[petsc-users] Moving from KSPSetNullSpace to MatSetNullSpace
Olivier Mesnard
olivier.mesnard8 at gmail.com
Wed Oct 26 10:15:32 CDT 2016
On 26 October 2016 at 09:38, Mark Adams <mfadams at lbl.gov> wrote:
> Please run with -info and grep on GAMG and send that. (-info is very
> noisy).
> I cat the grep at the end of the log file (see attachment
petsc-3.7.4-n2.log).
Also, increasing the local number of iterations in SOR, as suggested by
Barry, removed the indefinite preconditioner (file
petsc-3.7.4-n2-lits2.log).
> I'm not sure what is going on here. Divergence with parallelism. Here are
> some suggestions.
> Note, you do not need to set the null space for a scalar (Poisson) problem
> unless you have some special null space. And not getting it set (with the 6
> rigid body modes) for the velocity (elasticity) equation will only degrade
> convergence rates.
> There was a bug for a while (early 3.7 versions) where the coarse grid was
> not squeezed onto one processor, which could result in very bad
> convergence, but not divergence, on multiple processors (the -info output
> will report the number of 'active pes'). Perhaps this bug is causing
> divergence for you. We had another subtle bug where the eigen estimates
> used a bad seed vector, which gives a bad eigen estimate. This would cause
> divergence but it should not be a parallelism issue (these two bugs were
> both regressions in around 3.7)
> Divergence usually comes from a bad eigen estimate in a Chebyshev
> smoother, but this is not highly correlated with parallelism. The -info
> data will report the eigen estimates but that is not terribly useful but
> you can see if it changes (gets larger) with better parameters. Add these
> parameters, with the correct prefix, and use -options_left to make sure
> that "there are no unused options":
> -mg_levels_ksp_type chebyshev
> -mg_levels_esteig_ksp_type cg
> -mg_levels_esteig_ksp_max_it 10
> -mg_levels_ksp_chebyshev_esteig 0,.1,0,1.05
> petsc-3.7.4-n2-chebyshev.log contains the output when using the default
KSP Chebyshev.
When estimating the eigenvalues using cg with the translations [0, 0.1; 0,
1.05] (previously using default gmres with translations [0, 0.1; 0, 1.1]),
the max eigenvalue decreases from 1.0931 to 1.04366 and the indefinite
preconditioner appears ealier after 2 iterations (3 previously).
I attached the log (see petsc-3.7.4-chebyshev.log).
> chebyshev is the default, as Barry suggested, replace this with gmres or
> richardson (see below) and verify that this fixed the divergence problem.
Using gmres (-poisson_mg_levels_ksp_type gmres) fixes the divergence problem
(file petsc-3.7.4-n2-gmres.log)
Same observation with richardson (file petsc-3.7.4-n2-richardson.log).
> If your matrix is symmetric positive definite then use
> '-mg_levels_esteig_ksp_type cg', if not then use the default gmres.
I checked and I still get an indefinite preconditioner when using gmres to
estimate the eigenvalues.
> Increase/decrease '-mg_levels_esteig_ksp_max_it 10', you should see the
> estimates increase and converge with higher max_it. Setting this to a huge
> number, like 100, should fix the bad seed vector problem mentioned above.
> I played with the maximum number of iterations. Here are the min/max
eigenvalue estimates for the two levels:
- max_it 5: (min=0.0975079, max=1.02383) on level 1, (0.0975647, 1.02443)
on level 2
- max_it 10: (0.0991546, 1.04112), (0.0993962, 1.04366)
- max_it 20: (0.0995918, 1.04571), (0.115723, 1.21509)
- max_it 50: (0.0995651, 1.04543), (0.133744, 1.40431)
- max_it 100: (0.0995651, 1.04543), (0.133744, 1.40431)
Note that all those runs ended up with an indefinite preconditioner, except
when increasing the maximum number of iterations to 50 (and 100, which did
not improve the eigenvalue estimates).
> If eigen estimates are a pain, like with non SPD systems, then
> richardson is an option (instead of chebyshev):
> -mg_levels_ksp_type richardson
> -mg_levels_ksp_richardson_scale 0.6
> You then need to play with the scaling (that is what chebyshev does for
> you essentially).
