[petsc-users] large PetscCommDuplicate overhead
Matthew Overholt overholt at capesim.com
Wed Oct 12 10:48:18 CDT 2016
Jed,
I realize that the PetscCommDuplicate (PCD) overhead I am seeing must be
only indirectly related to the problem size, etc., and I wouldn't be
surprised if it was an artifact of some sort related to my specific
algorithm.  So you may not want to pursue this much further.  However, I did
make three runs using the same Edison environment and code but different
input geometry files.  Earlier I found a strong dependence on the number of
processes, so for this test I ran all of the tests on 1 node with 8
processes (N=1, n=8).  What I found was that the amount of PCD overhead was
geometry dependent, not size dependent.  A moderately-sized simple geometry
(with relatively few ghosted vertices at the simple-planar interfaces) had
no PCD overhead, whereas both small and large complex geometries (with
relatively more ghosted vertices at the more-complex interfaces) had 5 - 6%
PCD overhead.  The log files follow.
Matt Overholt
// pllSs20 : Simple Pencil Shape with Small Planar Interfaces
//           No PetscCommDuplicate() overhead in CrayPat sampling.
...713097 vertices...646400 elements (moderate size)
Total run time was 47.853 seconds.
---------------------------------------------- PETSc Performance Summary:
Using Petsc Release Version 3.7.2, Jun, 05, 2016
                         Max       Max/Min        Avg      Total
Time (sec):           4.822e+01      1.01022   4.780e+01
Objects:              1.160e+02      1.00000   1.160e+02
Flops:                1.425e+06      1.00000   1.425e+06  1.140e+07
Flops/sec:            2.986e+04      1.01022   2.982e+04  2.385e+05
MPI Messages:         1.140e+02      1.46154   9.500e+01  7.600e+02
MPI Message Lengths:  7.202e+07      3.55575   2.888e+05  2.195e+08
MPI Reductions:       2.600e+02      1.00000
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---
-- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total
 0:      Main Stage: 4.7802e+01 100.0%  1.1402e+07 100.0%  7.600e+02 100.0%
2.888e+05      100.0%  2.590e+02  99.6%
Event                Count      Time (sec)     Flops
--- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecMax                 8 1.0 3.8538e-03 3.9 0.00e+00 0.0 0.0e+00 0.0e+00
8.0e+00  0  0  0  0  3   0  0  0  0  3     0
VecNorm                8 1.0 1.8222e-03 1.0 7.13e+05 1.0 0.0e+00 0.0e+00
8.0e+00  0 50  0  0  3   0 50  0  0  3  3129
VecCopy                8 1.0 5.5838e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                31 1.0 9.2564e-03 5.7 0.00e+00 0.0 0.0e+00 0.0e+00
VecAYPX                8 1.0 1.0111e-03 1.2 7.13e+05 1.0 0.0e+00 0.0e+00
0.0e+00  0 50  0  0  0   0 50  0  0  0  5638
VecAssemblyBegin      26 1.0 4.5311e-01 1.9 0.00e+00 0.0 2.1e+02 5.7e+05
7.8e+01  1  0 28 55 30   1  0 28 55 30     0
VecAssemblyEnd        26 1.0 5.2852e-0211.7 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin       39 1.0 4.5546e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00
3.9e+01  0  0  0 29 15   0  0  0 29 15     0
VecScatterEnd         19 1.0 2.4319e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
MatSolve               8 1.0 1.3143e+00 1.0 0.00e+00 0.0 3.4e+02 2.0e+05
3.2e+01  3  0 44 31 12   3  0 44 31 12     0
MatLUFactorSym         1 1.0 1.1012e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
5.0e+00 23  0  0  0  2  23  0  0  0  2     0
MatLUFactorNum         8 1.0 3.1378e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 66  0  0  0  0  66  0  0  0  0     0
MatAssemblyBegin       8 1.0 1.5738e-03 2.0 0.00e+00 0.0 1.7e+02 6.8e+04
1.6e+01  0  0 22  5  6   0  0 22  5  6     0
MatAssemblyEnd         8 1.0 3.4761e-02 1.0 0.00e+00 0.0 2.8e+01 8.8e+02
2.3e+01  0  0  4  0  9   0  0  4  0  9     0
MatGetRowIJ            1 1.0 2.4080e-05 5.9 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering         1 1.0 3.5882e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
MatZeroEntries         8 1.0 3.6283e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSetUp               1 1.0 1.1921e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve               8 1.0 4.3712e+01 1.0 0.00e+00 0.0 3.4e+02 2.0e+05
4.3e+01 91  0 44 31 17  91  0 44 31 17     0
PCSetUp                8 1.0 4.2397e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
1.1e+01 89  0  0  0  4  89  0  0  0  4     0
PCApply                8 1.0 1.3144e+00 1.0 0.00e+00 0.0 3.4e+02 2.0e+05
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    46             43     49344760     0.
