[petsc-users] Moving from KSPSetNullSpace to MatSetNullSpace
Mark Adams mfadams at lbl.gov
Wed Oct 26 21:29:46 CDT 2016
On Wed, Oct 26, 2016 at 11:15 AM, Olivier Mesnard <
olivier.mesnard8 at gmail.com> wrote:
> On 26 October 2016 at 09:38, Mark Adams <mfadams at lbl.gov> wrote:
>> Please run with -info and grep on GAMG and send that. (-info is very
>> noisy).
>> ​I cat the grep at the end of the log file (see attachment
> petsc-3.7.4-n2.log).
> Also, increasing the local number of iterations in SOR, as suggested by
> Barry, removed the indefinite preconditioner (file
> petsc-3.7.4-n2-lits2.log).
The eigen estimate on the second level looks like it could be low.
You have a small stencil. Is this a 2D problem? You might try adding
'-pc_gamg_square_graph 0', just to see what happens. (AMG can be a real
pain sometimes.)
>> I'm not sure what is going on here. Divergence with parallelism.  Here
>> are some suggestions.
>> Note, you do not need to set the null space for a scalar (Poisson)
>> problem unless you have some special null space. And not getting it set
>> (with the 6 rigid body modes) for the velocity (elasticity) equation will
>> only degrade convergence rates.
>> There was a bug for a while (early 3.7 versions) where the coarse grid
>> was not squeezed onto one processor, which could result in very bad
>> convergence, but not divergence, on multiple processors (the -info output
>> will report the number of 'active pes'). Perhaps this bug is causing
>> divergence for you.  We had another subtle bug where the eigen estimates
>> used a bad seed vector, which gives a bad eigen estimate. This would cause
>> divergence but it should not be a parallelism issue (these two bugs were
>> both regressions in around 3.7)
>> Divergence usually comes from a bad eigen estimate in a Chebyshev
>> smoother, but this is not highly correlated with parallelism. The -info
>> data will report the eigen estimates but that is not terribly useful but
>> you can see if it changes (gets larger) with better parameters. Add these
>> parameters, with the correct prefix, and use -options_left to make sure
>> that "there are no unused options":
>> -mg_levels_ksp_type chebyshev
>> -mg_levels_esteig_ksp_type cg
>> -mg_levels_esteig_ksp_max_it 10
>> -mg_levels_ksp_chebyshev_esteig 0,.1,0,1.05
>> ​petsc-3.7.4-n2-chebyshev.log contains the output when using the default
> KSP Chebyshev.
> When estimating the eigenvalues using cg with the translations [0, 0.1; 0,
> 1.05] (previously using default gmres with translations [0, 0.1; 0, 1.1]),
> the max eigenvalue decreases from 1.0931 to 1.04366 and the indefinite
> preconditioner appears ealier after 2 iterations (3 previously).
> I attached the log (see petsc-3.7.4-chebyshev.log).
>> chebyshev is the default, as Barry suggested, replace this with gmres or
>> richardson (see below) and verify that this fixed the divergence problem.
>>> Using gmres (-poisson_mg_levels_ksp_type gmres) fixes the divergence
> problem
> ​ (file petsc-3.7.4-n2-gmres.log)​
>> Same observation with richardson (file petsc-3.7.4-n2-richardson.log).
>> If your matrix is symmetric positive definite then use
>> '-mg_levels_esteig_ksp_type cg', if not then use the default gmres.
> I checked and I still get an indefinite preconditioner when using gmres to
> estimate the eigenvalues.​
If you matrix is symmetric (and positive) then CG will give you a better
estimate (provable?)
>> Increase/decrease '-mg_levels_esteig_ksp_max_it 10', you should see the
>> estimates increase and converge with higher max_it. Setting this to a huge
>> number, like 100, should fix the bad seed vector problem mentioned above.
>> ​I played with the maximum number of iterations. Here are the min/max
> eigenvalue estimates for the two levels:
> - max_it 5: (min​=0.0975079, max=1.02383) on level 1, (0.0975647, 1.02443)
> on level 2
> - max_it 10: (0.0991546, 1.04112), (0.0993962, 1.04366)
> - max_it 20: (0.0995918, 1.04571), (0.115723, 1.21509)
> - max_it 50: (0.0995651, 1.04543), (0.133744, 1.40431)
> - max_it 100: (0.0995651, 1.04543), (0.133744, 1.40431)
> Note that all those runs ended up with an indefinite preconditioner,
> except when increasing the maximum number of iterations to 50 (and 100,
> which did not improve the eigenvalue estimates).
