[petsc-users] create global vector in latest version of petsc
frank
hengjiew at uci.edu
Wed Oct 5 19:57:18 CDT 2016
I update petsc to the latest version by pulling from the repo. Then I
find one of my old code, which worked before, output errors now.
After debugging, I find that the error is caused by "DMCreateGlobalVector".
I attach a short program which can re-produce the error. This program
works well with an older version of petsc.
I also attach the script I used to configure petsc.
The error message is below. Did I miss something in the installation ?
Thank you.
1 [0]PETSC ERROR: --------------------- Error Message
2 [0]PETSC ERROR: Null argument, when expecting valid pointer
3 [0]PETSC ERROR: Null Object: Parameter # 2
4 [0]PETSC ERROR: See
http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
5 [0]PETSC ERROR: Petsc Development GIT revision:
v3.7.4-1571-g7fc5cb5 GIT Date: 2016-10-05 10:56:19 -0500
6 [0]PETSC ERROR: [2]PETSC ERROR: ./test_ksp.exe on a gnu-dbg-32idx
named kolmog1 by frank Wed Oct 5 17:40:07 2016
7 [0]PETSC ERROR: Configure options --known-mpi-shared="0 "
--known-memcmp-ok --with-debugging="1 " --with-shared-libraries=0
--with-mpi-compilers="1 " --download-blacs="1 " --download-metis="1 "
--dow nload-parmetis="1 " --download-superlu_dist="1 "
--download-hypre=1 PETSC_ARCH=gnu-dbg-32idx
8 [0]PETSC ERROR: #1 VecSetLocalToGlobalMapping() line 83 in
/home/frank/petsc/src/vec/vec/interface/vector.c
9 [0]PETSC ERROR: #2 DMCreateGlobalVector_DA() line 45 in
/home/frank/petsc/src/dm/impls/da/dadist.c
10 [0]PETSC ERROR: #3 DMCreateGlobalVector() line 880 in
/home/frank/petsc/src/dm/interface/dm.c
Frank
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161005/9cbb105a/attachment.bin>
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161005/9cbb105a/attachment.py>
