[petsc-users] preconditioner for contact / mesh tying problem
    Hoang Giang Bui
    hgbk2008 at gmail.com
    Tue Oct 18 11:27:40 CDT 2016
Clear on that. First I need some time to study ex77 carefully.
Giang
On Tue, Oct 18, 2016 at 6:19 PM, Jed Brown <jed at jedbrown.org> wrote:
> Hoang Giang Bui <hgbk2008 at gmail.com> writes:
> > I do have an elasticity solver though. However it's an in-house code
> hence
> > it's not very straight forward to unroll to make a PETSc example. The
> > example can only read in the provided matrices and apply the
> > preconditioner. However, I think in general standard PETSc example
> > generates the linear system and solve it successively. In that way, ex77
> > must be extended. What do you think?
> I suggest SNES ex77 (versus writing a pure KSP example) because the
> contact problem is nonlinear and your example might as well actually
> solve a problem instead of just solving one linearized step.  That said,
> VIRS isn't set up for general constraints using Lagrange multipliers, so
> it might be trying to tackle too many problems at once.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161018/eb545de7/attachment.html>