Are you saying that the indefinite PC error goes away when
'-mg_levels_esteig_ksp_max_it 50' ? or is this MG smoother iterations?
>> If eigen estimates are a pain, like with non SPD systems, then
>> richardson is an option (instead of chebyshev):
>> -mg_levels_ksp_type richardson
>> -mg_levels_ksp_richardson_scale 0.6
>> You then need to play with the scaling (that is what chebyshev does for
>> you essentially).
>> On Tue, Oct 25, 2016 at 10:22 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Oct 25, 2016 at 9:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   Olivier,
>>>>     Ok, so I've run the code in the debugger, but I don't not think the
>>>> problem is with the null space. The code is correctly removing the null
>>>> space on all the levels of multigrid.
>>>>     I think the error comes from changes in the behavior of GAMG. GAMG
>>>> is relatively rapidly moving with different defaults and even different
>>>> code with each release.
>>>>     To check this I added the option -poisson_mg_levels_pc_sor_lits 2
>>>> and it stopped complaining about KSP_DIVERGED_INDEFINITE_PC. I've seen this
>>>> before where the smoother is "too weak" and so the net result is that
>>>> action of the preconditioner is indefinite. Mark Adams probably has better
>>>> suggestions on how to make the preconditioner behave. Note you could also
>>>> use a KSP of richardson or gmres instead of cg since they don't care about
>>>> this indefinite business.
>>> I think old GAMG squared the graph by default. You can see in the 3.7
>>> output that it does not.
>>>    Matt
>>>>    Barry
>>>> > On Oct 25, 2016, at 5:39 PM, Olivier Mesnard <
>>>> > On 25 October 2016 at 17:51, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> >   Olivier,
>>>> >     In theory you do not need to change anything else. Are you using
>>>> a different matrix object for the velocity_ksp object than the poisson_ksp
>>>> object?
>>>> > ​The matrix is different for the velocity_ksp and the poisson_ksp​.
>>>> >     The code change in PETSc is very little but we have a report from
>>>> another CFD user who also had problems with the change so there may be some
>>>> subtle bug that we can't figure out causing things to not behave properly.
>>>> >    First run the 3.7.4 code with -poisson_ksp_view and verify that
>>>> when it prints the matrix information it prints something like has attached
>>>> null space if it does not print that it means that somehow the matrix is
>>>> not properly getting the matrix attached.
>>>> > ​When running with 3.7.4 and -poisson_ksp_view, the output shows that
>>>> the nullspace is not attached to the KSP (as it was with 3.5.4)​; however
>>>> the print statement is now under the Mat info (which is expected when
>>>> moving from KSPSetNullSpace to MatSetNullSpace?).
>>>> >     Though older versions had MatSetNullSpace() they didn't
>>>> necessarily associate it with the KSP so it was not expected to work as a
>>>> replacement for KSPSetNullSpace() with older versions.
>>>> >     Because our other user had great difficulty trying to debug the
>>>> issue feel free to send us at petsc-maint at mcs.anl.gov your code with
>>>> instructions on building and running and we can try to track down the
>>>> problem. Better than hours and hours spent with fruitless email. We will,
>>>> of course, not distribute the code and will delete in when we are finished
>>>> with it.
>>>> > ​The code is open-source and hosted on GitHub (
>>>> https://github.com/barbagroup/PetIBM)​.
>>>> > I just pushed the branches `feature-compatible-petsc-3.7` and
>>>> `revert-compatible-petsc-3.5` that I used to observe this problem.
>>>> > PETSc (both 3.5.4 and 3.7.4) was configured as follow:
>>>> > export PETSC_ARCH="linux-gnu-dbg"
>>>> > ./configure --PETSC_ARCH=$PETSC_ARCH \
>>>> >       --with-cc=gcc \
>>>> >       --with-cxx=g++ \
>>>> >       --with-fc=gfortran \
>>>> >       --COPTFLAGS="-O0" \
>>>> >       --CXXOPTFLAGS="-O0" \
>>>> >       --FOPTFLAGS="-O0" \
>>>> >       --with-debugging=1 \
>>>> >       --download-fblaslapack \
>>>> >       --download-mpich \
>>>> >       --download-hypre \
>>>> >       --download-yaml \
>>>> >       --with-x=1
>>>> > Our code was built using the following commands:​
>>>> > mkdir petibm-build
>>>> > cd petibm-build
>>>> > ​export PETSC_DIR=<directory of PETSc>
>>>> > export PETIBM_DIR=<directory of PetIBM git repo>
>>>> > $PETIBM_DIR/configure --prefix=$PWD \
>>>> >       CXX=$PETSC_DIR/$PETSC_ARCH/bin/mpicxx \
>>>> >       CXXFLAGS="-g -O0 -std=c++11"​
>>>> > make all
>>>> > make install
>>>> > ​Then
>>>> > cd examples
>>>> > make examples​
>>>> > ​The example of the lid-driven cavity I was talking about can be
>>>> found in the folder `examples/2d/convergence/lidDrivenCavity20/20/`​
>>>> > To run it:
>>>> > mpiexec -n N <path-to-petibm-build>/bin/petibm2d -directory
>>>> <path-to-example>
>>>> > Let me know if you need more info. Thank you.
