[petsc-users] Rép: Re: FLAGS in makefile
timothee.nicolas
timothee.nicolas at gmail.com
Tue Sep 13 17:48:45 CDT 2016
8 min should reasonable. I was considering this lengthy actually but OK I got the point. Thank you
Timothée
Matthew Knepley <knepley at gmail.com> a écrit :
On Tue, Sep 13, 2016 at 5:28 PM, Timothée Nicolas <timothee.nicolas at gmail.com> wrote:
OK, thank you.
Regarding point 3, no I didn't realize this was dangerous. But reconfiguring petsc everytime is quite lengthy. How to do if you just want to test a few compilation options, before knowing what you need?
It dangerous because you can make source incompatible with the previously compiled libraries. You can insert other
headers in front of those used by the libraries, change type size, name mangling, etc.
Configuring should not take that long. A complete configure and build takes about 8min at the Bitbucket regression
tests. Are you running on a slow file system?
Matt
Timothée
2016-09-13 19:56 GMT+02:00 Satish Balay <balay at mcs.anl.gov>:
On Tue, 13 Sep 2016, Matthew Knepley wrote:
> On Tue, Sep 13, 2016 at 12:16 PM, Timothée Nicolas <
> > Hi all,
> > I can't seem to figure out how to specify my compilation options with
> > PETSc. For my makefiles, I've always been using Petsc examples inspired
> > makefiles, just tuning them to my needs, and I have never played with
> > compilation options so far. Now, I am trying to add some compilation
> > options, but they are not taken into account by the compiler. My makefile
> > looks like this
> > all: energy
> > include ${PETSC_DIR}/lib/petsc/conf/variables
> > include ${PETSC_DIR}/lib/petsc/conf/rules
> > #FLAGS = -g -O0 -fbounds-check
> > MYFLAGS = -mcmodel=medium -shared-intel
> > OBJS = main.o \
> > modules.o \
> > diags.o \
> > functions.o \
> > conservation.o \
> > EXEC = energy
> > main.o: modules.o \
> > functions.o \
> > conservation.o \
> > diags.o \
> > energy: $(OBJS) chkopts
> > -$(FLINKER) -o $(EXEC) $(MYFLAGS) $(FLAGS) $(OBJS) $(
> > PETSC_SNES_LIB)
> > clean_all:
> > $(RM) $(OBJS) $(EXEC)
> > The compiler then executes things like
> > /opt/mpi/bullxmpi/1.2.8.4/bin/mpif90 -c -fPIC -g -O3
> > -I/ccc/scratch/cont003/gen0198/lutjensh/Timothee/petsc-3.7.3/include
> > petsc-3.7.3/arch-linux2-c-debug/include -I/opt/mpi/bullxmpi/1.2.8.4/
> > include -o modules.o modules.F90
> > without taking my variable MYFLAGS into account. What may be the reason?
> > Also, what does "chkopts" mean ?
> 1) You want to change CFLAGS or FFLAGS
> 2) 'chkopts' is an internal check for PETSc
> 3) You realize that it is very dangerous to compile with options not
