[petsc-users] questions on hypre preconditioner
Barry Smith
bsmith at mcs.anl.gov
Mon Sep 5 12:26:14 CDT 2016
> On Sep 5, 2016, at 11:21 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi Developers,
> There are two questions on the hypre preconditioner.
> (1) How to set different relax types on different levels? It looks to use the SAME relax type on all levels except the coarse level which we could set it to a different solver. Especially, could I set the smoother type on the finest level as NONE?
I don't think this is possible through the PETSc interface; it may or may not be possible by adding additional hypre calls. You need to check the hypre documentation.
> (2) How could I know how many levels have been actually created in hypre, and how many unknowns on different levels? The "-pc_view" can not tell me this information:
-pc_hypre_boomeramg_print_statistics integer different integers give different amounts of detail, I don't know what the integers mean.
> type: hypre
> HYPRE BoomerAMG preconditioning
> HYPRE BoomerAMG: Cycle type V
> HYPRE BoomerAMG: Maximum number of levels 25
> HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
> HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
> HYPRE BoomerAMG: Threshold for strong coupling 0.25
> HYPRE BoomerAMG: Interpolation truncation factor 0
> HYPRE BoomerAMG: Interpolation: max elements per row 0
> HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
> HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
> HYPRE BoomerAMG: Maximum row sums 0.9
> HYPRE BoomerAMG: Sweeps down 1
> HYPRE BoomerAMG: Sweeps up 1
> HYPRE BoomerAMG: Sweeps on coarse 1
> HYPRE BoomerAMG: Relax down symmetric-SOR/Jacobi
> HYPRE BoomerAMG: Relax up symmetric-SOR/Jacobi
> HYPRE BoomerAMG: Relax on coarse Gaussian-elimination
> HYPRE BoomerAMG: Relax weight (all) 1
> HYPRE BoomerAMG: Outer relax weight (all) 1
> HYPRE BoomerAMG: Using CF-relaxation
> HYPRE BoomerAMG: Measure type local
> HYPRE BoomerAMG: Coarsen type Falgout
> HYPRE BoomerAMG: Interpolation type classical
> linear system matrix = precond matrix:
> Fande,