>>>> >    Barry
>>>> > > On Oct 25, 2016, at 4:38 PM, Olivier Mesnard <
>>>> > > Hi all,
>>>> > > We develop a CFD code using the PETSc library that solves the
>>>> Navier-Stokes equations using the fractional-step method from Perot (1993).
>>>> > > At each time-step, we solve two systems: one for the velocity
>>>> field, the other, a Poisson system, for the pressure field.
>>>> > > One of our test-cases is a 2D lid-driven cavity flow (Re=100) on a
>>>> 20x20 grid using 1 or 2 procs.
>>>> > > For the Poisson system, we usually use CG preconditioned with GAMG.
>>>> > > So far, we have been using PETSc-3.5.4, and we would like to update
>>>> the code with the latest release: 3.7.4.
>>>> > > As suggested in the changelog of 3.6, we replaced the routine
>>>> `KSPSetNullSpace()` with `MatSetNullSpace()`.
>>>> > > Here is the list of options we use to configure the two solvers:
>>>> > > * Velocity solver: prefix `-velocity_`
>>>> > >   -velocity_ksp_type bcgs
>>>> > >   -velocity_ksp_rtol 1.0E-08
>>>> > >   -velocity_ksp_atol 0.0
>>>> > >   -velocity_ksp_max_it 10000
>>>> > >   -velocity_pc_type jacobi
>>>> > >   -velocity_ksp_view
>>>> > >   -velocity_ksp_monitor_true_residual
>>>> > >   -velocity_ksp_converged_reason
>>>> > > * Poisson solver: prefix `-poisson_`
>>>> > >   -poisson_ksp_type cg
>>>> > >   -poisson_ksp_rtol 1.0E-08
>>>> > >   -poisson_ksp_atol 0.0
>>>> > >   -poisson_ksp_max_it 20000
>>>> > >   -poisson_pc_type gamg
>>>> > >   -poisson_pc_gamg_type agg
>>>> > >   -poisson_pc_gamg_agg_nsmooths 1
>>>> > >   -poissonksp_view
>>>> > >   -poisson_ksp_monitor_true_residual
>>>> > >   -poisson_ksp_converged_reason
>>>> > > With 3.5.4, the case runs normally on 1 or 2 procs.
>>>> > > With 3.7.4, the case runs normally on 1 proc but not on 2.
>>>> > > Why? The Poisson solver diverges because of an indefinite
>>>> preconditioner (only with 2 procs).
>>>> > > We also saw that the routine `MatSetNullSpace()` was already
>>>> available in 3.5.4.
>>>> > > With 3.5.4, replacing `KSPSetNullSpace()` with `MatSetNullSpace()`
>>>> led to the Poisson solver diverging because of an indefinite matrix (on 1
>>>> and 2 procs).
>>>> > > Thus, we were wondering if we needed to update something else for
>>>> the KSP, and not just modifying the name of the routine?
>>>> > > I have attached the output files from the different cases:
>>>> > > * `run-petsc-3.5.4-n1.log` (3.5.4, `KSPSetNullSpace()`, n=1)
>>>> > > * `run-petsc-3.5.4-n2.log`
>>>> > > * `run-petsc-3.5.4-nsp-n1.log` (3.5.4, `MatSetNullSpace()`, n=1)
>>>> > > * `run-petsc-3.5.4-nsp-n2.log`
>>>> > > * `run-petsc-3.7.4-n1.log` (3.7.4, `MatSetNullSpace()`, n=1)
>>>> > > * `run-petsc-3.7.4-n2.log`
>>>> > > Thank you for your help,
>>>> > > Olivier
>>>> > > <run-petsc-3.5.4-n1.log><run-petsc-3.5.4-n2.log><run-petsc-3
>>>> .5.4-nsp-n1.log><run-petsc-3.5.4-nsp-n2.log><run-petsc-3.7.4
>>>> -n1.log><run-petsc-3.7.4-n2.log>
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161026/8dbeb4c8/attachment-0001.html>
