[petsc-users] large PetscCommDuplicate overhead
Jed Brown jed at jedbrown.org
Tue Oct 11 16:19:05 CDT 2016
Matthew Overholt <overholt at capesim.com> writes:
> Barry,
> Subsequent tests with the same code and a problem (input) having a much
> smaller vertex (equation) count (i.e. a much smaller matrix to invert for
> the solution) have NOT had PetscCommDuplicate() account for any significant
> time, so I'm not surprised that your test didn't find any problem.
Can you re-run the large and small configurations with the same
code/environment and resend those logs?  PetscCommDuplicate has nothing
to do with the problem size, so any difference in cost must be indirect,
though attribute access should be simple and independent.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161011/77fc6879/attachment-0001.pgp>
