[petsc-users] KSP_CONVERGED_STEP_LENGTH
Harshad Sahasrabudhe
hsahasra at purdue.edu
Thu Sep 8 10:38:29 CDT 2016
I'm using GAMG + GMRES for my Poisson problem. The solver converges with
KSP_CONVERGED_STEP_LENGTH at a residual of 9.773346857844e-02, which is
much higher than what I need (I need a tolerance of at least 1E-8). I am
not able to figure out which tolerance I need to set to avoid convergence
due to CONVERGED_STEP_LENGTH.
Any help is appreciated! Output of -ksp_view and -ksp_monitor:
0 KSP Residual norm 3.121347818142e+00
1 KSP Residual norm 9.773346857844e-02
Linear solve converged due to CONVERGED_STEP_LENGTH iterations 1
KSP Object: 1 MPI processes
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-08, absolute=1e-50, divergence=10000
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: gamg
MG: type is MULTIPLICATIVE, levels=2 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
Coarse grid solver -- level -------------------------------
KSP Object: (mg_coarse_) 1 MPI processes
type: preonly
maximum iterations=1, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
PC Object: (mg_coarse_) 1 MPI processes
type: bjacobi
block Jacobi: number of blocks = 1
Local solve is same for all blocks, in the following KSP and PC
objects:
KSP Object: (mg_coarse_sub_) 1 MPI processes
type: preonly
PC Object: (mg_coarse_sub_) 1 MPI processes
type: lu
LU: out-of-place factorization
tolerance for zero pivot 2.22045e-14
using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
matrix ordering: nd
factor fill ratio given 5, needed 1.91048
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqaij
rows=284, cols=284
package used to perform factorization: petsc
total: nonzeros=7726, allocated nonzeros=7726
total number of mallocs used during MatSetValues calls =0
using I-node routines: found 133 nodes, limit used is 5
linear system matrix = precond matrix:
type: seqaij
rows=284, cols=284
total: nonzeros=4044, allocated nonzeros=4044
not using I-node routines
type: seqaij
rows=284, cols=284
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (mg_levels_1_) 1 MPI processes
type: chebyshev
Chebyshev: eigenvalue estimates: min = 0.195339, max = 4.10212
maximum iterations=2
using nonzero initial guess
PC Object: (mg_levels_1_) 1 MPI processes
type: sor
SOR: type = local_symmetric, iterations = 1, local iterations = 1,
omega = 1
Mat Object: () 1 MPI processes
type: seqaij
rows=9036, cols=9036
total: nonzeros=192256, allocated nonzeros=192256
Up solver (post-smoother) same as down solver (pre-smoother)
type: seqaij
Harshad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160908/b1a46f1b/attachment.html>