      Vector Scatter    23             22        18176     0.
           Index Set    37             37      3279764     0.
   IS L to G Mapping     1              0            0     0.
              Matrix     6              6     43498680     0.
       Krylov Solver     1              1         1160     0.
      Preconditioner     1              1          992     0.
              Viewer     1              0            0     0.
Average time to get PetscTime(): 5.00679e-07
Average time for MPI_Barrier(): 1.81198e-06
Average time for zero size MPI_Send(): 3.75509e-06
// HBT-HP5 : Small Complex Shape with Complex Interfaces
//           5.3% PetscCommDuplicate() overhead in CrayPat sampling.
...50564 vertices...45420 elements  (small size)
Total run time was 4.863 seconds.
Time (sec):           4.930e+00      1.00841   4.894e+00
Objects:              1.080e+02      1.00000   1.080e+02
Flops:                7.539e+04      1.06240   7.267e+04  5.813e+05
Flops/sec:            1.542e+04      1.06244   1.485e+04  1.188e+05
MPI Messages:         2.070e+02      2.43529   1.628e+02  1.302e+03
MPI Message Lengths:  7.824e+06      2.40897   2.965e+04  3.861e+07
MPI Reductions:       2.320e+02      1.00000
 0:      Main Stage: 4.8945e+00 100.0%  5.8133e+05 100.0%  1.302e+03 100.0%
2.965e+04      100.0%  2.310e+02  99.6%
VecMax                 6 1.0 1.1725e-0321.6 0.00e+00 0.0 0.0e+00 0.0e+00
6.0e+00  0  0  0  0  3   0  0  0  0  3     0
VecNorm                6 1.0 2.2173e-02 1.0 3.77e+04 1.1 0.0e+00 0.0e+00
6.0e+00  0 50  0  0  3   0 50  0  0  3    13
VecCopy                6 1.0 3.1948e-05 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet                27 1.0 4.0102e-04 4.3 0.00e+00 0.0 0.0e+00 0.0e+00
VecAYPX                6 1.0 6.3896e-05 1.2 3.77e+04 1.1 0.0e+00 0.0e+00
0.0e+00  0 50  0  0  0   0 50  0  0  0  4549
VecAssemblyBegin      24 1.0 5.7409e-02 1.7 0.00e+00 0.0 3.1e+02 3.7e+04
7.2e+01  1  0 24 30 31   1  0 24 30 31     0
VecAssemblyEnd        24 1.0 4.1070e-0322.5 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin       33 1.0 6.2511e-03 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
3.3e+01  0  0  0 13 14   0  0  0 13 14     0
VecScatterEnd         15 1.0 2.7657e-04 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
MatSolve               6 1.0 1.3485e-01 1.0 0.00e+00 0.0 5.9e+02 5.8e+03
2.4e+01  3  0 45  9 10   3  0 45  9 10     0
MatLUFactorSym         1 1.0 6.4367e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
5.0e+00 13  0  0  0  2  13  0  0  0  2     0
MatLUFactorNum         6 1.0 3.5177e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 72  0  0  0  0  72  0  0  0  0     0
MatAssemblyBegin       6 1.0 3.6111e-03 2.0 0.00e+00 0.0 3.1e+02 6.8e+04
1.2e+01  0  0 24 54  5   0  0 24 54  5     0
MatAssemblyEnd         6 1.0 2.2925e-02 1.1 0.00e+00 0.0 6.8e+01 8.8e+02
1.9e+01  0  0  5  0  8   0  0  5  0  8     0
MatGetRowIJ            1 1.0 4.0531e-06 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering         1 1.0 4.3869e-05 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
MatZeroEntries         6 1.0 1.6685e-03 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve               6 1.0 4.3020e+00 1.0 0.00e+00 0.0 5.9e+02 5.8e+03
3.5e+01 88  0 45  9 15  88  0 45  9 15     0
PCSetUp                6 1.0 4.1670e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
1.1e+01 85  0  0  0  5  85  0  0  0  5     0
PCApply                6 1.0 1.3486e-01 1.0 0.00e+00 0.0 5.9e+02 5.8e+03
              Vector    44             41      3635912     0.
      Vector Scatter    21             20        90672     0.
           Index Set    33             33       286872     0.
              Matrix     6              6      2988180     0.
              Viewer     1              0            0     0.
Average time for MPI_Barrier(): 2.00272e-06
Average time for zero size MPI_Send(): 3.12924e-06
// GaNSi13 : Large Complex Shape with Complex Interfaces
//           6.4% PetscCommDuplicate() overhead in CrayPat sampling.
