[petsc-users] GAMG
Jeremy Theler
jeremy at seamplex.com
Mon Oct 31 05:54:11 CDT 2016
Hi again
I have been wokring on these issues. Long story short: it is about the
ordering of the unknown fields in the vector.
Long story:
The physics is linear elastic problem, you can see it does work with LU
over a simple cube (warp the displacements to see it does represent an
elastic problem, E=200e3, nu=0.3):
https://caeplex.com/demo/results.php?id=5817146bdb561
Say my three displacements (unknowns) are u,v,w. I can define the
unknown vector as (is this called node-based ordering?)
[u1 v1 w1 u2 v2 w2 ... un vn wn]^T
Another option is (is this called unknown-based ordering?)
[u1 u2 ... un v1 v2 ... vn w1 w2 ... wn]^T
With lu/preonly the results are the same, although the stiffnes matrixes
for each case are attached as PNGs. And of course, the near-nullspace
vectors are different. So PCSetCoordinates() should work with one
ordering and not with another one, an issue I did not take into
consideration.
After understanding Matt's point about the near nullspace (and reading
some interesting comments from Jed on scicomp stackexchange) I did built
my own vectors (I had to take a look at MatNullSpaceCreateRigidBody()
because I found out by running the code the nullspace should be an
orthonormal basis, it should say so in the docs).
Now, there are some results I do not understand. I tried these six
combinations:
order near-nullspace iterations norm
unknown explicit 10 1.6e-6
unknown PCSetCoordinates 15 1.7e-7
unknown none 15 2.4e-7
node explicit fails with error -11
node PCSetCoordinates fails with error -11
node none 13 3.8e-7
Error -11 is
PETSc's linear solver did not converge with reason
'DIVERGED_PCSETUP_FAILED' (-11)
Any explanation (for dumbs)?
Another thing to take into account: I am setting the dirichlet BCs with
MatZeroRows(), but I am not updating the columns to keep symmetry. Can
this pose a problem for GAMG?
I can post the two stiffnes matrices and the RHS vectors as binary
files.
Thank you!
jeremy
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161031/af9567d3/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161031/af9567d3/attachment-0003.png>
