[petsc-users] large PetscCommDuplicate overhead
Barry Smith
bsmith at mcs.anl.gov
Mon Oct 17 16:48:08 CDT 2016
Hmm, None of these sadly. There should be no barriers in the calls (optimized versions) just MPI_Attr_get() and MPI_Attr_set().
Maybe someone else has a better idea.
Barry
> On Oct 17, 2016, at 3:41 PM, Matthew Overholt <overholt at capesim.com> wrote:
> Barry,
> If I look at the symbols available to trace I find the following.
>> nm xSYMMIC | grep " T MPI" | grep "attr"
> <#> T MPIR_Call_attr_copy
> <#> T MPIR_Call_attr_delete
> <#> T MPIR_Comm_delete_attr_impl
> <#> T MPIR_Comm_set_attr_impl
> <#> T MPIU_nem_gni_smsg_mbox_attr_init
> => Are the two _Comm_ symbols the ones of interest?
>> nm xSYMMIC | grep " T MPI" | grep "arrier"
> <#> T MPIDI_CRAY_dmapp_barrier_join
> <#> T MPIDI_Cray_shared_mem_coll_barrier
> <#> T MPIDI_Cray_shared_mem_coll_barrier_gather
> <#> T MPID_Sched_barrier
> <#> T MPID_nem_barrier
> <#> T MPID_nem_barrier_init
> <#> T MPID_nem_barrier_vars_init
> <#> T MPIR_Barrier
> <#> T MPIR_Barrier_impl
> <#> T MPIR_Barrier_inter
> <#> T MPIR_Barrier_intra
> <#> T MPIR_CRAY_Barrier
> <#> T MPIR_Ibarrier_impl
> <#> T MPIR_Ibarrier_inter
> <#> T MPIR_Ibarrier_intra
> => Which of these barriers should I trace?
> Finally, the current version of PETSc seems to be 3.7.2; I am not able to
> load 3.7.3.
> Thanks,
> Matt Overholt
> -----Original Message-----
> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
> Sent: Thursday, October 13, 2016 11:46 PM
> To: overholt at capesim.com
> Cc: Jed Brown; PETSc
> Subject: Re: [petsc-users] large PetscCommDuplicate overhead
> Mathew,
> Thanks for the additional information. This is all very weird since the
> same number of calls made to PetscCommDuplicate() are the same regardless
> of geometry and the time of the call shouldn't depend on the geometry.
> Would you be able to do another set of tests where you track the time in
> MPI_Get_attr() and MPI_Barrier() instead of PetscCommDuplicate()? It could
> be Cray did something "funny" in their implementation of PETSc.
> You could also try using the module petsc/3.7.3 instead of the cray-petsc
> module
> Thanks
> Barry
>> On Oct 12, 2016, at 10:48 AM, Matthew Overholt <overholt at capesim.com>
> wrote:
>> Jed,
>> I realize that the PetscCommDuplicate (PCD) overhead I am seeing must
>> be only indirectly related to the problem size, etc., and I wouldn't
>> be surprised if it was an artifact of some sort related to my specific
>> algorithm. So you may not want to pursue this much further. However,
>> I did make three runs using the same Edison environment and code but
>> different input geometry files. Earlier I found a strong dependence
>> on the number of processes, so for this test I ran all of the tests on
>> 1 node with 8 processes (N=1, n=8). What I found was that the amount
>> of PCD overhead was geometry dependent, not size dependent. A
>> moderately-sized simple geometry (with relatively few ghosted vertices
>> at the simple-planar interfaces) had no PCD overhead, whereas both
>> small and large complex geometries (with relatively more ghosted
>> vertices at the more-complex interfaces) had 5 - 6% PCD overhead. The log
> files follow.
>> Thanks,
>> Matt Overholt
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