> On Tue, Oct 25, 2016 at 10:22 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Oct 25, 2016 at 9:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Olivier,
>>> Ok, so I've run the code in the debugger, but I don't not think the
>>> problem is with the null space. The code is correctly removing the null
>>> space on all the levels of multigrid.
>>> I think the error comes from changes in the behavior of GAMG. GAMG
>>> is relatively rapidly moving with different defaults and even different
>>> code with each release.
>>> To check this I added the option -poisson_mg_levels_pc_sor_lits 2
>>> and it stopped complaining about KSP_DIVERGED_INDEFINITE_PC. I've seen this
>>> before where the smoother is "too weak" and so the net result is that
>>> action of the preconditioner is indefinite. Mark Adams probably has better
>>> suggestions on how to make the preconditioner behave. Note you could also
>>> use a KSP of richardson or gmres instead of cg since they don't care about
>>> this indefinite business.
>> I think old GAMG squared the graph by default. You can see in the 3.7
>> output that it does not.
>> Matt
>>> Barry
>>> > On Oct 25, 2016, at 5:39 PM, Olivier Mesnard <
>>> olivier.mesnard8 at gmail.com> wrote:
>>> > On 25 October 2016 at 17:51, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> > Olivier,
>>> > In theory you do not need to change anything else. Are you using a
>>> different matrix object for the velocity_ksp object than the poisson_ksp
>>> object?
>>> > The matrix is different for the velocity_ksp and the poisson_ksp.
>>> > The code change in PETSc is very little but we have a report from
>>> another CFD user who also had problems with the change so there may be some
>>> subtle bug that we can't figure out causing things to not behave properly.
>>> > First run the 3.7.4 code with -poisson_ksp_view and verify that
>>> when it prints the matrix information it prints something like has attached
>>> null space if it does not print that it means that somehow the matrix is
>>> not properly getting the matrix attached.
>>> > When running with 3.7.4 and -poisson_ksp_view, the output shows that
>>> the nullspace is not attached to the KSP (as it was with 3.5.4); however
>>> the print statement is now under the Mat info (which is expected when
>>> moving from KSPSetNullSpace to MatSetNullSpace?).
>>> > Though older versions had MatSetNullSpace() they didn't
>>> necessarily associate it with the KSP so it was not expected to work as a
>>> replacement for KSPSetNullSpace() with older versions.
>>> > Because our other user had great difficulty trying to debug the
>>> issue feel free to send us at petsc-maint at mcs.anl.gov your code with
>>> instructions on building and running and we can try to track down the
>>> problem. Better than hours and hours spent with fruitless email. We will,
>>> of course, not distribute the code and will delete in when we are finished
>>> with it.
>>> > The code is open-source and hosted on GitHub (
>>> https://github.com/barbagroup/PetIBM).
>>> > I just pushed the branches `feature-compatible-petsc-3.7` and
>>> `revert-compatible-petsc-3.5` that I used to observe this problem.
>>> > PETSc (both 3.5.4 and 3.7.4) was configured as follow:
>>> > export PETSC_ARCH="linux-gnu-dbg"
>>> > ./configure --PETSC_ARCH=$PETSC_ARCH \
>>> > --with-cc=gcc \
>>> > --with-cxx=g++ \
>>> > --with-fc=gfortran \
>>> > --COPTFLAGS="-O0" \
>>> > --CXXOPTFLAGS="-O0" \
>>> > --FOPTFLAGS="-O0" \
>>> > --with-debugging=1 \
>>> > --download-fblaslapack \
>>> > --download-mpich \
>>> > --download-hypre \
>>> > --download-yaml \
>>> > --with-x=1
>>> > Our code was built using the following commands:
>>> > mkdir petibm-build
>>> > cd petibm-build
>>> > export PETSC_DIR=<directory of PETSc>
>>> > export PETIBM_DIR=<directory of PetIBM git repo>
>>> > $PETIBM_DIR/configure --prefix=$PWD \
>>> > CXX=$PETSC_DIR/$PETSC_ARCH/bin/mpicxx \
>>> > CXXFLAGS="-g -O0 -std=c++11"
>>> > make all
>>> > make install
>>> > Then
>>> > cd examples
>>> > make examples
>>> > The example of the lid-driven cavity I was talking about can be found
>>> in the folder `examples/2d/convergence/lidDrivenCavity20/20/`
>>> > To run it:
>>> > mpiexec -n N <path-to-petibm-build>/bin/petibm2d -directory
>>> <path-to-example>
>>> > Let me know if you need more info. Thank you.
