e+08
>>> [1] 1.50867e+08
>>> [2] 2.27932e+08
>>> [3] 1.52037e+08
>>> INFO(15) (estimated size of (in MB) MUMPS internal data
>>> for running numerical factorization):
>>> [0] 36
>>> [1] 37
>>> [2] 38
>>> [3] 39
>>> INFO(16) (size of (in MB) MUMPS internal data used during
>>> [0] 36
>>> [1] 37
>>> [2] 38
>>> [3] 39
>>> INFO(23) (num of pivots eliminated on this processor after
>>> factorization):
>>> [0] 6450
>>> [1] 5442
>>> [2] 4386
>>> [3] 5526
>>> RINFOG(1) (global estimated flops for the elimination
>>> after analysis): 8.98497e+08
>>> RINFOG(2) (global estimated flops for the assembly after
>>> factorization): 3.74939e+06
>>> RINFOG(3) (global estimated flops for the elimination
>>> after factorization): 6.9067e+08
>>> (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
>>> (0.,0.)*(2^0)
>>> INFOG(3) (estimated real workspace for factors on all
>>> processors after analysis): 4082184
>>> INFOG(4) (estimated integer workspace for factors on all
>>> processors after analysis): 231846
>>> INFOG(5) (estimated maximum front size in the complete
>>> tree): 678
>>> INFOG(6) (number of nodes in the complete tree): 1380
>>> INFOG(7) (ordering option effectively use after analysis):
>>> 5
>>> INFOG(8) (structural symmetry in percent of the permuted
>>> matrix after analysis): 100
>>> INFOG(9) (total real/complex workspace to store the matrix
>>> factors after factorization): 3521904
>>> INFOG(10) (total integer space store the matrix factors
>>> after factorization): 229416
>>> INFOG(11) (order of largest frontal matrix after
>>> factorization): 678
>>> INFOG(12) (number of off-diagonal pivots): 0
>>> INFOG(13) (number of delayed pivots after factorization):
>>> 0
>>> INFOG(14) (number of memory compress after factorization):
>>> 0
>>> INFOG(15) (number of steps of iterative refinement after
>>> solution): 0
>>> INFOG(16) (estimated size (in MB) of all MUMPS internal
>>> data for factorization after analysis: value on the most memory consuming
>>> processor): 39
>>> INFOG(17) (estimated size of all MUMPS internal data for
>>> factorization after analysis: sum over all processors): 150
>>> INFOG(18) (size of all MUMPS internal data allocated
>>> during factorization: value on the most memory consuming processor): 39
>>> INFOG(19) (size of all MUMPS internal data allocated
>>> during factorization: sum over all processors): 150
>>> INFOG(20) (estimated number of entries in the factors):
>>> 3361617
>>> INFOG(21) (size in MB of memory effectively used during
>>> factorization - value on the most memory consuming processor): 35
>>> INFOG(22) (size in MB of memory effectively used during
>>> factorization - sum over all processors): 136
>>> INFOG(23) (after analysis: value of ICNTL(6) effectively
>>> used): 0
>>> INFOG(24) (after analysis: value of ICNTL(12) effectively
>>> used): 1
>>> INFOG(25) (after factorization: number of pivots modified
>>> by static pivoting): 0
>>> INFOG(28) (after factorization: number of null pivots
>>> encountered): 0
>>> INFOG(29) (after factorization: effective number of
>>> entries in the factors (sum over all processors)): 2931438
>>> INFOG(30, 31) (after solution: size in Mbytes of memory
>>> used during solution phase): 0, 0
>>> INFOG(32) (after analysis: type of analysis done): 1
>>> INFOG(33) (value used for ICNTL(8)): 7
>>> INFOG(34) (exponent of the determinant if determinant is
>>> requested): 0
>>> linear system matrix = precond matrix:
>>> type: mpiaij
>>> total: nonzeros=1219140, allocated nonzeros=1219140
>>> using I-node (on process 0) routines: found 1889 nodes, limit used
>>> is 5
>>> converged reason: -11
>>> type: preonly
>>> type: cholesky
>>> type: mpiaij
>>> ICNTL(14) (percentage of estimated workspace increase): 30
>>> -24
>>> analysis):
>>> [0] 1.84947e+08
>>> [1] 2.42065e+08
>>> [2] 2.53044e+08
>>> [3] 2.18441e+08
>>> factorization):
>>> [0] 945938.
>>> [1] 906795.
>>> [2] 897815.
>>> [3] 998840.
>>> factorization):
>>> [0] 1.59835e+08
>>> [1] 1.50867e+08
>>> [2] 2.27932e+08
>>> [3] 1.52037e+08
>>> [0] 36
>>> [1] 37
>>> [2] 38
>>> [3] 39
>>> [0] 36
>>> [1] 37
>>> [2] 38
>>> [3] 39
>>> factorization):
>>> [0] 6450
>>> [1] 5442
>>> [2] 4386
>>> [3] 5526
>>> (0.,0.)*(2^0)
>>> tree): 678
>>> 5
>>> factorization): 678
>>> 0
>>> 0
>>> solution): 0
>>> processor): 39
>>> 3361617
>>> used): 0
>>> used): 1
>>> encountered): 0
>>> requested): 0
>>> type: mpiaij
>>> is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160919/fc8ae8fa/attachment-0001.html>