...1642311 vertices...1497368 elements  (large size)
Total run time was 260.958 seconds.
Time (sec):           2.619e+02      1.00319   2.611e+02
Objects:              1.040e+02      1.00000   1.040e+02
Flops:                2.050e+06      1.07341   1.969e+06  1.575e+07
Flops/sec:            7.853e+03      1.07354   7.541e+03  6.032e+04
MPI Messages:         1.835e+02      1.47390   1.448e+02  1.158e+03
MPI Message Lengths:  1.761e+08      3.47614   4.801e+05  5.560e+08
MPI Reductions:       2.180e+02      1.00000
 0:      Main Stage: 2.6114e+02 100.0%  1.5754e+07 100.0%  1.158e+03 100.0%
4.801e+05      100.0%  2.170e+02  99.5%
VecMax                 5 1.0 5.5013e-03 7.3 0.00e+00 0.0 0.0e+00 0.0e+00
5.0e+00  0  0  0  0  2   0  0  0  0  2     0
VecNorm                5 1.0 1.8921e-03 1.0 1.02e+06 1.1 0.0e+00 0.0e+00
5.0e+00  0 50  0  0  2   0 50  0  0  2  4163
VecCopy                5 1.0 9.0218e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet                25 1.0 2.4175e-0210.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecAYPX                5 1.0 1.2169e-03 1.1 1.02e+06 1.1 0.0e+00 0.0e+00
0.0e+00  0 50  0  0  0   0 50  0  0  0  6473
VecAssemblyBegin      23 1.0 2.6960e+00 1.6 0.00e+00 0.0 3.2e+02 9.2e+05
6.9e+01  1  0 28 54 32   1  0 28 54 32     0
VecAssemblyEnd        23 1.0 1.2512e-0111.1 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin       30 1.0 1.3994e-01 3.3 0.00e+00 0.0 0.0e+00 0.0e+00
3.0e+01  0  0  0 19 14   0  0  0 19 14     0
VecScatterEnd         13 1.0 4.6802e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
MatSolve               5 1.0 2.9838e+00 1.0 0.00e+00 0.0 3.7e+02 2.3e+05
2.0e+01  1  0 32 15  9   1  0 32 15  9     0
MatLUFactorSym         1 1.0 2.8861e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
5.0e+00 11  0  0  0  2  11  0  0  0  2     0
MatLUFactorNum         5 1.0 1.9893e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 76  0  0  0  0  76  0  0  0  0     0
MatAssemblyBegin       5 1.0 1.6689e-02 2.9 0.00e+00 0.0 3.3e+02 3.7e+05
1.0e+01  0  0 28 22  5   0  0 28 22  5     0
MatAssemblyEnd         5 1.0 5.6672e+00 1.0 0.00e+00 0.0 9.2e+01 4.5e+03
1.7e+01  2  0  8  0  8   2  0  8  0  8     0
MatGetRowIJ            1 1.0 4.0531e-06 2.1 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering         1 1.0 7.0381e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
MatZeroEntries         5 1.0 7.0859e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSetUp               1 1.0 9.5367e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve               5 1.0 2.3079e+02 1.0 0.00e+00 0.0 3.7e+02 2.3e+05
3.1e+01 88  0 32 15 14  88  0 32 15 14     0
PCSetUp                5 1.0 2.2781e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
1.1e+01 87  0  0  0  5  87  0  0  0  5     0
PCApply                5 1.0 2.9838e+00 1.0 0.00e+00 0.0 3.7e+02 2.3e+05
              Vector    43             40    114480760     0.
      Vector Scatter    20             19       291760     0.
           Index Set    31             31      5440808     0.
              Matrix     6              6     99689528     0.
              Viewer     1              0            0     0.
Average time to get PetscTime(): 1.90735e-07
-----Original Message-----
Sent: Tuesday, October 11, 2016 5:19 PM
To: overholt at capesim.com; 'Barry Smith'
Cc: 'PETSc'
Subject: Re: [petsc-users] large PetscCommDuplicate overhead
Matthew Overholt <overholt at capesim.com> writes:
> Barry,
> Subsequent tests with the same code and a problem (input) having a
> much smaller vertex (equation) count (i.e. a much smaller matrix to
> invert for the solution) have NOT had PetscCommDuplicate() account for
> any significant time, so I'm not surprised that your test didn't find any
problem.
Can you re-run the large and small configurations with the same
code/environment and resend those logs?  PetscCommDuplicate has nothing to
do with the problem size, so any difference in cost must be indirect, though
attribute access should be simple and independent.
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