>>> > Barry
>>> > > On Oct 25, 2016, at 4:38 PM, Olivier Mesnard <
>>> > > Hi all,
>>> > > We develop a CFD code using the PETSc library that solves the
>>> Navier-Stokes equations using the fractional-step method from Perot (1993).
>>> > > At each time-step, we solve two systems: one for the velocity field,
>>> the other, a Poisson system, for the pressure field.
>>> > > One of our test-cases is a 2D lid-driven cavity flow (Re=100) on a
>>> 20x20 grid using 1 or 2 procs.
>>> > > For the Poisson system, we usually use CG preconditioned with GAMG.
>>> > > So far, we have been using PETSc-3.5.4, and we would like to update
>>> the code with the latest release: 3.7.4.
>>> > > As suggested in the changelog of 3.6, we replaced the routine
>>> `KSPSetNullSpace()` with `MatSetNullSpace()`.
>>> > > Here is the list of options we use to configure the two solvers:
>>> > > * Velocity solver: prefix `-velocity_`
>>> > > -velocity_ksp_type bcgs
>>> > > -velocity_ksp_rtol 1.0E-08
>>> > > -velocity_ksp_atol 0.0
>>> > > -velocity_ksp_max_it 10000
>>> > > -velocity_pc_type jacobi
>>> > > -velocity_ksp_view
>>> > > -velocity_ksp_monitor_true_residual
>>> > > -velocity_ksp_converged_reason
>>> > > * Poisson solver: prefix `-poisson_`
>>> > > -poisson_ksp_type cg
>>> > > -poisson_ksp_rtol 1.0E-08
>>> > > -poisson_ksp_atol 0.0
>>> > > -poisson_ksp_max_it 20000
>>> > > -poisson_pc_type gamg
>>> > > -poisson_pc_gamg_type agg
>>> > > -poisson_pc_gamg_agg_nsmooths 1
>>> > > -poissonksp_view
>>> > > -poisson_ksp_monitor_true_residual
>>> > > -poisson_ksp_converged_reason
>>> > > With 3.5.4, the case runs normally on 1 or 2 procs.
>>> > > With 3.7.4, the case runs normally on 1 proc but not on 2.
>>> > > Why? The Poisson solver diverges because of an indefinite
>>> preconditioner (only with 2 procs).
>>> > > We also saw that the routine `MatSetNullSpace()` was already
>>> available in 3.5.4.
>>> > > With 3.5.4, replacing `KSPSetNullSpace()` with `MatSetNullSpace()`
>>> led to the Poisson solver diverging because of an indefinite matrix (on 1
>>> and 2 procs).
>>> > > Thus, we were wondering if we needed to update something else for
>>> the KSP, and not just modifying the name of the routine?
>>> > > I have attached the output files from the different cases:
>>> > > * `run-petsc-3.5.4-n1.log` (3.5.4, `KSPSetNullSpace()`, n=1)
>>> > > * `run-petsc-3.5.4-n2.log`
>>> > > * `run-petsc-3.5.4-nsp-n1.log` (3.5.4, `MatSetNullSpace()`, n=1)
>>> > > * `run-petsc-3.5.4-nsp-n2.log`
>>> > > * `run-petsc-3.7.4-n1.log` (3.7.4, `MatSetNullSpace()`, n=1)
>>> > > * `run-petsc-3.7.4-n2.log`
>>> > > Thank you for your help,
>>> > > Olivier
>>> > > <run-petsc-3.5.4-n1.log><run-petsc-3.5.4-n2.log><run-petsc-3
>>> .5.4-nsp-n1.log><run-petsc-3.5.4-nsp-n2.log><run-petsc-3.7.4
>>> -n1.log><run-petsc-3.7.4-n2.log>
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161026/e0b4795a/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161026/e0b4795a/attachment-0005.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161026/e0b4795a/attachment-0006.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161026/e0b4795a/attachment-0007.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161026/e0b4795a/attachment-0008.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161026/e0b4795a/attachment-0009.bin>
