[petsc-users] Using PETSc solvers and preconditioners with mfem
Abdullah Ali Sivas
abdullahasivas at gmail.com
Tue Oct 25 11:30:20 CDT 2016
I will check that. I am preallocating but it may be that I am not
allocating big enough. I still have to figure out nuance differences
between these formats to solve the bugs. I appreciate your answer and
hope Satish knows it.
Thank you,
Abdullah Ali Sivas
On 2016-10-25 12:15 PM, Matthew Knepley wrote:
> On Tue, Oct 25, 2016 at 10:54 AM, Abdullah Ali Sivas
> <abdullahasivas at gmail.com <mailto:abdullahasivas at gmail.com>> wrote:
> Hello,
> I want to use PETSc with mfem and I know that mfem people will
> figure out a way to do it in few months. But for now as a
> temporary solution I just thought of converting hypre PARCSR
> matrices (that is what mfem uses as linear solver package) into
> PETSc MPIAIJ matrices and I have a semi-working code with some
> bugs. Also my code is dauntingly slow and seems like not scaling.
> I have used /MatHYPRE_IJMatrixCopy /from myhp.c of PETSc and
> /hypre_ParCSRMatrixPrintIJ/ from par_csr_matrix.c of hypre as
> starting points. Before starting I checked whether there was
> anything done similar to this, I could not find anything.
> My question is, are you aware of such a conversion code (i.e.
> something like /hypre_ParCSRtoPETScMPIAIJ( hypre_ParCSRMatrix
> *matrix, //Mat *A/)?
> No, but maybe Satish knows. Slow running times most likely come from
> lack of preallocation for the target matrix.
> Thanks,
> Matt
> Thanks in advance,
> Abdullah Ali Sivas
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161025/3113fea5/attachment.html>
