[petsc-users] Sorted CSR Matrix and Multigrid PC.
Manuel Valera
mvalera at mail.sdsu.edu
Fri Sep 9 19:28:19 CDT 2016
Thank you SO much for helping me out on this. Dumb error from my part not
to notice.
This means the common /mypcs/ elements are preconfigure internally in PETSc?
Regards and happy weekend,
On Fri, Sep 9, 2016 at 5:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> The missing third argument to PCApply means that you haven't allocated
> the vector work?
> > On Sep 9, 2016, at 3:34 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> > Hello everyone,
> > I'm having an error with my program that i cannot understand, the weird
> part is that the same implementation in my main model does not show errors
> and they are virtually identical.
> > The problematic part of the code is:
> > call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> > call KSPSetOperators(ksp,Ap,Ap,ierr)
> > call KSPGetPC(ksp,pc,ierr)
> > tol = 1.e-5
> > call KSPSetTolerances(ksp,tol,PETSC_DEFAULT_REAL,PETSC_
> DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr)
> > call PCGetOperators(pc,PETSC_NULL_OBJECT,pmat,ierr)
> > call PCCreate(PETSC_COMM_WORLD,mg,ierr)
> > call PCSetType(mg,PCJACOBI,ierr)
> > call PCSetOperators(mg,pmat,pmat,ierr)
> > call PCSetUp(mg,ierr)
> > call PCApply(mg,xp,work,ierr)
> > And the errors i get are:
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Null argument, when expecting valid pointer
> > [0]PETSC ERROR: Null Object: Parameter # 3
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
> > [0]PETSC ERROR: ./solvelinearmgPETSc
> on a
> arch-linux2-c-debug named valera-HP-xw4600-Workstation by valera Fri Sep 9
> 12:46:02 2016
> > [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack=1 --download-mpich=1
> --download-ml=1
> > [0]PETSC ERROR: #1 PCApply() line 467 in /home/valera/sergcemv4/
> bitbucket/serucoamv4/petsc-3.7.3/src/ksp/pc/interface/precon.c
> > As i said before, the exact same code in a bigger model does not print
> errors. I'm trying to solve this before moving into multigrid
> implementation in my prototype,
> > Thanks for your time,
> > On Wed, Sep 7, 2016 at 8:27 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Sep 7, 2016, at 10:24 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > Thank you I will try this. What would be the call if I wanted to use
> other Multigrid option?
> > There really isn't any other choices.
> > > Don't worry this is a standalone prototype, it should be fine on the
> main model. Anyway, any hints would be appreciated. Thanks a lot for your
> time.
> > > On Sep 7, 2016 8:22 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
> > > Sorry, this was due to our bug, the fortran function for
> PCGAMGSetType() was wrong. I have fixed this in the maint and master branch
> of PETSc in the git repository. But you can simply remove the call to
> PCGAMGSetType() from your code since what you are setting is the default
> type.
> > > BTW: there are other problems with your code after that call that
> you will have to work through.
> > > Barry
> > > > On Sep 7, 2016, at 8:46 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > > ---------- Forwarded message ----------
> > > > From: Manuel Valera <mvalera at mail.sdsu.edu>
> > > > Date: Wed, Sep 7, 2016 at 6:40 PM
> > > > Subject: Re: [petsc-users] Sorted CSR Matrix and Multigrid PC.
> > > > To:
> > > > Cc: PETSc users list <petsc-users at mcs.anl.gov>
> > > > Hello,
> > > > I was able to sort the data but the PCGAMG does not seem to be
> working.
> > > > I reconfigured everything from scratch as suggested and updated to
> the latest PETSc version, same results,
> > > > I get the following error:
> > > > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
> Violation, probably memory access out of range
> > > > [0]PETSC ERROR: --------------------- Stack Frames
> > > > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > > > [0]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > > > [0]PETSC ERROR: is given.
> > > > [0]PETSC ERROR: [0] PetscStrcmp line 524 /home/valera/sergcemv4/
> bitbucket/serucoamv4/petsc-3.7.3/src/sys/utils/str.c
> > > > [0]PETSC ERROR: [0] PetscFunctionListFind_Private line 352
> /home/valera/sergcemv4/bitbucket/serucoamv4/petsc-3.7.3/src/sys/dll/reg.c
> > > > [0]PETSC ERROR: [0] PCGAMGSetType_GAMG line 1157
> 7.3/src/ksp/pc/impls/gamg/gamg.c
> > > > [0]PETSC ERROR: [0] PCGAMGSetType line 1102 /home/valera/sergcemv4/
> bitbucket/serucoamv4/petsc-3.7.3/src/ksp/pc/impls/gamg/gamg.c
> > > > You can find the working program attached, sorry for the large files
> and messy makefile,
> > > > Many thanks,
> > > > Manuel Valera.
> > > > MGpetscSolver.tar.gz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160909/21d54b5d/attachment-0001.html>
